audtatious
CIO
2002 Maxima SE - 2008 G37s
Jeff/Louisville
10-27-2002
| « Re: pads gone in less than a year?!?! (95.240AZN378) | 4:11 PM 7/12/2008 |
Have you had the rotors checked out?
95.240AZN378
95 240sx
Williamsburg VA
5-7-2006
| « Re: pads gone in less than a year?!?! (audtatious) | 5:13 PM 7/12/2008 |
I replaced them too. The ones that were on it were warped, and my new rotors are getting there already also.
gumby74
San Antonio Texas
1-7-2007
Sounds like the calipers are binding. Is there excessive tension on the parking brake cable? The brake handle should come up and fully engage after x number of clicks. (I wanna say 6, but I could be thinking of another car)
adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
| « Re: (gumby74) | 3:44 PM 7/13/2008 |
your calipers could be siezed. What condition are the boots in?
Snoop with a 510?
 | Quote, originally posted by idahotuner » | | WAHT DOES THIS FAP MEAN |
95.240AZN378
95 240sx
Williamsburg VA
5-7-2006
| « Re: (adrians_s13) | 9:11 PM 7/13/2008 |
the boots are ehhh... when I had to push the piston thing back in, it looked like they used pliers to turn it, and it had rips around the outside of it. The rubber piece around the piston thing is what your talking about right adrian?
adrians_s13
Long Beach CA
6-29-2005
| « Re: (95.240AZN378) | 12:26 AM 7/15/2008 |
| Quote, originally posted by 95.240AZN378 » | the boots are ehhh... when I had to push the piston thing back in, it looked like they used pliers to turn it, and it had rips around the outside of it. The rubber piece around the piston thing is what your talking about right adrian? |
yup.it's probably already seized man... either get them rebuilt or find some used ones for cheap. Same thing happened to me... my passenger rear's boots torn and seized... I'm loosing pad, plus my wheel gets all dirty quick because of the brake pad dust. Luckily I found a dude nearby that sold me both his rear calipers for $5.
95.240AZN378
95 240sx
Williamsburg VA
5-7-2006
| « Re: (adrians_s13) | 6:24 AM 7/15/2008 |
awww dude you are lucky! Are the SE's and the base rear calipers the same? The other day, I drove home from work, (maybe a 5 minute drive) touched the disc, and burned my finger. Touched the front, not nearly as hot.
adrians_s13
Long Beach CA
6-29-2005
| « Re: (95.240AZN378) | 10:44 AM 7/15/2008 |
| Quote, originally posted by 95.240AZN378 » | awww dude you are lucky! Are the SE's and the base rear calipers the same? The other day, I drove home from work, (maybe a 5 minute drive) touched the disc, and burned my finger. Touched the front, not nearly as hot. |
no... bases and se's are different I think. I think all SE's have abs...
95.240AZN378
95 240sx
Williamsburg VA
5-7-2006
| « Re: (adrians_s13) | 4:10 PM 7/15/2008 |
are you sure? hmmmm... I don't think all se's have ABS.
adrians_s13
Long Beach CA
6-29-2005
| « Re: (95.240AZN378) | 12:12 AM 7/16/2008 |
| Quote, originally posted by 95.240AZN378 » | | are you sure? hmmmm... I don't think all se's have ABS. |
well the difference is between ABS and non ABS, whether or not you have an SE or not. Do you have abs?
95.240AZN378
95 240sx
Williamsburg VA
5-7-2006
| « Re: (adrians_s13) | 10:13 AM 7/16/2008 |
I don't, I just talked to a dude that said that he'll sell me his from a wrecked SE, he said the only difference was the ABS nonABS. too bad he had ABS. It was a killer deal.
