 wind noise
jazzy5454
rogue
BROKEN ARROW OKLAHOMA
7-10-2008
  wind noise
I had bought my 2008 rogue in dec & i have a howling wind noise as well. it has been taken in to the dealership (4) times & they do not know where it comes from. I am not sure if you take the crossbars off it will go away? I do know that i have tred folded in my side mirrors & for now when i do this i do not hear a wind noise? Who knows the noise is very annoying and for a 26,000 dollar car you should not have to deal with this. Anyone have any good ideas?
OnlineUser
Nissan Rogue S
Edmonton Alberta
8-1-2008
 « Re: wind noise (jazzy5454)
WE just bought a Rogue S and took it on a 1800 mile road trip. On our way back we experienced terrible wind noise -- kind of like a lame ghost impersanation - we were going 75 mph (the speed limit!) and it was windy as heck. We experimented and discovered with the passenger window all the way up it caused the noise and if just barely moved it down it wouldn't make the noise. Luckily we had a video camera and recorded the noise as there is no way service would think there is anything wrong just by looking at it. If they can't fix it, they can take their car back. Not paying $25K for a noisy highway trip!
apd183
'08 Nissan Rogue SL AWD
Austin TX
8-5-2008
I think the noise is coming from the door seams. I hear it during windy weather (which is common here in Texas) at high-ish speeds while driving into the wind. I am able to make it go away by pulling the top of the door frame in, though I can't tell if the noise is from air being channeled between the door and frame or if it's leaking through the weatherstripping. During one windy rainstorm I found some water on the frame inside the weatherstripping, so I'm leaning towards that.
I have not been to the dealer about it yet as I have just recently determined the source of the noise.
jazzy5454
rogue
7-10-2008
 « Re: wind noise (apd183)
IF YOU FIND OUT THE PROBLEM PLEASE POST SO I CAN GET MINE FIXED.
THANK YOU
kerrton
Lethbridge AB
2-4-2008
Yeah, it must be a problem with a seal, because my Rogue is whisper quiet on the highway, and the Rogue usually gets praised for quiet interior in most reviews I've read. Good luck, I'm sure you'll find the problem soon.
By the way, I don't understand your poll. The two choices are "why" and "help" - can you clarify what these mean?
Cristen
2008 Nissan Rogue SL FWD - Venetian Red
Ottawa ON
12-19-2007
I have the same problem, but I have no idea what your poll means. Why and Help?
philipa_240sx
'08 Rogue SL FWD - Iridium Graphite
KW Ont
6-21-2007
 « Re: wind noise (Cristen)
Poll didn't make sense to me either. I deleted it.
OnlineUser
Nissan Rogue S
Edmonton Alberta
8-1-2008
 « Re: wind noise (philipa_240sx)
Of course we took the rogue in with the video/audio evidence which they admitted they heard. They couldn't reproduce the sound so, hey, hope it doesn't happen again! Well, today we drove out to the lake and voila! The wind noise problem occurred again!! Now, what are my chances that Nissan will simply allow me to exchange my vehicle for a non-faulty one (as is the case with other products!) I have 1800 miles on it only.
philipa_240sx
KW Ont
6-21-2007
 « Re: wind noise (OnlineUser)
Hmmm, these wind noise issues remind me of my 2003 Altima. There was some weatherstripping on the drivers side window that simply would not seal. Nissan did release a tech bulletin for it... a carefully placed piece of foam that would 'expand' the weatherstipping to seal the gap. Perhaps it's the same issue here?
jsizzle
08 nissan rogue
winslow arizona
8-14-2008
i just bought a 2008 rogue and i was having this same problem, tell your dealer to use an air blower around the mirror, in between the cracks where the mirror bolts on. if starts making the noise tell them to put some foam tape in between the mirror and the bracket it bolts up to(there are three little screws holding the mirror on the bracket, you can unscrew them threw the bottom). If they do this it should take of the problem. make sure they put it around the whole mirror or it will keep making the noise.
OnlineUser
Nissan Rogue S
Edmonton Alberta
8-1-2008
 « Re: wind noise (jsizzle)
Our problem seems to be something to do with the window seal. When we have it 99% closed no problem (other than it being louder inside than it should) and when we close it all the way the power windows let us, that's when we have the issue. Can't be the mirror then. Right? I am going to attempt to have Nissan simply give me a new vehicle if this one can't be fixed -- this is what would be done with any other product consumers purchase.
jsizzle
08 nissan rogue
winslow arizona
8-14-2008
My rogue was doing the same as yours, and what i did was put some foam tape in between the seems of the mirror where the mirror is bolted on. your dealer should try what i did. it unscrews at the bottom of the mirror, there is a little cover and when they take that off there will be three screws, once they take the screws off the mirror can hang there, then they can put foam tape everywhere.
ahhbeebee
calgary ab
5-14-2008
My noises seem related to roof rails. Only when the wind is coming in at a certain angle does the 'whistle' sound come about, and its often fleeting since it only appears to happen at certain traveling speeds and specific wind velocities.
It reminds me of the noise of crossbars, and snowboards on the roof of my old car.
janemackey
infiniti ex
weatherford ok
5-28-2008
 « Re: wind noise (ahhbeebee)
Anyone find any solutions yet? I just found this site after purchasing a new Rogue for my daughter. Wind noise is horrible!.....but of course didn't find that out until driving it home!......Please advise if you've had luck finding an answer. So far the dealer has replaced two pieces on either side of the front windshield they thought were causing a tunneling effect thereby making the noise. Didn't work. We are just trying to figure it out! Thanks.
» Return to Rogue Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
