 Spark blowout below 4k
articzap
1990 Nissan 240SX - CA Swap
Depew NY
3-18-2008
  Spark blowout below 4k (Solved)
I'm getting spark blowout below 4k well in boost, ~3 psi roughly or more. I had my plugs gapped at 1.1 mm and have since changed them .8 mm. It still does not help any. My butterflies are hooked up and working properly. Above 4k, the car pulls like a raped date with no issues at all. I'm confused as to what it might be. I think theres a possibility it could be the igniter. Is there any way to test to see if thats my weak link? Any one else have any other ideas?
NGK coppers with 7 heat range.
Modified by articzap at 4:17 PM 7/21/2008
240 Hotness
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
You can check the contiunuity between pins on the ignitor, the fsm has the process in the ef & ec pages.
Is it definatley spark blowing out?
What on earth possessed him to build such a creation?
articzap
Depew NY
3-18-2008
 « Re: (meminto)
It feels exactly like spark blow out, but I can't be sure. I doubt it fuel cut since I can drive it fine above 4k. I'm at a loss for words right now. I just want to get this issue fixed so I can crank the boost some.
slo
S13
Atlanta Ga
10-31-2007
 « Re: (articzap)
Maybe be a maf issue? Which maf are you using?
articzap
Depew NY
3-18-2008
 « Re: (slo)
SOHC KA MAF right now but I also have a MAF from a B13 Sentra SR20DE.
Even so it was fuel cutting it'd continue to do it above 4k. Thats the weird part. Its only down low.
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
It seems strange that spark is blowing out in the lower rev range.. I will have a think about it..
articzap
Depew NY
3-18-2008
 « Re: (meminto)
Its so damn strange that its only down low. It makes no sense to me. I have no idea how to diagnose it either.
A/F looks fine too.
float_6969
1990 Nissan 240sx Coupe
Topeka Kansas
8-26-2002
If it was spark blowout and you were getting failed combustion, your AFR's wouldn't be OK. Something else it going on. Try unplugging the mafs and driving the car around.
Buddyworm
St. Albert AB
1-9-2007
 « Re: (meminto)
I have a similar issue with my car. It's only around 3000 to just under 4000rpm and it's the worst when I'm getting on the throttle when the revs are around that range. Within that range I sometimes get a misfire or two, but just like you, once I'm above 4G's the engine goes like mad. My plugs are gapped to 1.1mm as well and my butterflies are also hooked up properly.
I'm pretty sure I know the cause; I noticed it the other day when I was tuning with a wideband. The "why", however, is still a mystery. Anyway, at that particular rpm range and that particular load, the engine runs pig rich, like 9:1 AFR. For some reason, the target pullswidths Nissan put in that particular section of the fuel map are huge, and the throttle tip-in enrichment as you get on the gas certainly wouldn't help things.
You wouldn't happen to have aftermarket cams would you? My theory is that because of the differences in the cams yadda, yadda [insert a bunch of cam design jargon here], perhaps the secondary butterflies are openning at the wrong time to suit the cams. And maybe need to open sooner because they're restricting the higher flow capabilities of the cams.
Of course, that theory goes out the window if you've got stock bumpsticks and I'm probably wrong anyway.
Buddyworm
St. Albert AB
1-9-2007
 « Re: (Buddyworm)
Another thought I just had: O2 sensor. I know mine is buggered because in Nistune it reads 0.3v. Constantly. Irregardless of anything. So the ECU thinks there's a lean condition and adds more fuel. It seems to me the ECU would still operate in closed loop at this point as well and leaves it once we hit the magic 4000rpm threshold.
This seems most likely than my previous theory, now that I think about it.
Thoughts?
Modified by Buddyworm at 9:46 PM 7/13/2008
articzap
Depew NY
3-18-2008
 « Re: (RS12Turbo)
I'm running 10* timing as per Jap FSM and have stock cams along with a stock turbo.
RS12Turbo
Birmingham AL
8-30-2006
 « Re: (articzap)
Hmmm, thats weird.....the fsm I have, that I downloaded from here (I think) says 15 degrees + or - 2 degrees
Keith
'84 S12 Turbo; Ca-det powered
'95 Maxima A32
http://www.cardomain.com/id/1984rps12
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
 « Re: (RS12Turbo)
That is because it is for the euro version, the base timing is correct for jdm motors 10 +- 2
Have you checked the fault codes articzap?
Definatley check the continuity of the ignitor....
articzap
Depew NY
3-18-2008
 « Re: (meminto)
The FSM that you can get through links on this site seems to be for a CA18DE only.
I searched through the FSM and couldn't find the test. Does anyone happen to know the page its on? I wonder if I'm having a similiar problem. My narrow band O2 sensor is reading 14.2-14.6. I'm starting to think its running a lot richer then that. I wish I had a way to test it though. I'll pull fault codes in a few minutes.
articzap
Depew NY
3-18-2008
 « Re: (articzap)
Went outside and pulled the codes. I got 55 which should mean no problems at all.
I'm just more and more confused with everything I check being in perfect condition. How do you set the TPS in case that could bumped during install? I don't know if that would cause this issue or not.
kapower06
St.Louis , MO
8-15-2004
I would suggest a correct ca18det mafs.
The SOHC ka is not the same.
90' 240sx Hatch ( ca18det )
- ARC smic
- Centerforce Stage II clutch
- 3" Megan Racing 02 housing
- 3" Megan Racing downpipe/test pipe
- 3" RSR Ex-Mag cat-back (sounds awesome)
- Removed A/C, P/S, and stock fan
- HKS air filter
Best 1/4 mile... 14.2 @96 mph 2.0 60ft. (stock turbo@12psi, open diff)
shooting for mid-low 13s with stock 370's, hybrid t2/t3, n60 maf and chipped ecu.
articzap
Depew NY
3-18-2008
 « Re: (kapower06)
Yeah I know I should be running one of those but it wouldn't effect me where I am having problems....It would effect me up top.
My Apexi turbo timer is showing around .6-.7 volts during those RPMs.
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
 « Re: (articzap)
Thats a good start, it means the ecu is detecting the sensors fine, the downside is that one or more still could be faulty as all the ecu does is check detection of the circuit..
I will find the pages you need for the continuity check and the tps setting tonight and let you know..
Out of curiosity, does it happen more often at WOT or does it have the issue regardless of position?
articzap
Depew NY
3-18-2008
 « Re: (meminto)
Seems to be regardless of throttle. Although if your very smooth with it, you can edge out about 5 psi before it starts to blow out. Now if I straight floor it, it blows out almost right away. Right around 1 or 2 psi. This is making the car very awful to drive. You have to drive like an old person to get going. God it sucks so bad.
I just lost to a third gen Camaro because I couldn't accelerate at a light. Had to play to catch up and was pulling on him, it was just to late.
Thank you very much meminto. If theres anything you need, please let me know.
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
Ok, you need pages :
Power Transistor (ignitor) EF&EC 125
Idle Switch - EF&EC 100
Throttle Position Sensor - EF&EC 98
You don't actually adjust the TPS, you adjust the idle switch...
This is from the euro manual which is the most common one floating around...
articzap
Depew NY
3-18-2008
 « Re: (meminto)
I know the TPS doesn't need adjustment, I just don't think its in the factory position.
Now to add to possible light to the problem. After work I'll test the power transitor. But on my way to work today I was getting spark blow out around -8 inHg. Then when I'd let off the gas it would almost die all the way out. I then got it up to 4k and floored it. It had spark blowout for a few seconds then proceeded to pull like normal when in boost above 4k.
I'm starting to think its a going power transitor, which I'll check when I get home or I have and over fueling issue causing the plugs to foul out in the low RPM's and causing the spark blow out because of an over rich condition.
I'm going to assume this condition is caused by the Walbro 255 lph pushing to much volume through the injectors. Does anyone else think I should try pulling some fuel out of the mix with SAFC?
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
 « Re: (articzap)
Check your igniotor first, eliminate that possibility...
The fuel pressure is regulated, so the pump couldn't be pushing to much volume as such...
Actually how healthy are your injectors?
articzap
Depew NY
3-18-2008
 « Re: (meminto)
Gabby sent me a set because mine were stuck closed. These ones seem to be operating just fine. And an FYI, fuel pressure is regulated, not volume. You could regulate volume with a fitting change within the Synapse FPR, but I have set to stock right now. I may need to change that.
RS12Turbo
Birmingham AL
8-30-2006
 « Re: (articzap)
Quote, originally posted by articzap »
Wouldn't hurt to try. I've got my afc set all in the negative range...like -8 and -9 throughout.....because it was running pig rich. Found this out when I got it dyno tuned a couple of years ago. before the tune it would cut out at wot ONLY in 4th and 5th gear at 4000k-4500k. After the tune the afr's are where they should be, and it hasn't cut out like that again. Still not sure if my stock fpr is to blame because of the walbro 255
dftsilvia
s14
buffalo n.y.
12-28-2006
 « Re: (RS12Turbo)
dave do u have a wideband??? if u need to use one i could let u borrow my aem since my car doesnt run rite now. what do u have your maf settings at on the safc? have u looked in the sensor check in the afc to make sure your tps and your maf are all reading correctly?
do ca's have 270cc's or 370cc's???
maybe your pump if pushing fuel past the injectors?
Driftset
SuiSlide
Sawce Money
articzap
Depew NY
3-18-2008
 « Re: (RS12Turbo)
RS12Turbo, do you remember your throttle point settings? Was your low and high map the same?
drftsilva, I would like to borrow a wideband for tuning but I need to get a bung weld it in my test pipe then. Stock injectors are 370cc. I doubt fuel was getting pushed past them, I just think to much fuel is being let through when they are open.
RS12Turbo
Birmingham AL
8-30-2006
 « Re: (articzap)
My lo map is 0
My hi maps are..........
800 rpms: 0
1600: 0
2200: 0
2800: -9
3400: -9
3800: -10
4600: -10
5200: -9
5800: -8
6400: -8
7000: -10
7600: -10
articzap
Depew NY
3-18-2008
 « Re: (RS12Turbo)
So what was your throttle points set at.
articzap
Depew NY
3-18-2008
 « Re: (articzap)
I think I figured out my issue. My car is running very rich. I was reading my Synapse manual and it stats that if you run a Walbro 255 lph fuel pump, you need to install a larger bypass fitting so the volume of fuel in the rail isn't greater then stock. I'm pretty sure this will solve all of my issues. I'm going to mess with that Sunday when I have some free time again.
float_6969
Topeka Kansas
8-26-2002
I assume Synapse is the brand name of your FPR? If so, it's very easy to hook up a fuel pressure gauge and see what the fuel pressures are like.
articzap
Depew NY
3-18-2008
 « Re: (float_6969)
I have a fuel pressure gauge and its set at 38 psi. I'm not a complete idiot here. Theres a bypass fitting inside the regualtor it self that can be swapped for different sizes depending on fuel volume. I think I have the wrong fitting in there.
I took about 10% out with SAFC and it is indeed running a lot better but I'm still having issues.
dftsilvia
s14
buffalo n.y.
12-28-2006
 « Re: (articzap)
did u ever change that fitting????
articzap
Depew NY
3-18-2008
 « Re: (dftsilvia)
Weather pending, I'm swapping the fitting tonight. I'm going to buy a bung probably tonight too and try to get that welded in so I can get it tuned this weekend for 14 psi. :pimp: Can I still borrow that wideband?
articzap
Depew NY
3-18-2008
 « Re: (articzap)
Will the mods please change title to solved.
I believe I have stumbled on to the reason why so many guys running Walbros run stupid rich. Its all in the bypass fitting.
When I was having problems I had my stock Synapse FPR and my Walbro. In order to get the car to run I needed roughly 38 psi of fuel pressure. I would also get horrible spark blow out, terrible gas mileage and tons upon tons of black smoke. I began by removing fuel with my SAFC. That alone worked wonders but never got it right. Besides, trying to fix an issue with SAFC is just a horrible band aid solution. I knew the problem was fuel now though. So I read through my Synapse directions, and sure enough it says that if you run a Walbro 255, you need to change the bypass fitting to a 2.5mm. So today I got home and began to tear into it. What ***** it is to get the FPR off without taking off the rail. Stupid firewalls. Well I change the fitting and put it back together. First thing I did was start it up and go check my fuel pressure. At idle I was getting 23 psi of fuel pressure. Seemed low but I revved the motor a bit and it shot right up to 38-40 psi. Before when I revved the motor it would shoot to 80 psi. I figured alright the fuel pressure is low, but lets take it out and see if it exhibits the same symptoms as before. I drove around until the car warmed up. The true test was about to come. I put it in first and got the car above 4k and floored it. Still pulled very hard up top, if not harder. My O2 volts were hovering right around .5-.65. Respectable voltage. I then proceeded to give it the true test. At about 10 mph I put it in 2nd gear. I gave it a nice 50% throttle pull. I came up with 7 psi and had just a bit of hesitation. No big deal, the plugs are probably just fooled. Tried it again and all of my issues were gone. The car runs nearly perfect now. All thats left to do is to install drftsilva's wideband and get this beast tuned for 14 psi.
Well your thinking to yourself, I have similar issues but I run a NISMO FPR. If you're running a NISMO FPR with a Walbro 255, you may have something thats not solvable unless you can change the bypass fittings, which I doubt you can, or drill out the bypass to allow more fuel to get past.
Or just buy a real FPR.
RS12Turbo
Birmingham AL
8-30-2006
 « Re: (articzap)
nice............
Where can you buy the fittings at?
articzap
Depew NY
3-18-2008
 « Re: (RS12Turbo)
Its included when you buy the FPR. You remove the bottom and install the fitting that has a larger opening.
articzap
Depew NY
3-18-2008
 « Re: (articzap)
I feel like a complete newbie but I'll admit my dumbass mistake.
On the Synapse FPR, theres to vacuum ports. One for the FMU and one for the static fuel pressure. I had it hooked up to the FMU port. D'oh. I hooked it up properly and good lord. That fixed my fuel pressure issue too, FYI.
I'm now making 12 psi on the stock wastegate and holding 12psi till around 6500 RPM-7000 RPM. I'm so happy that its finally working properly. 14-16 PSI here I come.
dftsilvia
s14
buffalo n.y.
12-28-2006
 « Re: (articzap)
damn good to hear at least it was an easy fix. now slap one of my spare rb turbos on that slut
articzap
Depew NY
3-18-2008
 « Re: (dftsilvia)
You have spare RB turbos???? What are they, T28's? I wasn't going to do anymore this year but now I might have too.
» Return to CA18DE / CA18DET Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
