 my car keeps killing battery's!!!
joesomebody06
1996 240 sx s14 ka24de-t
Waco tx
6-5-2008
okay, my battery is relocated into the trunk area, i bought the car like this, my hunch is that the altenator is not hooked up correctly and thus not charging correctly, i have noticed that when i start the car up, it hesitates just a little bit, im not sure if that is b/c the power has to travel so far or what but, i have to come up with a solution b/c my battery tray has about a 4 inch hole cut in it for the intercooler piping to be run through it.... does this sound like the alternator to you or what, i dont want to just go take it off and head to autozone for a test, that takes too long, i want to believe its something else that is easier... please help!!!!
1996 Zenki S14 Ka24DE-T, Remote Operated Suicide Doors, 18" ICW Racing Rims, 5 spd. M/T, FMIC & BOV, MSD Ignition, Boost Retard Dial, Custom (3) Gauge Pod In Dash, SAFC II, T3 Hybrid, KYB GR-2 Gas Struts On All Corners, Megan Racing Rear Suspension Pieces, All I Need Now Is A Cheap Paint Job!!!!!
All Bow Down To Project Slidewayz08
http://www.cardomain.com/ride/3093988
MaximA32
Super Moderator
1998 Maxima
Corona CA
7-9-2006
If you think that the alternator is bad then the only way to test it is to take it off and have it bench tested. If you have any kind of experience you can test the output of the alternator with a DVOM. Normal alternator output is around 14v.
-Kenny
Need help? Click here!
jmexia
95 240sx
Euless tx
4-3-2008
 « Re: (MaximA32)
You could take it to any shop and they could test it on the car. Most places only charge a half hour if any at all.
joesomebody06
Waco tx
6-5-2008
 « Re: (jmexia)
im just going to rent a voltmeter at the autozone for a 1/2 hour and test the starter solenoid and the altenator while im at it!! figure better do it while i have it
ShaunakaRichard
92' 240sx sr20det Redtop
Redding California
7-10-2006
 « Re: (joesomebody06)
Test your starter solenoid? If the car cranks there's nothing really to test....And the easiest way is to start the car and put the voltmeter on the battery. It should be around 13 volts at a minimum while the car is running. If it isn't then you have a problem. And as for the battery being relocated into the trunk, it wouldn't take the voltage awhile to get up front. Electrons basically travel at the speed of light, in a perfect system anyway. 3x10^8 meters per second. Its freakin fast. So needless to say ten feet is nothing. Length in a car is nothing compared to how fast electrons flow. And instead of renting a tester, just buy one. Even a cheap one is probably ten bucks. Its something good to have.
joesomebody06
Waco tx
6-5-2008
 « Re: (ShaunakaRichard)
yeah sounds like a good idea, im gonna do that and get back with you... and as for electrons traveling at the speed on light.... wow.... i never though it could go that fast
nissanracer300zx
California
7-20-2008
 « Re: my car keeps killing battery's!!! (joesomebody06)
You need a new alternator.
joesomebody06
Waco tx
6-5-2008
 « Re: my car keeps killing battery's!!! (nissanracer300zx)
found the problem, the shop had tensioned the belt too much and it frayed the belt so bad that it finally just popped off so in other words good altenator, no belt!! will be fixed by lunch
Dansmaxima
2001 Maxima SE, 95 Jimmy, 91 GMC Sierra
Warren NJ
4-13-2008
I was gonna say 186,000 miles per second is fast, but resistance also comes into play. Old trick to test alternator is to put a steel screwdriver blade to the back center of the alternator while the engine is running. (If you can reach it safely) If it feels magnetized the rotor has field current and likely the alternator is charging.
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
