 Patching Drywall?
240marcuSX
E34 525i, K6 GSX-R600
Petersburg VA
2-22-2003
  Patching Drywall?
Anybody know how to do this? Im watching tutorials on it right now, doesnt seem too bad.
I have a couple holes in my bedroom walls from when I got pissed off as a kid, and now its time to fix them.
One of them I think is small enough to put some mesh over and sand smooth, but the other I think needs to be cut out and patched.
Ive been watching this:
http://www.easy2diy.com/cm/eas...#shop
Any other advice?
S13 HATCH PARTS GIVEAWAY!!! Interior pieces, ecu, rear seats, cd player, glove box, and carpet. A good start for someone wanting to convert to all black interior. marcusrcis2@yahoo.com
1994 BMW 525i
2006 Suzuki GSX-R 600
240marcuSX
Petersburg VA
2-22-2003
ok well. I just got back from the hardware store, I bought everything I needed for about $38, I'll let you know how everything goes, if anyone cares.
Papi Chulo
72 Datsun 510
Central Coast CA
10-11-2007
That link is how I do it, minus the wood strips.
240marcuSX
Petersburg VA
2-22-2003
 « Re: (Papi Chulo)
So you just use the mesh tape? or do you attach the new drywall to the existing studs? I have a large hole, over 3" in diameter.
numbnuts240
1995 blue emerald 240sx se, 2006 F-150
meriden ct
7-1-2006
 « Re: (240marcuSX)
post pics of the holes, and if possible, show where the next studs are on either side of the holes.
Quote, originally posted by DrifterXRPS13 »
what can i say...i like teh cock!
Great...now everybody's gonna know i like teh cock...you guys suck..oh wait, no i guess that applies to me...wah wah wah..
"what is your major malfunction, numbnuts?"
Papi Chulo
72 Datsun 510
Central Coast CA
10-11-2007
 « Re: (240marcuSX)
Quote, originally posted by 240marcuSX »
I use paper tape but mesh works just the same. You're not just covering the hole with tape and applying compound, that will leave it uneven and it will eventually crack.
If there's a stud in the area then yes, if not use the wood strip method. I just cut the square to fit tight, tape it with compound, sand, then texture.
240marcuSX
Petersburg VA
2-22-2003
OK, I just cut out an 8"x12" hole, and cut a piece of drywall to fit. It doesnt fit tightly enough to not use the board, so I will have to use it. I cut out such a big piece because the damage was much bigger on the other side of the wall.
There is one stud about a centimeter away on one side, but on the other side there isnt one anywhere near. If the hole were more directly over the stud I would just use the stud.
My main concern is making it look even, because this is a little bit of a covert operation.
Q451990
Old School Q Guru
1990 Q45 - 91K, 2005 G35 Sedan - 32K, 1997 Nissan Truck - 133K
Columbia, SC
7-23-2002
 « Re: (240marcuSX)
As a real estate investor, I have patched waaaaay too many holes in drywall over the years. My favorite trick is to walk through the paint department at Home Depot on the way to the registers and grab a handfull of those big wooden stir sticks... the ones for the 5 gallon bucket. They make great backers for sheetrock patches. For some reason they tend to split less than 1x2s, and they're free.
The biggest thing I have learned is to do as much smoothing as possible while you're applying the mud. But be sure not to build it up too much. You will need to sand and re-apply at least twice.
Good luck with the "covert operation" since the entire room will likely be covered in white dust from the sanding!
One of my favorite tricks for small patches is online somewhere, but I can't find it. I'll describe it as best as possible, but it's hard to put into words. Say you have a 4"x 4" hole. Cut a 6" x 6" peice of sheetrock, then cut the back side through the paper and most of the filler, in a 3 7/8" x 3 7/8" square leaving the face of the paper intact. When you're done you'll have the front sheet with a chunk of drywall that will fit perfectly into the hole in your wall. The "flaps" around the edge can be buttered with drywall mud and act as both sheetrock and tape! Like I said, hard to explain, but it works. For smaller patches, you can get away with only one touch-up coat of mud.
Happy patching!
Heath
1990 Infiniti Q45 - AKA "Q2"
2005 Infiniti G35 - Sedan A/T FOR SALE
1997 Nissan Truck - XE - 5 Speed M/T
audtatious
CIO
2002 Maxima SE - 2008 G37s
Jeff/Louisville
10-27-2002
 « Re: (240marcuSX)
Unless it's an old house, studs are typically spaced 16 inches on center. Make sure you use drywall mud and not spackling as that crap is a pain to try and sand. Use a large trowel as well and spread the mud at least 6-8" passt the seams to ensure a smooth blend.
Q451990
Old School Q Guru
Columbia, SC
7-23-2002
 « Re: (audtatious)
I finally found a link to the method I was trying to describe...
http://www.naturalhandyman.com....html
Heath
240marcuSX
Petersburg VA
2-22-2003
Thanks for the help guys.
I got it patched up, It just needs to be painted. The dust did get all over everything, but Im going to call this mission completed.
The other hole that I have is just going to get some drywall compound, I dont think I need to cut out a patch of wall to fix it.
krazydriver
2002 civic ex, 1993 KA-T 240sx
Middle of Nowhere NY
2-8-2007
 « Re: (240marcuSX)
^ there's no need to paint it.
Just pull a redtop and put a lamp over it.
Quote, originally posted by srpowered240sx »
lowering springs. or for the same cost you could date a fat girl for a few days, would cost the same and have about the same drop.
Engine stuff for sale -> http://forums.nicoclub.com/zerothread?id=368806
MSD coils, S13 cam, Intake stuff, stainless braid oil lines + more!
redtop91
Meat Gazer
↑ ↑ ↓ ↓ ← → ← → B A Start
Broken Arrow OK
9-7-2006
 « Re: (krazydriver)
It's gonna look like *** with that patch kit. Here's my attempt at patching.
http://forums.nicoclub.com/zer...age=1
Just pay someone professional to do it. Trust me. If you want to do it, just cut a piece of drywall to roughly fit and use spackle to fill in the spaces.
» Return to Around the House
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
