 Need help on pulling an engine.
kingkilburn
'93 240SX
Fresno CA
11-19-2007
I'm going to be pulling a motor tomorrow. While I am mechanically inclined I tend to get a head of myself with these types of things. What would you guys suggest I take out with the motor knowing its going in an S13? I plan to get as much as possible(half off day at pick-n-pull) all at once.
craigztoyz
90 300ZX VH45 95 J30 90 rx7 lots of cars older then me.
Austin TX
1-18-2008
 « Re: Need help on pulling an engine. (kingkilburn)
Search, this was discussed a month or tow ago.
Eng, its wiring harness, and a foot of wire after the connectors if you can, all the accessories, maf, intake pipe to maf, hoses, belts, everything you can grab that is attatched, mounts, with the rubber isolators if good(easy to make solid) computer, fuel pump is a good thing too, VIN #, and any history you can find in car, to chase down its maintance records. PULL A VALVE COVER OFF< If there is sludge in engine, don't get it.
kingkilburn
'93 240SX
Fresno CA
11-19-2007
For 60 bucks I'll take what ever I get. At the very least it will be a dummy block for mock up.
craigztoyz
Austin TX
1-18-2008
 « Re: (kingkilburn)
60 wow, that is cheap, yeah, take all you can get, and at least it is parts for the build and if needed, mockup parts. Good find, what year?
kingkilburn
'93 240SX
Fresno CA
11-19-2007
 « Re: (craigztoyz)
Ya its 50% off day at a local yard and they have a flat rate type of pricing. All engines are 120(every day price) so I was ready to get it at that price.
The year I don't know but it is a first gen Q45.
I know a guy who owns a machine shop so it wont be to bad to rebuild. He decked my KA head as well as redoing the valve shims for free.
kingkilburn
'93 240SX
Fresno CA
11-19-2007
 « Re: (kingkilburn)
Well I got my engine home. It took me about 6 hours if you remove the break time. I'll post pics in a couple of hours.
edit
I know this sounds stupid but how do you get the torque converter off? I have never dealt with an auto trans before so I am way in the dark.
Modified by kingkilburn at 6:47 PM 7/18/2008
Chrispy300
1990 J-Spec NA 300ZX 5 Speed Targa
Brisbane QLD, AUS
1-28-2008
 « Re: (kingkilburn)
$120 is the normal price I paid $1500 for my VH and that's a bargain over here
450ZX In The Works
Cheers,
Chris
craigztoyz
Austin TX
1-18-2008
 « Re: (kingkilburn)
The converter is a P.I.T.A. the first time. You hav to pull starter, and go through that hole with a socket and extension, Vise Grips on ringgear, and it should work out, Be sure to pull the front covers and get a good look at its tensioners, and sludge check. What year?
Wait till you try the cam bearing caps. worst ones I have ever dealt with. Must be cleaned first, and then hammer a (high quality) bit in there, forgot the size, but you will probably use a few bits to get them loosened.
kingkilburn
'93 240SX
Fresno CA
11-19-2007
 « Re: (craigztoyz)
I'm not sure on the year. I forgot to check the vin. Can you tell from the ecu?
npez
1993 Nissan 300ZX Turbo (soon 2B twin-turbo 450ZX) 2002 BMW M3 2008 Honda Odyssey Touring (Mama)
Houston TX
8-30-2007
 « Re: (kingkilburn)
Quote, originally posted by kingkilburn »
The prod date is stamped on the engine. I believe you can see it (my motor is in the engine bay at the moment) when you look at the shiny part of the block at 12 o clock above the flexplate - you'll also see the engine code (VH45DE) stamped there as well.
Nick.
1993 300ZX Twin-Turbo soon to be 450ZX Twin-Turbo (Oxford Gray)
2002 BMW M3 (Imola Red)
2008 Honda Odyssey Touring (Hey the kids have to ride somewhere!)
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
 « Re: (Chrispy300)
Quote, originally posted by Chrispy300 »
WOW!!! You can buy a nice Q45 for less than $1000 here! I never really appreciated the cheap cost of the engine until you hear what others are paying. VHs here in the US seem to be sold at about the price of the material they're made of.
nissandoms47
96 Nissan Pathfinder, AC Lift, Custom Spacer, KYB struts, Pro Comp Es9000s shocks, Warn hubs, 32 Bfg
Alpine UT
1-1-2007
 « Re: (tmorgan4)
You can get to the torque converter bolts through the access space right under the oil pan. No need to remove the starter.
craigztoyz
Austin TX
1-18-2008
 « Re: (nissandoms47)
But to use the plate in a adapter sheid way, then you have to, the sheild goes around the starter hole, so it can't be removed. Or at least that is what I remember of doing it.
SuperHatch
07 Tundra, VH Powered S14, 92 Slicktop Z32
Manahawkin NJ
11-17-2006
Quote, originally posted by nissandoms47 »
Ditto, that's how I did it on the 4 Q45's I've pulled motors out of, and that's how it's done in the FSM.
- Stephen
http://www.godspeed-racing.com
thejapino
'94 Q45
Bay Area CA
1-9-2004
 « Re: (SuperHatch)
$60, good find. Thats a GREAT way to start a vh swap project!
There are always a couple of G50's in the yard near my house but you have to wonder about the condition of the motors when the bodies are clean and wreck-free (how did it end up in the junkyard???).
Hopefully the motor isn't trash but for $60 and pnp's 90 day exchange policy, you can't really complain.
kingkilburn
'93 240SX
Fresno CA
11-19-2007
 « Re: (thejapino)
It is a serious ***** getting those bolts out with the ring gear moving the whole time. If I had known I would have taken them off while it was still in the car.
I've had this stupid rental cherry picker for going on three days know because I haven't had time to get the converter off so I can get the motor on the stand. I could have just bought the damn thing.
Edit
I have also noticed that the oil filter tree is broken. Not having seen one before I didn't realize until I really got looking.
At least it was only $60
npez
Houston TX
8-30-2007
 « Re: (npez)
Quote, originally posted by npez »
Nick.
Correction the prod date is stamped on the rear main seal cover - you'll need to take your flexplate out to see it. I just popped my flywheel off and saw mine again.
Thanks,
Nick.
craigztoyz
Austin TX
1-18-2008
 « Re: (kingkilburn)
Edit
Thats why I do it through the starter hole, the tension of the rachet's extension on the housing allows it to not rotate.
Nick, pulled flywheel again?
npez
Houston TX
8-30-2007
 « Re: (craigztoyz)
Quote, originally posted by craigztoyz »
Yep - The motor won't clear the engine stand with the flywheel on. I was taking the pan off to send that and the turbo housings to High Performance Coatings for the hipercoat extreme treatment. When the manis are done, they're going as well.....
Thanks,
Nick.
npez
Houston TX
8-30-2007
 « Re: (npez)
Nick.
Thanks,
Nick.
» Return to VH45DE / VK45DE Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
