18x10 +22 S14?
Zetec
I have found a set of wheels I like and the lowest offset is +22. Is anyone running a set up similar to this? Can I run these in the rear without rolling the fender? Any help is appreciated.
ashibah83
Car: 93 SUPA BLACK COUPE
your probably gonna need a roll, pull, depending on how low you are...maybe spacers to clear the frontsomeone correct me
Darius
Just don't lower your car as much. You won't fit a 10 +22 under the fender unless you pull it about 1".
Here's my setup:
koukicody
Car: 93 Mazda Miata
zer...age=2
6th post down by Kornaz. he has 18x10 +24 in the rear. really close to what your looking for.
Zetec
The whole plan is to run 18x9 +24 255/35 in the front and 18x10 +22 275/35 in the rear, So if I were to get 20mm over fenders up front and 30mm over fenders in the rear I should not have any rubbing issues is that right?
Darius
Those wheel specs are exactly what I have. Unless you're planning on slamming the car and tucking the wheels, don't waste your time with overfenders. You can make it look good with a roll and slight pull on both the front and rear fenders.
