 Air bypass valve, crankcase ducting
craigztoyz
90 300ZX VH45 95 J30 90 rx7 lots of cars older then me.
Austin TX
1-18-2008
Long story short.
I am running the rear lines from each cover to the crankcase vent in the valley. The middle two are bridged together, the front two, are t'd together and vent through a filter. ok, so I plugged the big opening in bottom of upper plenium. I left the bracket for the AIB, but the rest is all gone, or lost in storage.
Is this ok?
I recall someone saying they had removed it, and it idled fine, and had no issues. looking for feedback, and info, Thank You, Craig
To help define info wanted, what is the importance, of this, andsince it is unmetered air, I can't imagine it feeds much if connected. Do I need to find the pieces?
Same with the EGR too. I removed it all, plugged it up, and now not sure what to do with the wiring connectors.
Q45tech
Q45 Guru
1990 Q45 319,000 miles
Marietta , Georgia
4-30-2002
 « Re: Air bypass valve, crankcase ducting (craigztoyz)
IAC is also used as an electronic dash pot to progressively drop rpm in steps when you suddenly let off throttle on highway to avoid stalls.
Besides it's normall function of stablizing rpms under load of Power steering, alternator, ac system and varying air densities and temperatures.
http://www.t3auto.com/
craigztoyz
Austin TX
1-18-2008
 « Re: Air bypass valve, crankcase ducting (Q45tech)
Thats what I was figuring, by what it does, but not sure what problems I will have, hot weather usually, hope that will be good, as a choke is rarely needed.
T45
King Kong powered Z32
va beach va
6-9-2006
I deleted both my IAC and PCV systems. Without the IAC the engine is a pig when it's cold, even in the summer. Once it's up to operating temp the idle is (was...lol) fine and once my idle speed was set I didn't have any stalling after chopping the throttle on the highway etc.
For the pcv I ran the rears to the crankcase vents, the centers together, but on the pass side I vented it and the drivers side I blocked it off. Any pressure from the drivers side will make it over to the pass side through that center hose.
SuperHatch
07 Tundra, VH Powered S14, 92 Slicktop Z32
Manahawkin NJ
11-17-2006
Quote, originally posted by craigztoyz »
The IAV does not feed the motor unmetered air. There is a pipe that runs under the plenum to under the throttle body, and a small hose that connects that pipe to the intake pipe, between the MAFS and the throttle plate. Every bit of air in the engine is metered from the factory, it is the only way to ensure proper tuning. Even venting the PCV system to atmosphere introduces unmetered air via crankcase blowby gases or releases metered air that is now unburnt. Venting the PCV system, however, is a very small percentage compared to the IAC system and will only result (if the motor is healthy) in a 1-2% change in target AFRs.
- Stephen
http://www.godspeed-racing.com
npez
1993 Nissan 300ZX Turbo (soon 2B twin-turbo 450ZX) 2002 BMW M3 2008 Honda Odyssey Touring (Mama)
Houston TX
8-30-2007
 « Re: Air bypass valve, crankcase ducting (SuperHatch)
Quote, originally posted by SuperHatch »
Craig,
To add to Steve's & Q45Tech's comments, the IACV works off of like 10 different inputs to the ECM. Also, though hot here in Texas, the input is not ambient air temp but engine coolant temp. So when you start the car and until it reaches operating temp, the IACV is in play. It also has an input for battery voltage, starting signal, and many others that determine how open or closed this valve will be.
My $.02 would be that while the car will most likely run without it, it probably will be best to track it down and install it, so you can have 100% drivability.
Thanks,
Nick.
Modified by npez at 9:56 PM 7/12/2008
1993 300ZX Twin-Turbo soon to be 450ZX Twin-Turbo (Oxford Gray)
2002 BMW M3 (Imola Red)
2008 Honda Odyssey Touring (Hey the kids have to ride somewhere!)
craigztoyz
Austin TX
1-18-2008
 « Re: Air bypass valve, crankcase ducting (npez)
Thanx Everyone for the input, This is what I was looking for.
T45- Thats exactly the reply I was looking for, I remember when you started it, those q's were brought up and went through. I wont be driving it cold, and am not worried about it. If I come across the pieces, then maybe one day.
I hope to get some vids up soon. Ground issues at the moment. Now cant get ecu to trigger anything. No pump, inj, coil. THE JOY OF $#IT THAT DOESNT WORK.
» Return to VH45DE / VK45DE Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
