is my ecu dead?
Kalypso
from a new swap, red top sr20 ecu #62
symptoms
- the starter cranks but motor doesnt turn over- attached a noid light to the injectors and it doesnt light up- I put the key and turn it to 2, (the notch before ignition) - the ecu light doesnt come on when I turn the key, - I cant activate the diagnostic mode, it does nothing. - I opened it up, but there are no visible burn marks.
I had a bad ground for my battery that I just replaced. Previously I may have flooded the ecu with current and fried it.... i dont know
what else should I check for?
Modified by Kalypso123 at 4:10 AM 7/10/2008
xpicer
Car: 1990 nissan 240sx
what harness are you using , maybe you got a black top harness , get the serial off the harness and check if you got injection pulse on all of the injectors, also if the computer is led is not on at all you will never get spark nor injection pulse
Kalypso
no light at all on the ecu... either of them ( I have two different ones. )no pulse on any of the injectors....
I bought it with a s13 that had this swap preinstalled. when the car crashed I took swapped motor,harness, and ecu over
ill be back with pictures, this is strange
xpicer
ok how about , are all of your fuses good , also do you have a power prove?
Kalypso
- what is a power drove?- it could be my fuse box, take a look.
*I took all the fuses out of the previous chassis and put them in here. replaced nearly all of them with my old working ones...
more pics.........
turn the key:
no light:
my ecu and a few misc cables not connected:
im just noticing these, but it might be normal
interior harness connections.....
a f*ckin mess... I dont know my way around this
bottom of the fuse box.
the whole picture of the ecu:.
ok. so back to the symptoms.
- no light unto the ecu....- interior lights and dash come on. headlights and blinkers work motor cranks... - everything else is silent.
what else help me think....
Kalypso
Kalypso
ill be back,
im takin a nap
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
so have you ad it running before.
the light on the ecu never comes on. unless your in diagnostic mode then it just blinks
so the motor is cranking?
are you getting spark? fuel? air?
Kalypso
no, this is the first time.
Ive had it running before, this ecu, harness, and motor we're in another chassis. I exported them all here to this on...
light never comes on? until I go into diagnostic?ok and how do i activate diag. mode.
rotate the nob counter clockwise and hold?
It does crank, but injectors and spark plugs get no juice.
none of those, it seems like everything on the upper harness is dead. I need to go through the fuses and relays...
I do have a fuse tester...
Modified by Kalypso123 at 1:58 PM 7/10/2008
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
why didnt you reuse the old harness that worked. and if you still have them i would sya go through and compare them.
Kalypso
I did,
I guess its time to try the relays
Kalypso
any other ideas?
from anyone?
xpicer
Kalypso
OK, I was instructed to check the ECU ground for current.
if its not getting current then its a relay/fuse/or the harness. if it is? the ecu is dead.
key is in
ecu ground wire scored
held up the + prong on the volt meter ( is this right? or do I also need to hook up the negative? )
no action, so electricity isnt making its way to the ecu... at all. bad wiring, bad fuses, or bad relays.
getting a fuse tester tomorrow, as well as relays from the Nissan dealership
something that was also interesting.
this relay is badly connected and alsmost completely free. blurry pics sorry. new ones coming.
the black wire goes to a ground.
there are four prongs, 3 are missing wires.
I wish I knew what it was for.
Modified by Kalypso123 at 10:57 PM 7/16/2008
Kalypso
Also I installed an Altima fan
you can see the bottom on both sides where I had to chop so it would fit. it slid in real nicely. maybe later ill paint the shround black again.
I've yet to wire it and and a thermo. I may also scrap my AC core and make a custom one, that ill put on the back of the intercooler with a fan attached.
Kalypso
bump
Kalypso
For those of you passers by... I sold this problem.
amazingly my car got towed a few days after i posted this thread and it took me three weeks to get it back.
finally i swapped ina new body harness (both fuse boxes and the loom)... and it worked... the motor fired up and was fine.
