neverlift
brain fart
PIGNOSE #19 turbo piggy
sunshinestate
4-24-2006
| « Re: need help on built ka! (kazuma) | 7:40 PM 7/15/2008 |
hope its the pan, I'd try retightening the pan bolts IF a gasket was used... as for the crank that sounds like the problem, my front was brand new(wasnt OEM ) and it leaked only when the motor was running I know my crank had a bad groove, somehow it sealed for me
PIGNOSE SQUAD MEMBER # 19
 ---------------------------------- r.i.p. Lee 09/01/89~09/28/06
kazuma
winnipeg MB
11-27-2004
| « Re: need help on built ka! (neverlift) | 9:01 PM 7/15/2008 |
| Quote, originally posted by neverlift » | | hope its the pan, I'd try retightening the pan bolts IF a gasket was used... as for the crank that sounds like the problem, my front was brand new(wasnt OEM ) and it leaked only when the motor was running I know my crank had a bad groove, somehow it sealed for me |
I did use a gasket, maybe I"ll try to tighten it down and see what happens. but I agree its gonna be my main seal , and I thought I was done.
lrb_2000
'91 SE s13 Hatch, '95 SE s14
ID
5-3-2005
That could be it then. The only time I used a gasket on my oil pan, it leaked bad. I would try tightening it a little, if that doesn't work, take it off, scrape it clean and use RTV silicone to seal it. No gasket is needed for the oil pan.
kazuma
winnipeg MB
11-27-2004
| « Re: (lrb_2000) | 7:03 AM 7/16/2008 |
Thanks for the replies, I'll try to tighten it down after work today and hopefully that works!the one thing I did notice though that I forgot to mention was is the oil was not hot or anything even though the car was at operating temps which makes no sense to me.
kazuma
winnipeg MB
11-27-2004
| « Re: (kazuma) | 5:47 PM 7/16/2008 |
So I tightened the oil pan and more than 80% of the leak stopped, bfore it was dropping 10 drops a min now its more like 2-3. Could it be just a oil pan or do you guys still think its the rear seal?
480sx
Angry Hippie
1991 White/Black s13 1996 Pearl White 240sx
NOVA Va
11-12-2006
| « Re: (kazuma) | 5:53 PM 7/16/2008 |
Hard to say man. I would get it on jackstands, get it running, and try to get under there with a flashlight and see if you can find where its leaking from.
'I have never known anyone who picketed anything successfully. "Damn there are people outside with signs, maybe im wrong"' Brand new Borg Warner S258, AKA The Better Than a GT-R Turbo( )---> http://forums.nicoclub.com/zerothread?id=354932
jeff420
92 240sx, 86 crx, 96 grand am, 79 trans am, 03 dakota
Royse City tx
5-2-2007
| « Re: (480sx) | 3:24 AM 7/17/2008 |
if its the rear main seal it should sling oil everywhere and make your clutch slip. thats what my civic did
92 240sx hatch with silvia front. built ka coming soon
