 GA16DE
Ea898
99 Nissan Sentra All Motor
NorthSide N.J
7-18-2008
  GA16DE
can anyone tell me if i can turbo a GA16DE. If So From What Intake Manifold And What Turbo?
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
and....here's the sentra forum!
Like the phoenix....we shall rise! and obliterate your darkest hour!
ETA...2 months maybe? I'm kinda lazy....
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
You can turbo anything. It hasn't been done much, though, as the GA isn't a popular engine to mod.
Intake manifold doesn't have much to do with turbocharging.
You can use whatever turbo you like. I'd stick to something fairly small like a T25 or T3 unless you do some significant internal work.
Take a look around the forum, we've had a member do it.
However, most people find it easier to swap in an SR20DET and go from there.
Welcome to NICO!
The DD - '01 Sentra SE (RR SR20DE) w/pp (VLSD, FSTB), a few mods
Get your Nissan/Infiniti's FSM FREE here.
Need parts? Look here!
500dolla
1993 G20 Infiniti
Chelmsford MA
3-5-2007
 « Re: GA16DE (Ea898)
Take it easy man, do a little research before you want to put a turbo on a small and very unpopular nissan engine. Try some bolt ons before you go right for the turbo. It's going to cost a lot if you try to make that 1.6 a sleeper.
BeyondBiscuits2
1990 Nissan Sentra XE B12 w/h 1999 GA16DE & T25 turbo
Clarksville TN
8-10-2006
 « Re: GA16DE (500dolla)
Quote, originally posted by 500dolla »
Are you daft or just ignorant? Unpopular Nissan engine??? The GA16DE was the Nissan workhorse from 1991-1998, and is still in production today! Not to mention the engine came in the Nissan Sentra, Sunny, Primera, Almera, Pulsar, 200SX, Presea, and NX! Clearly you know nothing about Nissans if you think the GA16DE isn't even worth modifying.
Now, from someone who actually knows about the GA16DE. Turboing the engine is a good choice... it loves boost and can handle upwards of 250whp on stock internals. Changing out the intake manifold is unnecessary, and frankly, there isn't any aftermarket intake manifolds for the engine that I know of... though RallyBob is custom fabricating one from his N/A car. Hotshot made a turbo kit for the GA, but since they have gone out of business, you can only buy it used off someone or from eBay. Your best bet (but most expensive) is the buy the TSI turbo kit, which can be found here:
http://www.prostreetonline.com/pnsku/ns2001x.asp
Many GA16DE owners have bought this kit, including blownb310 (in a B12 Sentra wagon 4wd of all things), and say it is more than satisfactory. I find it rather disheartening that it comes with a T20 turbo (not very powerful but quick spool) and only a rising rate fuel pressure regulator as a fuel controller. I am pretty sure they expect you to use your stock fuel pump, which means very little to no actually change in your fuel system. Fortunately, the turbo manifold comes with a T2 flange, which means you can use T2, T20, T25, and T28 turbo variants. I believe Wes and Mike Kojima, who lead the turbo Sentra GA16DE research, both run the "disco potato" T28 on their GAs. If you do buy the kit, I suggest also getting an A'pexi S-AFC 2 to be safe.
Another option is to do what I did. I bought the TSI turbo manifold on eBay for a steal ($150 compared to wanted $399), and expanded the exhaust ports on the manifold as compared to the cylinder head to ensure no exhaust manifold gasket blow-outs. I got a T25g turbo off a friend for free; he builds KA24DE(T) engines all the time for local GIs looking to boost their 240SXs, and had one laying around his garage with some shaft play... so I volunteered to take it off his hands since he didn't want to rebuild it. I also purchased an A'pexi S-AFC 2, a N60 Maxima MAF sensor, a blow-off valve, 259cc injectors, Walbro 255lph fuel pump, and miscellaneous piping. Altogether, everything cost me about $500 as compared to the $2000+ the kit would cost. It doesn't look as pretty, but it gets the job done at 8lbs of boost. All this is in an old B12 Sentra... and the car hauls ***. Nothing like boosting in 5th gear on the motorway while just tapping the accelerator .
All in all, the GA16DE is a good turbo platform. It doesn't have the displacement of some engines, but it is nonetheless a potent engine. Jim Wolf Technology makes reprogrammed ECUs and turbo camshafts, and CalumSult also has a B13 OBDI ECU reprogrammed for sale. While the S-AFC 2 can't compensate for the 370cc injectors without an ECU reprogramme (I tried... flooded out the engine even at -50% across the board), the 259cc injectors can handle up to about 12lbs of boost on a T25, which is more than enough! I tried it once, and let me say... scared the crap out of me...
Modified by BeyondBiscuits2 at 12:16 PM 7/20/2008
Nissan B12 Sentra; rusted, busted, used, but trusted.
500dolla
1993 G20 Infiniti
Chelmsford MA
3-5-2007
 « Re: GA16DE (BeyondBiscuits2)
I may be a little daft. But I was saying unpopular as in tuning not as in vehichle applications. I know there is an aftermarket for it, but its just not as big. I honestly didn't know that could run a turbo at 12psi safely, and cheaply.
I'm sorry, my bad
crams_A_problem
Queens village new york
3-9-2007
GA16DE ftw!
i saw a turbo GA once at a car meet. he had a lot of internal work tho T3 T4 and had a sleeved bottem end. car was beautiful but he wouldnt tell me any numbers (horse power/torque wise)
BeyondBiscuits2
Clarksville TN
8-10-2006
Here is mine on film:
http://www.youtube.com/watch?v=uuhqdu8C0rc
(first video is crap...)
http://www.youtube.com/watch?v=WUhM77bZ0ik
If you have a Youtube account... please subscribe!
» Return to Sentra Forum / Infiniti G20 Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
