i am piecing my turbo kit together and i'm trying to find the easiest oil line fix. i started to order the jgs kit but it doesnt say anything about how the feed line works. if its the sand which style or the kind you have to screw into your oil sending unit or what? what other options are you guys running?
i used a sandwich plate from ebay the o ring is poo and leaks oil.. which sucks.. oil lines tho i got made at a local rubber and gasket place.. coolant and oil lines ran me about 90 bucks with fitting and everything .. and everything is stainless steel braided except for the oil return.. so it looks pretty good for a decent price..
