 has anybody thought about how bad our intake ports are? (charge mixing-wise)
themadscientist
RB/Skyline Moderator
Online
staring down at you with disdain from the
spooky mountaintop castle
11-12-2002
Think about it. We have eight ports feeding four cylinders. That by itself is not much of a problem but what about the secondary butterflies and most importantly injector placement.
The secondary butterflies are in theory a neat idea but anybody who has flipped those things open and looked down the port will likely come to the same conclusion I have, F-that silly crap.
Now the four port euro head has, well four ports. Four oval ports that divide before the valves but more importantly a centered injector firing reasonably equally at both valves. Think about the eight port head, starting to realize what I have? yeah you have a wet port and a dry port. The injector is centered on one port and valve, the other port flows only air.
I'm no engineer, don't claim to be but Madmomma didn't raise no dummy and you only need basic horse sense to start asking some straight questions.
1. how effectively is the charge getting mixed in the chamber?
The charge is actually the sum of the collision of two columns of air, one saturated with fuel, the other bone dry and they are expected to fully homogenize in the chamber before it gets compressed and lit.
To me that sounds completely impossible and very inefficient.
2. how much hotter is that dry valve than the wet one?
The incoming charge has a cooling effect as it washes over the valve; how much I don't know. I do know that one valve is bathed in a super rich charge and the other again gets bubkis, air only. That dry valve has got to be hotter that the other. That could create a possible detonation source.
It makes me wonder if getting an even fuel flow might unlock some power, perhaps raise the boost threshold. You could perhaps modify the sub manifold to mount eight smaller injectors or mount four further back in a custom manifold and knife edge the splitter between the ports.
Discuss.
zmannz
1988 rx7 w/ dry sump ca18det coming soon....
Rock Hill SC
12-12-2004
 « Re: has anybody thought about how bad our intake ports are? (themadscientist)
I was thinking of an extra set of stock injectors on the manifold, one extra for each "dry" port.
1988 Mazda RX-7 with dry sumped ca18det in the works!
Full picture gallery:
http://s169.photobucket.com/albums/u226/zmannz/
themadscientist
Online
11-12-2002
 « Re: has anybody thought about how bad our intake ports are? (zmannz)
There is not enough meat in the casting to cut reliefs for extra injectors to spray.
float_6969
Online
1990 Nissan 240sx Coupe
Topeka Kansas
8-26-2002
I've considered all of these things in the past as well, and if you look at all of the latest design technologies, all of the variable port velocity mechanisms are now upstream from the injectors and use one port per cylinder.
The other thing that comes to mind is that the 4 port head used on the EDM CA's was created AFTER the 8 port head. I would have to say that Nissan must have realized something about the 8 port head that made it worth creating a whole new cast for the head...
Ca_Silvia
Calgary
11-18-2005
 « Re: (float_6969)
Quote, originally posted by float_6969 »
True but the 8 port head must have been Rand D for a few years prior to production. Also, what about all those crazy high hp CA we keep seeing. Are they 4 or 8 port intake vehicles? Common sense would lead me to believve they are 4 port for maximum peak air flow but that is just a guess.
Aaron
themadscientist
Online
11-12-2002
 « Re: (Ca_Silvia)
The Norris car is four port as are all the high HP European cars but the Pady and other big power Japan cars are eight port.
Ca_Silvia
Calgary
11-18-2005
 « Re: (themadscientist)
Quote, originally posted by themadscientist »
So its basically a wash then, kinda sounds like the intake flow doesn't really matter to make high hp.
themadscientist
Online
11-12-2002
 « Re: (Ca_Silvia)
it always matters.
The Norris car retains the stock manifold which is definitely a restriction. The J-spec cars ditch the factory manifold which makes a big difference. Four port plus good manifold could mean 700hp.
ca18detgabby
92 s13 ca18det
lake mary fl
2-10-2007
Just spit balling, but wouldnt utilizing the charcoal canister make for more fuel being used by the "dry port" as it utilizes the over draft of fuel fumes as a fuel source instead of using the fuel itself.
not 100% on how the canisters work, but from what I understand thats what the idea behind them was. better MPG as you run on fumes instead of the fuel itself.
Quote, originally posted by r34 gtr »
Who gets rid of their CA's? People who suck, thats who.
r34 gtr
ugly black 89 240sx hatchback
Huntsvegas AL
12-29-2002
Yes I have thought about it. You could cut out the material in there and make it a custom massive four port job, or you could just jump on a plane to England and stuff a four port head in your carry on. If you have family over there like me, its just a matter of remembering to pick one up from a breakers yard when you are visiting.
I plan on running meth injection, if I ran it through that other port by drilling and tapping a jet into the "dry" runner, then I would have the cooling effect on that valve too, and would have mixing of two fuels in the combustion chamber. It would also be very easy (and baller-status) to do.
I'm like the Gangstalicious of NICO.
Quote, originally posted by Jesda »
Side note: People in the mortgage industry do a lot of cocaine.
ryan: It's not that I think he's retarded. It's that I was the one that gave him his gold medal at the special olympics. I KNOW tim is retarded. I hope I never meet him in real life actually. I'm like 6'2" 185lbs. Tim is prob like 6'7" 300lbs and eats live baby sheep for snacks during the day.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
what about converting the 8 port to a 4 port with a costume manifold and costum inj system and a standalone
1990 240sx
recently swapped CA18DET 32k miles
Greddy FMIC and Hot pipe
R32 VLSD
SoOn tO cOmE : 5 lug brake upgrade, R32 MAF,KA TB,444cc injectors, aluminum one piece driveshaft, bucket with 4 point harness, Greddy BOV, Standalone,turbo timer...
themadscientist
Online
11-12-2002
 « Re: (r34 gtr)
I have two four port heads
meminto
Online
S13 Silvia CA18DET
Lismore NSW
4-28-2008
Out of curiosity, say you were able to prove that there is a benfit in increased horsepower or torque moving away from the 8 port head to the euro 4 port head or customised 8 port, however you want to do it...
If you could say, hypothetically that you found (examples only) 10-20 hp or 5-10 nm through the rev range, what would the cost v's performance gained ratio be?
Also when you say stock manifold being a restriction, do you mean an untouched manifold or a ported and flow tested stock manifold?
Project "Baller"
http://forums.nicoclub.com/zer...r-lol
mbmbmb23
Charlotte NC
8-19-2004
Get a greddy football intake and make a conversion plate to bolt it up to the CA middle intake (butterfly passage).....then relocate the injectors to the greddy manifold....delete the butterflies......jb weld the OEM injector holes. Plug in an SR top mount injectror fuel rail if the CA's doesnt work. Im pretty sure the greddy will work with top mount inj. You may have to hog out the butterfly passage....or.....weld the greddy to the 4 intake runners RIGHT before the butterfly passage.....like the custom CA manifolds weld on.
Heres the fake greddy "freddy" intake on ebay. Evidently the casting is rough....but guys cut em in half and port them. The price is right for a lil experimenting.
http://cgi.ebay.com/ebaymotors...ZWDVW
Modified by mbmbmb23 at 10:36 PM 7/11/2008
DALAZ_68
240sx
Los Angeles CA
4-9-2007
 « Re: (mbmbmb23)
what about this one
http://cgi.ebay.com/ebaymotors...l1318
Quote, originally posted by mbmbmb23 »
mbmbmb23
Charlotte NC
8-19-2004
 « Re: (DALAZ_68)
It doesnt have injector bosses (ports)...otherwise its decemt...wonder if the velocity stacks are tuned to one another?
float_6969
Online
Topeka Kansas
8-26-2002
I have a 4 port head as well and I'm hoping (one day) to do a side-by-side comparison.
themadscientist
Online
11-12-2002
 « Re: (float_6969)
Somebody is working on it.
NUT-CSE
1988 Nissan Exa
Sydney
3-11-2007
I love the technical CA threads, its a shame my CA intelect is piss weak. Im just gonna keep taking in all this info that everyone has to offer.
articzap
1990 Nissan 240SX - CA Swap
Depew NY
3-18-2008
 « Re: (NUT-CSE)
You cannot spray the whole port before the butterflies, or you'll be pooling of fuel at the butterflies. So if you're going to leave the butterflies, theres a couple of things you can do. You can either add another injector computer controlled to come on when the secondaries open or you can close off the stock injector port or add one before the butterflies in the center as a "secondary" injector.
240 Hotness
r34 gtr
Huntsvegas AL
12-29-2002
TMS, those intake ports are drop dead sexy. Thats exactly what I had in mind.
I've always said, butterfly valves = weak sauce. I'm much happier without them.
chausaster
1990 Nissan 240SX Fastback CA18DET
Logan Utah
5-24-2005
 « Re: (r34 gtr)
I honestly like this idea. I'm running megasquirt right now and adding a RPM based meth injection into the dry secondary butterfly port may yield an very easy wet port setup. If anyones got a spare 8-port intake manifold that they are willing to sell I'd totally like to try that idea.
edit: So looking into the system. I'm finding a few small problems. will fitting the meth jet near the beginning of the secondary butterfly port be too close? or does it spray kind of like an injector and have the time to cool and atomize? I'm not really familiar with meth injection.
Modified by chausaster at 3:02 PM 7/13/2008
themadscientist
Online
11-12-2002
 « Re: (chausaster)
Quote, originally posted by chausaster »
Just say no to drugs man
chausaster
Logan Utah
5-24-2005
Oh but I got so interested.... I can't stop now..... So going on after several hours of looking around and reading up. It seems that if 4 jets were ran near the beginning of split in each secondary butterfly ports you should still get a good mixture of methanol and air into the system to give sufficient cooling for the system and create a wet secondary butterfly port.
I've found in the process of this a cheaper water\methanol injection kit that should suffice. http://www.enginerunup.com/ these guys have a cheap little kit that comes with most of the stuff needed to run the 4 port injection.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
dare i ask...but what would happen if we remove the secondaries all together and fab a manifold directly to the head?
lostmenoggin
1989 Nissan 240sx ca18det swapped
Bluemont VA
3-16-2006
 « Re: (DALAZ_68)
heres another...
http://cgi.ebay.com/Nissan-Sil...l1318
themadscientist
Online
11-12-2002
 « Re: (DALAZ_68)
Quote, originally posted by DALAZ_68 »
Just be sure to include the thermostat housing.
chausaster
Logan Utah
5-24-2005
 « Re: (lostmenoggin)
Quote, originally posted by lostmenoggin »
heres another...
This intake mani doesn't have any ports for fuel injectors. You may want to have some. Also If you live in the wonder winter weather land like I do 5 months outa the year. it may be good to have a spot where the fast idle stuff can sit.
themadscientist
Online
11-12-2002
 « Re: (chausaster)
all cars have a fast idle system
float_6969
Online
Topeka Kansas
8-26-2002
LOL!
chausaster
Logan Utah
5-24-2005
I have no response but that is a true statement but for people who'd rather not sit in there car and wait for it to warm up a fast idle solenoid is nice.
themadscientist
Online
11-12-2002
 « Re: (chausaster)
use a stick ya gyrl.
I'm sure somebody sells a carbon fiber "fast idle adjustment rod" for all you racer types with the detachable steering wheels.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
i need a detachable wheel...i live in L.A.
themadscientist
Online
11-12-2002
 « Re: (DALAZ_68)
No you need a team of crips brandishing AK47s to stand around your car.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
im not in south central or compton lol...but i do hasve fam there
themadscientist
Online
11-12-2002
 « Re: (DALAZ_68)
Think of it as a community outreach program.
Keep a gangbanger employed so they don't get involved in destructive things like drugs or democratic party membership.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
u sir...are an entrepreneur LOL
» Return to CA18DE / CA18DET Forum
Copyright © 2000-2008 by NICO
