Florida240sx
Online
93 Hatch 5spd 93 vert 89 hatch
DeLand FL
7-1-2004
Sure it's a bearing not timing chain? Wishful thinking
http://www.itsfunnyhoney.com/v..._time S14 for sale http://forums.nicoclub.com/zerothread?id=294220
 Megan Racing Parts supplier.Among many more companies Act, hks, b&m, sparco,msd,etc. hotrod6000000@yahoo.com KA-T why settle for anything less?
nelson8708
1989 Nissan 240sx Fastback
Sideways
12-14-2004
| « Re: (Florida240sx) | 5:26 AM 7/19/2008 |
All my buddies said it was my exhaust hitting my dump tube or some thing. It sounds like that until you open the hood. Since its at the back of the motor i kind of ruled the timing chain out. .....Its one of those sounds that when you hear it coming from your car you get that feeling in your gut. Ya never know...maybe next weekend when i get a chance to look into to it might be some thing else but, i'm not holding my breath.I'm pretty much going to throw it up on jack stands and if everything looks ok under it then i am going to go ahead and start unbolting the tranny and what not.
eazye2000
Booze Hound
of FAIL...
Hanscom AFB MA
6-27-2005
| « Re: (nelson8708) | 6:20 AM 7/19/2008 |
What kind of clutch do you have? Stock, or aftermarket? I'm just asking because my stocker took a crap, and sounded like a 'knock'. It was either the pilot, or throwout bearing.| Quote, originally posted by Florida240sx » | | Sure it's a bearing not timing chain? Wishful thinking |
My S14 does that. You can heat that bish' doing it's thing at idle, but if you bump up the rpm's, it goes away. I guess the oil pressure tightens it up. Or that's a sign of a bad oil pump.. who knows'. lol But yeah, hope it's nothing bad. And the fact that you drove it home without a hitch, is a good thing. Now that you're going to tear it down, put some fortified guts in that puppy!
DevilMB3017
1991 Nissan 240SX Hatch & 2004 Saturn ION 3 Coupe
Union NJ
9-14-2006
Could be a clutch thing like has been said.If it happens only at idle, maybe it's a valve thing? You sure it's not coming from the top of the motor? Just throwing it out there.
Proud Member Of WBDM2TTWFOC. "I'm no prince, and I can't lay the stars at your feet, But I got this old car, and she's pretty tough to beat..." Wings For Wheels, by Bruce Springsteen
480sx
Angry Hippie
1991 White/Black s13 1996 Pearl White 240sx
NOVA Va
11-12-2006
| « Re: (DevilMB3017) | 10:44 AM 7/19/2008 |
If its an RPM based ticking type sound, its almost def a rod bearing. Really surprised that you were able to drive it home though, when i had rod knock it went from being barely audible to horrible sounding within 10 min. Time for a rebuild!
For Sale!Brand new Borg Warner S258 ---> http://forums.nicoclub.com/zerothread?id=354932 NIB Ferrea 1mm oversize ka24de valves 4 a KA ---> http://forums.nicoclub.com/zerothread?id=363557 New sparco sliders/rail for a s14 --> EMAIL ME
WDRacing
Super Grumpy Moderator
1995 240SX, K5 Blazer
USA
11-25-2002
| « Re: (480sx) | 2:53 PM 7/19/2008 |
When you get rod knock it's almost always a lube problem, unless you stretched the hardware. But shifting at 6k isn't going to do that, and 5 psi isn't creating so much torque you were bending things.I had that issue...I had knock...then I had a hole in the block. In fact 3 years later that same engine with the hole is still under the hood...lol.
nelson8708
Sideways
12-14-2004
| « Re: (WDRacing) | 3:16 PM 7/19/2008 |
As for clutch i have a WBS. Its not a valve thing. Its sounds like it coming from the bottom end. I have bad cell phone vid of it i will post that i took that night. I need to turn the car around in the garage to get ready to pull the motor in the next few weeks so i will get another vid then too. If if was the clutch shouldn't the noise change when i engage / disengauge the clutch? When i bought the car it had a bad throw out bearing that made some weird noises but it wasnt the same as this. My buddie (also sohc) thought he had a lifter seize on him but coutinued to drive the car for about a week or two. It was a rod knock and the motor ended up seizing in his drive way after a drive home from work. So he drove it for about 1.5-2 weeks after hearing the initial rod knock. http://tinypic.com/player.php?v=285b7o&s=4 I have a high volume 280zx oil pump so i dont think it was a pressure or volume problem. The only thing i can think of being a lube problem is that it was a 95 degree day. During my last run when it happend it had cooled down to probably 86 degrees. I was running 10w30 (only had 800 miles on the oil that was in the engine though).
480sx
Angry Hippie
NOVA Va
11-12-2006
| « Re: (nelson8708) | 7:32 PM 7/19/2008 |
Woulda been helpful if you reved the motor when you took that vid but... Doesnt sound good hah. Id say rod knock for sure if the noise follows through the RPMs. You got an oil pressure gage? Hows the OP?
nelson8708
Sideways
12-14-2004
| « Re: (480sx) | 3:03 AM 7/20/2008 |
I have a oil pressure gauge, just not installed.lol....I got another sohc last night though. I am kinda debating on what i want to do. Me and a buddie have to go pick it up. He gets the cylinder head and i get the short block. Depending on how my bottom end looks when i pull it i will either fix the motor in the car or just swap my head onto the short block i am getting. The only thing is i dont know what kinda shape the block i am getting is in. Might be fine or it may have a spun bearing and bad compression. I will probably fix the motor that is in the car. New bearing and possibly a new crank. As long as the rod is ok i'm not even going to take the head off.
neverlift
brain fart
PIGNOSE #19 turbo piggy
sunshinestate
4-24-2006
| « Re: (nelson8708) | 8:35 AM 7/20/2008 |
that is what my bud's cobra sounded like , till it put a chunk of al. block in my driveway never got to race the ****er damn nelson at least you got it home man so what was your best time?
PIGNOSE SQUAD MEMBER # 19
 ---------------------------------- r.i.p. Lee 09/01/89~09/28/06
nelson8708
Sideways
12-14-2004
| « Re: Went to the track.....now pulling motor (nelson8708) | 4:13 PM 7/20/2008 |
| Quote, originally posted by nelson8708 » | I went to the track today. I got there about 6pm and did runs all the way till 10pm. I got 16 runs in ...I probably did three runs back to back then took a half hour break or so. I was on 5psi, bald street tires, welded diff. For the first 6 runs or so i couldn't get a decent launch. Were talking 2.4 to 2.6 60's. I was launching around 3K since that is what i launch at on the street but i would spin like crazy on the street and i was bogging on the track. I kept upping my laucnch rpms and when i got around 4K it didnt bog as much any more. Towards the end of the night i was launching at 4,200rpm and was cutting 2.2 60's. I think i can get it a little lower if i were to lauch around 4,500. My best time of the night was a 14.6@97 with the 2.2 60'. |
Yeah i was happy that i atleast made it home.
nissanfanatic
1992 Nissan 240sx SE
Gainesville Fl
11-1-2004
I had an issue that sounded like bad knock on the dyno after putting down 532whp. It turned out to be my flywheel bolts shearing off/backing out. I would check oil pressure, as if you have enough clearance to be knocking, oil pressure should be pretty low.You don't run the car hard when it is cold do you?
-Cory Street racing fatalities: 0.21% of total fatalities in motor vehicle crashes. FTC1992 Nissan 240sx KA24DE-Turbo: The "Showcar" Stock internals 532whp/486ft.lbs-30psi 12.6@122.3mph-22psi http://ka-t.org/cory_b.php
Ghost518
92 240sx hatch
Rotterdam NY
4-9-2007
| « Re: (nissanfanatic) | 8:58 PM 7/21/2008 |
guy near me has a junkyard turbo setup KA SOHC on his 90. his best was 14.4 @ 95. im very glad to see people arent throwing these motors out. nothing wrong with sohc.
'92 Hatch... ~ Car Domain ~ MySpace ~ Buy my stuff, most free!! Build Thread ~Local Car fourm, Albany NY. im Hooked on 240 PM me if your selling a 89-93 240sx coupe shell, or in crapping condition
nelson8708
Sideways
12-14-2004
| « Re: (nissanfanatic) | 2:59 PM 7/24/2008 |
| Quote, originally posted by nissanfanatic » | | I had an issue that sounded like bad knock on the dyno after putting down 532whp. It turned out to be my flywheel bolts shearing off/backing out. I would check oil pressure, as if you have enough clearance to be knocking, oil pressure should be pretty low. You don't run the car hard when it is cold do you? |
No i never beat on the car when its cold. I wait for it to atleast get up to 160-170 degrees. I believe i read on moto tune usa that beating on a motor that is not fully warmed up is one of the main causes of engine failure. When i pull it i will find out whether or not its the flywheel bolts backing out or not. I did use red lock tite when i installed them but, that doesnt mean they didnt back out. When i pull it i plan on spot welding what i can in the engine bay as well as maybe cleaning up a few wires. Do you think it could of been the fact that i was running too light of engine oil (10w30 on a 92 degree day)? I am thinking 10w-40 or maybe 20w50 depending on my clearences if it turns out that i have to replace my bearings. | Quote, originally posted by Ghost518 » | | guy near me has a junkyard turbo setup KA SOHC on his 90. his best was 14.4 @ 95. im very glad to see people arent throwing these motors out. nothing wrong with sohc. |
Yeah...I ran a 15.2@92 on my t25/smic setup. My clutch was already going so i didnt launch it and ran a 2.7 60' when i was at the track with that setup. I think i could of ran a 14.5 or 14.4 (new setup) if i had launched a little higher. I was getting nervous when i was having to launch around 4K even though i was still bogging. I think the sweet spot would be 4.5K and then i would be able to cut a sub 2.0 60'. Plus i had pulled to much timing on that tune. I pulled enough timing for 8psi since i though i would be running that but, i was only on 5psi because the mafs maxed out. So with a little timing put back in and a higher launch rpm i think i could of gotten a little better time.
nelson8708
Sideways
12-14-2004
| « Re: (nelson8708) | 5:36 PM 7/29/2008 |
Update:I am starting to think it might be the clutch like nissan fanatic said. I had to start the car today to turn it around in the garage to get it ready to pull the motor next weekend and when i stated it...it was fine and didnt make any noises. Once it warmed up a little the noise came back but it wasnt loud. I have noticed that it only does it on the down rev and because that i think it might be a wrist pin / piston issue. It does have ebay pistons in it after all. My tig teacher gave me the hint that it might be wrist pin related. He does a lot of welding for a sprint car team and he and his son use to race go karts so he knows a bad sound when he hears it, But he said that only wrist pins make the noise on the down rev and if i had spun a bearing it should do it all the time. I am still going to pull the tranny this weekend to check the clutch and if it turns out everything is ok then i will pull the motor but, probably not the same weekend. Since i still have to pull the bottom end a part to get the pistons / wrist pins out for inspection i am going to go a head and put some ACL bearing in there. If it turn out the pistons have some issues then the stockers will be going back in. P.S. Does any one know where i can go look at some diamond star racing wheels? EDIT: New videos http://tinypic.com/usermedia.p...3D%3D http://tinypic.com/usermedia.p...3D%3D
Modified by nelson8708 at 6:03 AM 8/4/2008
480sx
Angry Hippie
NOVA Va
11-12-2006
| « Re: (nelson8708) | 7:30 PM 7/29/2008 |
Thats good news, means your crank is most likely OK. Still a tear down which sucks but you had a great run out of that motor.BTW, OEM used pistons > ebay pistons any day of the week. Not trying to be an ***, i just cant believe you used ebay pistons over OEM. Really curious now to see if its a wrist pin thats failed/failing. Good info from your shop teacher about knock on the down rev knock. Hes right about the rod knock noise, if it was that, you would hear it all the time.
nelson8708
Sideways
12-14-2004
| « Re: (480sx) | 2:17 PM 7/30/2008 |
At the time new pistons sounded good and they had a ceramic coating. Once i boosted it i had wished i used stock ones since i know what they can take. I plan on putting the stockers back in if i have to pull the motor apart. What is your opinion on engine bearings?King bearings of ACL bearings
480sx
Angry Hippie
NOVA Va
11-12-2006
| « Re: (nelson8708) | 7:21 PM 7/30/2008 |
Either one is most likely going to be fine. I havnt done much research on king bearings either so i cant say one way or the other as far as they are concerned. If you want to go all out, go with either a calico coated bearing or a WPC treatment. All depends on how much you want to spend. WPC = the ish.I would just go with tried, true, and damn cheap. ACL, 45 shipped for rods/mains, done.
neverlift
brain fart
sunshinestate
4-24-2006
| « Re: (480sx) | 8:19 PM 7/30/2008 |
glad it isnt as bad as thought I run ebay pistons bro, @75 bux shipped I will eat them if I have to, honestly the quality was as good or better than a local parts shop rings were not the best... clevite main and rod bearing for 3x$ been reused once now....
nelson8708
Sideways
12-14-2004
| « Re: (neverlift) | 2:21 PM 7/31/2008 |
Well i'm not going to pull the crank if i can help it. I am going to pull the head and just take the #4 piston rod out first to see if thats it. If i can figure out what went wrong then i will do bearings. The ones that are in here only have 15K on them. The only thing i plan on buying now if it turns out to be the pistons is a new head gasket.
neverlift
brain fart
sunshinestate
4-24-2006
| « Re: (nelson8708) | 6:05 PM 7/31/2008 |
yeah I was thinking today I should have bought a copper gasket, I think I'll get one next time I open her up.... I'd pull the tranny, I experienced a strange noise I knew was my motor being pwnt, it turned ou to be 2 flywheel bolts backing out, and another time 2 pressure plate bolts..... thread lock ftl hell speaking of two's I believe my overheating is solved but now my slave cyl is dead and leaking fvckin nissan well tyten up and let us know
nelson8708
Sideways
12-14-2004
| « Re: (neverlift) | 4:17 AM 8/1/2008 |
You guys are really temping me to just pull the tranny now but, i already have half the stuff done i need to in order to pull the motor. I think i am just going to go ahead and pull it and if it turns out to be a clutch / flywheel related issue i will be happy to put it back in.If i cant get ahold of a cherry picker then i will pull the tranny though.
neverlift
brain fart
sunshinestate
4-24-2006
| « Re: (nelson8708) | 10:56 AM 8/1/2008 |
just pull the tranny with the motor and check out eveything goes back in much easier that way imho.
nissanfanatic
Gainesville Fl
11-1-2004
I wouldn't say your crank is necessarily "alright"...It could come out looking like this:
 You'll have to extract six of these little bitches if your flywheel shears off.
 If it is a clutch issue, you should be able to feel/hear a change when you depress the clutch. Or you can just wait until your car is immobile and the car sounds like a sport bike when the throttle is depressed.
WDRacing
USA
11-25-2002
| « Re: (nissanfanatic) | 10:22 AM 8/2/2008 |
| Quote, originally posted by nissanfanatic » | | I wouldn't say your crank is necessarily "alright"... It could come out looking like this:
 If it is a clutch issue, you should be able to feel/hear a change when you depress the clutch. Or you can just wait until your car is immobile and the car sounds like a sport bike when the throttle is depressed. |
FAIL
nissanfanatic
Gainesville Fl
11-1-2004
| « Re: (WDRacing) | 10:27 AM 8/2/2008 |
| Quote, originally posted by WDRacing » | FAIL |
Yea, I had a naughty word in the url. Censorship reflects a society's lack of confidence in itself.
WDRacing
USA
11-25-2002
| « Re: (nissanfanatic) | 10:28 AM 8/2/2008 |
Agreed
neverlift
brain fart
sunshinestate
4-24-2006
| « Re: (WDRacing) | 4:24 PM 8/2/2008 |
nelson8708
Sideways
12-14-2004
| « Re: (neverlift) | 7:21 PM 8/2/2008 |
I dont think i have the power to sheer off bolts but maybe because of having ot launch so high, one may have come loose. I dont know yet but, will find out tomorrow since i got a cherry picker today but, forgot to get a chain while i was there ....P.S. I also found out that one of my couplers had a decent size hole in it so i might have ran faster if it wasnt for that. I will have some pics of it and the motor being pulled tomorrow night.
nissanfanatic
Gainesville Fl
11-1-2004
| « Re: (nelson8708) | 6:26 AM 8/3/2008 |
| Quote, originally posted by nelson8708 » | I dont think i have the power to sheer off bolts but maybe because of having ot launch so high, one may have come loose. I dont know yet but, will find out tomorrow since i got a cherry picker today but, forgot to get a chain while i was there ....P.S. I also found out that one of my couplers had a decent size hole in it so i might have ran faster if it wasnt for that. I will have some pics of it and the motor being pulled tomorrow night. |
You don't necessarily shear off bolts from too much power. It is typically a clamping issue. Basically, bolts are supposed to operate in a single vector. All they are supposed to do is clamp two surfaces together, and the coefficient of friction, area and clamp load should dictate how much force can be applied. If the bolts back out, then you have a problem. A lot of things can come into play here. If any of the three are compromised, then you could have a failure. Three easy problems could be improperly torqued bolts (no lubricant on the threads, damaged threads), lubricant on the flywheel/crankshaft mating surface, or warped surfaces. Once one of them is compromised, it is a matter of time/frequency. The bolts could probably hold a constant 300ft/lbs of direct force. But alternating force will kill them quickly. This could be related to the theory of an impact wrench vs a breaker bar. Whether or not we feel it, our drivetrain undergoes the same stress that bolts/sockets/extensions undergo when being used with an impact gun. The engine simply exerts these forces at a much higher frequency. At 7000rpm, the entire driveline is seeing the resulting force in sine wave form at 233.3 Hz, and the amplitude can be described using cylinder pressure*area of the piston top. You could then use that force value times .1574803ft to see what torque is being made by each cylinder.
nelson8708
Sideways
12-14-2004
| « Re: (nissanfanatic) | 5:18 PM 8/3/2008 |
| Quote, originally posted by nissanfanatic » | You don't necessarily shear off bolts from too much power. It is typically a clamping issue. Basically, bolts are supposed to operate in a single vector. All they are supposed to do is clamp two surfaces together, and the coefficient of friction, area and clamp load should dictate how much force can be applied. If the bolts back out, then you have a problem. A lot of things can come into play here. If any of the three are compromised, then you could have a failure. Three easy problems could be improperly torqued bolts (no lubricant on the threads, damaged threads), lubricant on the flywheel/crankshaft mating surface, or warped surfaces. Once one of them is compromised, it is a matter of time/frequency. The bolts could probably hold a constant 300ft/lbs of direct force. But alternating force will kill them quickly. This could be related to the theory of an impact wrench vs a breaker bar. Whether or not we feel it, our drivetrain undergoes the same stress that bolts/sockets/extensions undergo when being used with an impact gun. The engine simply exerts these forces at a much higher frequency. At 7000rpm, the entire driveline is seeing the resulting force in sine wave form at 233.3 Hz, and the amplitude can be described using cylinder pressure*area of the piston top. You could then use that force value times .1574803ft to see what torque is being made by each cylinder. |
Most of that is way over my head but, i get the just of it and i know that clamping force is what holds it together. I got the engine out and its not the clutch or flywheel. I was susprised to see that the flywheel on has two hot spots on it. I figured that it would be a little more burnt since i had a slipping issue last year with it but, it held up great at the track. So its defintally internal and i suspect it to be the piston / wrist pin. I have to get one of my buddies over here to take my other engine out of my stand that is in the barn so i can use it on the one in the garage. I want to start tearing it apart tonight so i can see what i need to order so i will be ready to reassemble next weekend. I will try to get a few pics up tonight.
neverlift
brain fart
sunshinestate
4-24-2006
| « Re: (nelson8708) | 6:50 PM 8/3/2008 |
damn I had hoped it to be the clutch/flywheel for ya!
nelson8708
Sideways
12-14-2004
| « Re: (neverlift) | 11:16 PM 8/3/2008 |
| Quote, originally posted by neverlift » | damn I had hoped it to be the clutch/flywheel for ya!
yeah me also but, atleast i pulled the motor instead of the tranny to check. I drained the oil and the magnetic drain plug looked like it did on the first oil change when i was breaking it in. I pulled as much as i could apart to night and got it in my engine stand but, i dont have a puller so i couldn't pull the crank pulley off so i had to stop there. I screwed up the crank pulley when i tried to use a pry bar and hammer on it ...but, its no big deal. I will just get the pulley off the short block i got a couple weeks ago. Tomorrow my goal is to have the the entire engine apart so i can see what i need to order. I got my stock pistons out of my barn so they are going back in. I am going to use the rings off the pistons that are in there and give the block a light hone so they can re-seat. I believe you did that a while ago cory and didnt have any problems with blow-by because of it. Also, do you guys think it would be ok to delete the coolant lines going to the upper part of the intake manifold? I want to delete them for a cleaner look. Do you see any problems with this? I know its common for people to cut the throttle body out of the loop but, i haven't seen it done with the intake manifold. Does the coolant heat up the intake manifold to engine temp or does it keep it cooler than if i was to not run the coolant line?
nelson8708
Sideways
12-14-2004
| « Re: (nelson8708) | 2:55 AM 8/4/2008 |
WTFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF!!!!!!!!!!!!!!!!!!!!!! I couldn't sleep anyway so i decided to pull the rest of it apart. I dont see anything that would cause the knocking sound it made. You guys did watch the vids right? I'm not hearing $hit and I? The rod bearings look fine. Better than the main bearings do. Do the shinny spot on the main bearing mean the crank and bearing came into contact? The crank is fine. No scratches or anything on it. You can drag your finger nail across it and it is smooth. Everything was tight when i pulled it a part. The only thing i see is that the side of one of the rods looks like it came into contact with some thing. I checked the block and there is nothing else it could have touched. It might have been like that when i rebuilt it the first time.....i dont remember. At this point i dont know what to do. Do i just put new bearing in it and see what happens? The small little pieces of metal that was on the magnetic drain plug had to come from some where.
480sx
Angry Hippie
NOVA Va
11-12-2006
| « Re: (nelson8708) | 8:30 AM 8/4/2008 |
I wouldnt replace the bearings if they are in good shape. No reason to, and new bearings will put wear on the crank for the first few runs.You sure that the wrist pins are O.K? Still floating in the groove? What about your timing chain/tensioners?' How do your cylinder walls look? Check your rod bolts to make sure they havnt stretched. How big were the metal shavings? Was it powdered metal or little chunks? IDK i dont like the idea of putting it all back together without figuring out what was the cause of that noise/metal.
nelson8708
Sideways
12-14-2004
| « Re: (480sx) | 2:54 PM 8/4/2008 |
| Quote, originally posted by 480sx » | | I wouldnt replace the bearings if they are in good shape. No reason to, and new bearings will put wear on the crank for the first few runs. You sure that the wrist pins are O.K? Still floating in the groove? What about your timing chain/tensioners?' How do your cylinder walls look? Check your rod bolts to make sure they havnt stretched. How big were the metal shavings? Was it powdered metal or little chunks? IDK i dont like the idea of putting it all back together without figuring out what was the cause of that noise/metal. |
Yeah all the wrist pins and still floating and none have excessive play as far as i can tell but, the stock pistons are still going back in with a light hone. The timing chain and tensioners look fine. I havent got a close look at the cylinder walls yet but, i will today. If the rod bolts had stretched then that particular rod nut would be looser than the others when i pulled it apart but, i have a caliper so i can compare them real quick. The metal shavings were more powder than anything. When i wiped off the magnet is just looked like black grease. There were a few tiny slivers but, nothing bigger than the normal engine break in size. Yeah believe me i dont want to put it back together and have the same problem agian....that would be terms to sell the car and buy another honda. ....i was actually thinking a rx7 FC since i dont think that will become a bandwagon car because people are scared of what they dont know and that is rotory power.
nelson8708
Sideways
12-14-2004
| « Re: (nelson8708) | 5:00 PM 8/4/2008 |
Here are some more pics that make it easier to see the bearings and crank. Everything looks good. The cylinder walls and i looked very closely at the pistons and there is nothing wrong with them. There is not enough play between the rod and piston to cause that noise but, i guess when it warms up the play would be increased. You can slide the rod on the wrist pin very easily but there is no actual play. I figure since it moves this easily when cold that i could make the noise when its at running temp. It sucks that i pulled his apart and found nothing wrong.....yet. Like i said the material on the magnet had to come from some where. It wasn't and whole lot of material....just more than usual. I am going to dissasmble the rod and piston and see if i can find anything wrong.
480sx
Angry Hippie
1991 White/Black s13 1 |
