Taylor008
90 240 coupe
SL UT
2-15-2008
Wow. I don't know what to say except congrats on the purchase?
MellowS13
1990 Nissan 240sx, 1992 Acura Integra
Long Beach CA
2-16-2008
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (kornmanz) | 8:22 PM 7/18/2008 |
sorry to hear that but
I'm the last ninja on my block!
danielekfuj
veni vidi vici
1998 Hoonda AV6 coupe, ariel atom
szikago IL
12-28-2006
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (kornmanz) | 8:25 PM 7/18/2008 |
hah got that last part right. did the dude do the swap in his garage?
Most of our projects focus on taking apart a perfectly good car and screwing it up. At least that's what the masses would think. In personalizing, customizing, and focusing our cars on performance above all else, we inevitably upset the delicate balance of ride and handling, horsepower and fuel economy, and perhaps even styling and anonymity that the OEM spent so many billions of dollars to achieve. Whatever, we think they're better.
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (danielekfuj) | 8:32 PM 7/18/2008 |
| Quote, originally posted by danielekfuj » | | hah got that last part right. did the dude do the swap in his garage? |
yeah I think so. Pictures to come soon. I am just happy to get a 240 finally but god it was horrible...
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (kornmanz) | 8:38 PM 7/18/2008 |
In my garage
 Yes thats my exhaust in the trunk
AZ89two4Tsx
Online
89 sil40
Ghetto Capital Scottsdale Arizona
3-8-2008
What's with the hood?
 89 sil40- JIC coils, custom exhaust, fg hood, silvia front Soon to come- KA-T, paint, wheels, interior work, the list goes on..... http://www.myspace.com/christian0258 add me!
5zigen
1997 Q45
Fremont California
4-20-2005
| « Re: (AZ89two4Tsx) | 8:52 PM 7/18/2008 |
At least the engine bay looks good.
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: (5zigen) | 9:16 PM 7/18/2008 |
| Quote, originally posted by 5zigen » | | At least the engine bay looks good. |
yeah, but doesnt run now. It ran so good when we were driving too.. The orig. owner is helping me every way he can. DO NOT construe my post and think that I made this to bash him. I did not. I just wanted to post one hell of an adventure that I had in the last 2 days to get my 240. I am happy its in my garage, running or not. I hated my honda.
Modified by kornmanz at 9:36 PM 7/18/2008
anti_flag_army
88' RX-7 GTU
Lincoln CA
11-7-2006
how much if you dont mind my asking...
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: (anti_flag_army) | 10:30 PM 7/18/2008 |
A 2006 ZX 14 and 1.6k cash. He'll be paying for the work it took to get me home. Mod list:
Greddy titanium valve springs crower titanium valve set crower 272 cam set (also getting a 264 duration cam) phase 2 motorsports rocker arm stoppers pro-machine acid treated head pro-machine multi angle valve job pro-machine ported and polished ports ARP head bolts and studs HKS 1.04mm multilayer metal head gasket brian crower bronze valve guides OEM valve seals (new) OEM timing chain tension-er (new) 5 Ziegen Oil cap Nismo rod bearings NIsmo main bearings Nismo thrust bearings Eagle h-beam rods OEM pistons (new) OEM rings (new) OEM oil pan (new. Got replaced because other one was dented) Greddy blow-by canister ARP rod bolts Greddy aluminum pulley set greddy oil filter sandwitch plate Aeromotive tsunami fuel pump aeromotive 100 micron inline fuel filter aeromotive fuel pressure regulator aeromitve fuel pressure gauge greddy fuel pressure fittings BGRG custom high pressure fuel lines with 6AN fittings Apexi SAFC 2 fuel controller Z32 Mass air flow sensor Nismo thermostat Samco braided radiator hoses greddy radiator cap koyo polished aluminum radiator 12" electric fan (2) Phase 2 motorsports aluminum coolant tank B-road carbon fiber air diversion plate AEM air filter Greddy t25 turbine Greddy turbo timer Kei-offic manual boost controller BGRG steel braided oil return line HKS equal length exhuast manifold Heat solutions exhaust heat wrap JDM lab aluminum intercooler JDM lab intercooler piping Blitz BOV Blitz BOV fitting Apexi Downpipe Apexi dual N1 Exhaust system OEM o2 sensor (new) Nismo Performance clutch Nismo throw out bearing Nismo clutch cylinder Phase 2 motorsports steel braided clutch line Tomei short shifter Z32TT dual piston front calipers 2 Z32TT brembo rotors 2 240sx brembo rotors (rear) 2 phase 2 motorpsorts steel braided brake lines 4 tokiko performance shocks 4 tein s performance springs FR and RR began racing strut tower braces Black carpet Letherette covered glove box Letherette covered door panel inserts Nismo steering wheel Nardi detatchable steering hub corbeau forza 2 racing seat corbeau 240sx seat rail nismo harness pro sport digital gauges (boost oil press and oil temp) GTS passanger seat kenwood cd head unit polk audio speakers in all slots sound restraining and rust proff rubberized coating under carpet Origin lab body kit custom headlight cover intake red/white tail lamps shaved antenna shaved rear wiper engine bay painted single stage black..
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
A caliper hanging? You just suck at inspection.As for the turbo, I recommend using super glue next time you attach it to the manifold. Although, personally I would use QuikSteel.
For SALE: 2003 SE-R Spec V 6 Speed Manual with LSD Brakes =$150. Running Strong. 1991 - S13 Coupe KYB AGX + Eibach ProLine $475, Strut Mount $160, ClutchKit $150, ExhaustSet $300, WaterPump $50, Radiator $99, FanCluth $45, Clutch Master $30, Brake Kit $310, Chassis $150, Anti-Theft $XXX, Audio $250, Celica Seats $200, Alternator $115, Starter $130, NISMO Wheels, Stillen Strut Bar, RedCoupe Shell $1,500 NEXT>>Bushing, LSDStatus - Running Strong. 1992 S13 SE Coupe Being taken apart for VQ Swap VQ30DE $320, ECU $50, Harness $100, MAFS $50, Intake Manifold $99, Z33 6-Spd $380, Poly Mounts $125, Z33 Oil Pan $121 For Sale : FL, S13 Radiator, KA24DE, Automatic, ECU, Starter, EGR, FAN, Alternator, etc NEW LOW PRICES
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: (Soravia) | 11:35 PM 7/18/2008 |
It wasnt hanging when I first got it. It fell off while driving.
Soravia
Jacksonville FL
11-18-2005
Then someone sucks at torque down on bolts.I knew one guy who had brake pads fell off his Accord. But he's a trakker nerd so that's to be expected. My engine bay just got painted black too. Not too pretty on closeup. There are tiny bumps that needs to be sanded.
Nismo_Freak
89 240SX
Austin Tx
7-25-2002
| « Re: (Soravia) | 12:04 AM 7/19/2008 |
| Quote, originally posted by Soravia » | | Then someone sucks at torque down on bolts. |
No, it's a common problem on bottom mounted SR's. All the backpressure in the exhaust manifold, heat, and vibration cause the bolts to work loose. That is why the OEM turbo has lock plates on the bolts. If the car died like that then you need to check the fuel pump, ECU, or MAF.
1995 BMW M3 http://www.texasguntalk.com - Forum for Texas Gun Owners
Nissan240sx_s13
1990 Nissan 240sx
Albuquerque New Mexico
7-9-2007
| « Re: (Nismo_Freak) | 2:47 AM 7/19/2008 |
Hey man need any help send me a e-mail I really wana see it!
PSN: Skateforfood
NSR_s30
Drive to live, live to drive
'99 Ford F250 7.3L Diesel, '87 Chrysler Conquest TSi, '71 Datsun 240Z
Somewhere in OH
10-8-2004
| « Re: (Nissan240sx_s13) | 5:17 PM 7/19/2008 |
Wow what a bummer of trip man, luckily enough you got it back. Getting it to run is only a minor setback for otherwise a clean car. Good luck.
- Josh ForSale: 1987 Chrysler Conquest TSi http://forums.nicoclub.com/zerothread/356505
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: (NSR_s30) | 5:41 PM 7/19/2008 |
Yeah it was clean. Towing it ripped the **** out of my front origin bumper. 488 bucks to replace....sweet! Oh well though, I am gonna just get it checked out by a shop in the next few days.
Once its up n runnin I'll let ya'll know
srpowered240sx
Shocker Style
90 240sx-sr, 92 F-150, 96 integra gsr
humboldt county ca
6-29-2005
damn, crazy trip. at least its home, the seller really didnt put that car together correctly though.
  When did I realize I was God? Well, I was praying and suddenly realized I was talking to myself. NICO photo contest crew..........three, count em, three times Proud Creator of WBDM2TTWFOC: Cuz selling is for pussies!!
dickie
Articles Manager
Killer Turtle
AtTheDriveIn TX
9-6-2005
| « Re: (srpowered240sx) | 9:24 AM 7/21/2008 |
| Quote, originally posted by srpowered240sx » | | damn, crazy trip. at least its home, the seller really didnt put that car together correctly though. |
you got royally ****ed. only thing you can do is hope that whatever "rebuild" was done on the car prior to your purchase was done by someone other than whoever worked on the rest of the car. i will NEVER buy a car that has been built by someone else. EVER.
dickie store!KA24DE Fuel Rail and Z32 Fuel Filter Chuki Bumper Grilles 3 mudflaps from S13 coupe
ca18detgabby
92 s13 ca18det
lake mary fl
2-10-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (danielekfuj) | 9:58 AM 7/23/2008 |
| Quote, originally posted by danielekfuj » | hah got that last part right. did the dude do the swap in his garage? |
whats wrong with doing a swap in the garage? mine seems to be holding up well that thing looks haggered as hell. engine looks clean, but pretty does not = quality.
 | Quote, originally posted by r34 gtr » | | Who gets rid of their CA's? People who suck, thats who. |
MastaYu
Online
92 240SX HB SE
MD
10-3-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (ca18detgabby) | 10:29 AM 7/23/2008 |
epic adventure
Shift_up My S13 Ressurection/Rebuild
srpowered240sx
Shocker Style
humboldt county ca
6-29-2005
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (danielekfuj) | 10:34 AM 7/23/2008 |
ive done lots of swaps and stuff in my garage, nothing wrong with that, its the mechanic in the garage, not the garage itself that does the work.
fukin240
1996 S14(Gone), 1992 Hatch w/ 96' motor
Dublin Ga
3-4-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (srpowered240sx) | 10:43 AM 7/23/2008 |
Man just be thankful you got that damn thing OUT of Kentucky and it even made it that far after the first break down!
sebazztard
1995 nissan 240sx, 1992 subaru legacy
massena ny
3-2-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (fukin240) | 11:23 AM 7/23/2008 |
good story, at least its a hatch.
PhopsonNY
New York
10-26-2003
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (kornmanz) | 11:33 AM 7/23/2008 |
wow, I feel so bad for you...What it had to be like waiting on the side of the road for 5 hours... That's how some of those horror movies start. Congrats on getting it home eventually
Above soul...
EnjoiNismo
93' 240sx coupe
Tucson AZ
7-24-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (PhopsonNY) | 1:23 PM 7/23/2008 |
holy ****, well glad you guys made it home.Yeah engine bay looked clean. No one ever pulls over on the highway to help anyone out anymore, probably thinking of getting raped O_O
srpowered240sx
Shocker Style
humboldt county ca
6-29-2005
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (PhopsonNY) | 2:54 PM 7/23/2008 |
| Quote, originally posted by PhopsonNY » | What it had to be like waiting on the side of the road for 5 hours... That's how some of those horror movies start. |
yeah, but ive seen a lot of pornos that start off like that too.
joesomebody06
1996 240 sx s14 ka24de-t
Waco tx
6-5-2008
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (srpowered240sx) | 3:13 PM 7/23/2008 |
lmfao rofl!!! man that was flipping hilarious
1996 Zenki S14 Ka24DE-T, Remote Operated Suicide Doors, 18" ICW Racing Rims, 5 spd. M/T, FMIC & BOV, MSD Ignition, Boost Retard Dial, Custom (3) Gauge Pod In Dash, SAFC II, T3 Hybrid, KYB GR-2 Gas Struts On All Corners, Megan Racing Rear Suspension Pieces, All I Need Now Is A Cheap Paint Job!!!!! All Bow Down To Project Slidewayz08  http://www.cardomain.com/ride/3093988
ashibah83
Online
93 SUPA BLACK COUPE
St. Marys pretty much Jax, Fla Ga
10-14-2006
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (srpowered240sx) | 3:30 PM 7/23/2008 |
| Quote, originally posted by srpowered240sx » | yeah, but ive seen a lot of pornos that start off like that too. |
wow...someone BESIDES me remembers that movie......Detroit Rock City FTW!!!! oh, and great adventure, i hope the car is worth it to ya
kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
| « Re: So kornmanz finally got his 240sx, it was the drive fr ... (ashibah83) | 3:33 PM 7/23/2008 |
oh yeah its worth it to me. Sure it has a few little things to be done, but when its done, its going to be legit. Paint will be on in like 3 weeks. Gives me some time to find a new bumper.
