adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 9:47 AM 7/9/2008 |
you should search. There's plenty of topics already on Godspeed.
Snoop with a 510?
 | Quote, originally posted by idahotuner » | | WAHT DOES THIS FAP MEAN |
| Quote, originally posted by Razi » | | Sometimes I push it closed with my butt. |
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (adrians_s13) | 10:31 AM 7/9/2008 |
im going to check that out. so do you have any suspension upgrades on yours? how much did YOU spend? ANY REGRETS?
ashibah83
Online
93 SUPA BLACK COUPE
St. Marys pretty much Jax, Fla Ga
10-14-2006
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 12:13 PM 7/9/2008 |
Stance GR+ coilovers, Battle Version arms( RUCA, rear toe, traction, and tension), suspension techniques REAR sway bar, Nismo Power Brace, Megan Racing strur tower bars, and a stock front sway barthe only regret I have is not doing a master bushing kit and rear subframe bushings.....but there coming
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (ashibah83) | 10:19 PM 7/10/2008 |
nice set up. front sway comming thru too or it's not that serious?
ashibah83
Online
93 SUPA BLACK COUPE
10-14-2006
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 8:12 AM 7/11/2008 |
i have the front sitting in my garage, i not sure when or if im going to install it, someone correct me if im wrong, but i believe i read somewhere that installing a larger frontsway bar will create more understeer, and a tendency to push, as i have it right now, i have almost a perfect amount of neutral oversteer...for the way i drive, so i think ill keep it that way
adrians_s13
Long Beach CA
6-29-2005
| « Re: suspension set ups, regrets? godspeed? (ashibah83) | 11:46 AM 7/11/2008 |
| Quote, originally posted by ashibah83 » | the only regret I have is not doing a master bushing kit |
if you have all BV arms... why would you get a master bushing set? Only thing you'll probably need out of that kit is just the bushings for the lca.| Quote, originally posted by FRnIsmO » | | im going to check that out. so do you have any suspension upgrades on yours? how much did YOU spend? ANY REGRETS? |
I have a lot of suspension upgrades. I dont know how much I've spent all together because I didn't buy them all at the same time... it doesnt matter how much I've spent though, cuz I dont buy my stuff at retail price  you want a good suggestion on what suspension to get? http://splparts.com. KTS coilovers are great inverted monotube'ed coilovers for the price. Their (spl) suspension arms are by far one of the best in the market.
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (adrians_s13) | 11:33 PM 7/11/2008 |
hey, thanks for the feedback and website. gr8 deals2
Kalypso123
Scarlett Pimpernel
redtop 90 coupe
Flushing, Queens NY
7-24-2007
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 3:14 AM 7/12/2008 |
I have JIC magic FLA 2's white line sway bars ES master bushings cusco sway barsthey came with my shell sans motor and I am greatful to death for them.
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Kalypso123) | 7:26 AM 7/12/2008 |
do you see yourself adding to the list?
Kalypso123
Scarlett Pimpernel
redtop 90 coupe
Flushing, Queens NY
7-24-2007
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 12:47 PM 7/12/2008 |
Yeah nismo power brace
 fron mulit link arms: front tension rods and lower arm ( SPL or tein )
 rear multi link arms. camber adjustment and all that ( the whole SPL set )
Fender Braces Roll cage ( 4 point nothing extreme ) Nismo Motor Mount set. ( or avid racing ) and lastly great TIRES... thats about it... even with my stock turbo the car would hand or drift like its possessed. Browse SPLparts.com's suspension section. it has every suspension piece imaginable.
Modified by Kalypso123 at 6:23 PM 7/12/2008
rbsileighty
92 S13 w/ RB20 04 AP2 GPW S2000 85 Z31 300zx 08 Versa 6MT
MI
2-9-2003
I think I've said this on a few posts... but it's not something you would have found in a searchIn order not to waste money... start with your core mods... ie coilovers, wheels and tires... and/or cage (which owning a hatchback you should install by default... 4pts minimum) Each of these mods will change the car in a very significant way so you will want to install them and drive the car before you decide you need all of the supporting arms. For the Nismo power brace that was mentioned... look at your stock setup before you buy that... box yours in and weld in a bar with gussets and you have the same thing. The other thing about that part is... do you really need a stiffer front end (especially with a S13) without a stiffer rear? My setup is extreme, but minimal at the same time. You don't need a cage as crazy as mine (actually taking the door bars out soon since I'm not really going to compete with my car anymore due to running a Z33 in T2)... but even before the cage when I only had the Kei Office XT's, stock Hicas sways I didn't feel I needed more arms/braces. The cage made a huge difference... along with my wheel/tire combo I'm very satisfied. I might get rear LCA's down the road but that's all I can think of off of the top of my head... Hope this helps... just hate to see people waste their money on parts they might not need
 The Project The Wheels The Cage
Red coupe
92 Nissan 240sx Coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (ashibah83) | 5:42 PM 7/12/2008 |
| Quote, originally posted by ashibah83 » | | neutral oversteer... |
 Random Hip Hop: Ronald Jenkees - The Fast Song - a piano jam
ashibah83
Online
93 SUPA BLACK COUPE
10-14-2006
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 9:17 PM 7/12/2008 |
yeah i know it sounds oxymoronic, but the car feels suprisingly balanced...with a slight bit of oversteer, but not snap oversteer like an s2000, a manageable amount, you can feel right when it breaks loose and then pull it back
Kalypso123
Scarlett Pimpernel
redtop 90 coupe
Flushing, Queens NY
7-24-2007
| « Re: suspension set ups, regrets? godspeed? (ashibah83) | 10:42 PM 7/12/2008 |
a lot of options here for you.go to mestizo.net he builds a flawlessly tuned s13 sr20det with all the footwork attached
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Kalypso123) | 3:23 PM 7/13/2008 |
lol what is that site about? i have some real basic work on my suspension, kyb sturts and tein springs...what would you guys think is the best next move?
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 3:26 PM 7/13/2008 |
adjustable sway barsWhat KYB do you have? GR-2?
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 3:48 PM 7/13/2008 |
yea, gr2z. i got them on a package on enjukuracing.com. your coupe has a sick drop by the way. what did you use?
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 3:52 PM 7/13/2008 |
Its really not that lowered, its mainly from turning I guess lol.It has KTS coilovers on it. People actually ask me quite often if I plan to modify it, or why I don't lower it... I dunno the difference between GR2z, and the GR2's... but adjustable shocks are a good thing... and the GR2 at least is pretty close to just being an OEM replacement. Whats the spring rate on those tein springs?
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 4:04 PM 7/13/2008 |
sorry about that, the i meant with an ('s) not a z, i guess thats a jersey thing to use z as a plural ending but the springs are 1.5 on the front and 1.2 rear. really entry level. [IMG] [/IMG] those are 17's (17z lol). i heard adjustablers are less secure...what do you think about that. does anyone else think so? thanks
Modified by FRnIsmO at 4:28 PM 7/13/2008
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 4:08 PM 7/13/2008 |
| Quote, originally posted by FRnIsmO » | sorry about that, the i meant with an ('s) not a z, i guess thats a jersey thing to use z as a plural ending but the springs are 1.5 on the front and 1.2 rear. really entry level. [IMG] [/IMG] those are 17's (17z lol). i heard nonadjustablers are less secure...what do you think about that. does anyone else think so? thanks |
Don't be a ricer, springs are not rated by their drop alone... I you are trying to make the car handle don't buy of "drop"
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 4:18 PM 7/13/2008 |
its a daily driver so i went for some handle improvement but not something unintentional droving over newark potholes could "body" or destroy. how low is your drop?
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 4:24 PM 7/13/2008 |
uhh... I set both the front and rear as high as possible while still keeping enough of the shock threaded into the lower mount to feel comfortable. What do you mean non adjustable is less secure? whats less secure? You mean the spring? thats why you buy springs and shocks to match... and don't buy stupid lowering springs with stockish rates.
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 4:29 PM 7/13/2008 |
actually ment adjustable...hehe, btw heard weededed, not pad at all check this http://www.youtube.com/watch?v=AX4HLFMnKXc
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 4:30 PM 7/13/2008 |
How would being able to adjust the valving in the shock be less secure?
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 4:31 PM 7/13/2008 |
thats it, the fact that its adjustable
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 4:33 PM 7/13/2008 |
| Quote, originally posted by FRnIsmO » | | thats it, the fact that its adjustable | ???? what is less secure about that? What do you even mean by secure?
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 4:37 PM 7/13/2008 |
firm is what i mean, as in firmly secured
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 4:39 PM 7/13/2008 |
| Quote, originally posted by FRnIsmO » | | firm is what i mean, as in firmly secured | lol what? firm as in how soft or firm the shock settings is?what is firmly secured? Am I right in guessing you don't really know what you mean and its a random thing you read somewhere and didn't really understand but remembered for later?
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 6:25 PM 7/13/2008 |
lol somewhat, but something like the left side might drop more then the right after a few potholes...
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 6:35 PM 7/13/2008 |
| Quote, originally posted by FRnIsmO » | | lol somewhat, but something like the left side might drop more then the right after a few potholes... | Usually when people say adjustable shocks, they mean the actual valving inside the shock is adjustable to control how much resistance it offers to movement. I guess if you set them on two different levels one side COULD drop more... but no, really that would all be a quality control issue... so don't buy cheap crap The only real issue is that you get more ways to set them wrong... but if you don't notice what the changes you are making is doing chances are that its not that important anyways... once you get a feel for it its really nice to have as you can effect the balance of the car as you do other modifications... or even just to fit your preferences and use of the car.
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 6:37 PM 7/13/2008 |
cool, thanks for the info
Red coupe
Pomona CA
9-15-2004
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 3:35 AM 7/14/2008 |
lol, well thanks for being willing to listen and not getting bent out of shape when someone questions if you know what your talking about.I'd encourage you to read... a ton... but be weary of reading too much of things like this thread. People will be so quick to say "OMG get 10/8 coilovers! stiffer!" when they are never gonna be on a track and its not too hard to go stiff enough to lose grip on bumpier surfaces like streets and mountain roads. Hell even KTS at 8/6 loose some grip on roads that aren't ideal. Also look at the stiffness of the the springs, not just the drop... stiffness will be given in the force (quite you physics majors, close enough) required to compress the spring a certain amount. Typically stuff for imports will be in killograms per mm of compression, so the springs on the front of KTS coil overs take 8 kilograms of load to compress 1 millimeter. Domestics are often given in pounds per inch of compression. Stock on a 240 is about 2kg/mm front and read iirc, should be in the stickies at the top of the forum. Be sure not to make the mistake of comparing spring rates from one type of car to another... Honda spring rates will seem crazy, because the spring is further inboard so the suspension arm acts as more of a leveler, so a stiffer spring is needed to give the same rate at the wheels. http://forums.nicoclub.com/zerothread/11638 This is a good thread, with a fairly comprehensive list of 240 spring rates. If you have S-tech those actually don't look too bad... for a street setup RSR race springs, a GOOD pair of adjustable shocks, ground control coil overs, camber plates(if needed/wanted), adjustable swaybars (I have whiteline, and progress, progress is damn good... but i dunno if they are still made? I couldn't find them thats why I went with whiteline)... AND MOST OF ALL GOOD TIRES (all suspension works just seeks to optimize the tire...it is the ONLY thing holding you to the ground, remember that.) I think the above would kick some ***. I haven't owned or even ridden on the RSR springs, but the rates look good... and some respectable guys here have spoken highly of them. Of all the areas I would try hardest not to skimp on shocks or tires. Most the other pieces are just metal. Springs you gotta trust that the maker is giving you good rates... but thats easy enough to just steal from another company, and the manufacturing isn't overly difficult. But shocks... quite a bit to skimp out on or mess up in manufacturing, not so much so that they will break... but dampening the spring can be a demanding job, and the smoother the load you can put on the tire the better. Tires also are incredibly complex, your best answer is to say **** tread wear and pick up something like a Falken 615, or the Hankook RS-2 (did I mess that up?) I just finished up reading about 75 pages of pretty damn detailed info on tires...just to give you an idea of how complex they are...and that doesn't even include going into the chemistry of tread compounds. I think I have rambled sufficiently for now....
FRnIsmO
240sx fastback
bayonne NJ
6-28-2008
| « Re: suspension set ups, regrets? godspeed? (Red coupe) | 7:12 AM 7/14/2008 |
lol its definatlyl more complicated then "gas and ignition" but it all makes sense...i love the faq page you listed i never read that b4. i'm glad this is more then just a place to check out pics of member cars and vent on common problems. this is actually my first forum (ever) so i am pritty slow (NeWb) but i love the info and feedback. thanks, when im questioned i understand myself and what i know do bring it on lol.
Kalypso123
Scarlett Pimpernel
redtop 90 coupe
Flushing, Queens NY
7-24-2007
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 7:26 PM 7/14/2008 |
here is a very useful article on the affects of suspension tuning google any terms you dont know like "Roll resistance" http://www.wtrscca.org/tech.htm all the suspension parts you'll ever need have been posted somewhere in this thread. welcome to NICO
Eddie
1995 240sx se
San Antonio TX
12-30-2003
| « Re: suspension set ups, regrets? godspeed? (FRnIsmO) | 10:57 PM 7/22/2008 |
| Quote, originally posted by FRnIsmO » | what would you guys think is the best next move?
TIRES. Set up: I have eibach prokit, tokico blues, polyurethane T/C bushings, aluminum subframe inserts, front strut tower bar, suspension technique sways, yokohama s.drives, VLSD differential.
Regrets: I would have invested in linear rate springs with higher spring rates and better struts. Thats what I will do when money allows. Dream street set up is RSR race springs, Koni yellows, and adjustable upper mounts.
"I have many leather bound books...My apartment smells of rich mahogany"
