sloppy shifter
cb_240
Car: 1993 Nissan 240sx SE, RB25DET swap
driving my car today and everything was fine, shifting smoothly minimal play in the shifter when its in gear. parked the car for a bit and came back out to it and the shifter seems very sloppy, lots of free play in it while its in gear so i took it home and took all the rubber boots off to see but i couldnt really see anything. my first guess is a shifter bushing? any other ideas
Modified by cb_240 at 11:50 AM 7/8/2008
s13point5
Car: 89 240sx
yea i would guess shifter bushing. what RB do you have? i can get you the part number for the bushing if you have the RB25
cb_240
yeah i have the 25 and that would be awesome
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
More than likely the bushing on the bottom of the shifter, Mine busted and I had this problem. I made my own, Didn't think they made a replacement. But they might.
cb_240
think i found a part number so i punched it into a nissan site to make sure the number was still being used and wasn't replaced or anything and its calling it a socket assembly-control lever
does this sound like it?
cb_240
rb25drag wrote:More than likely the bushing on the bottom of the shifter, Mine busted and I had this problem. I made my own, Didn't think they made a replacement. But they might.
how did you make your own?
will the s13 bushing work? I found the part number for that, 32861-h7301 and figure it may be worth a shot
and if the stock s13 bushing works then id imagine the cusco one would work as well http://www.aspecproducts.com/s...earch
Modified by cb_240 at 8:46 AM 7/9/2008
Modified by cb_240 at 8:48 AM 7/9/2008
rb25drag
I made one out of aluminum on the lathe we had at school at the time. took me about 10 mins.
Im sure the KA one will work, I used my entire Ka shifter in the rb25 trans.
s13point5
Car: 89 240sx
RB25DET Shifter BushingOEM Nissan Part# 32861-01G00USDM Part
this is the part number i used. called up to nissan and ordered it and they had it within a couple days. its a bushing for a truck
rb25drag: ive done some research and found that alot of people are saying the KA shifter will not work in a RB25 transmission. how did you get it to work?
rb25drag
It was an aftermarket short throw, It basically fell right in, Had to get some longer bolts for the clamps, But works great.
This is the same shifter I bought about 5 years ago:
http://cgi.ebay.com/ebaymotors...86035
s13point5
Car: 89 240sx
rb25drag wrote:It was an aftermarket short throw, It basically fell right in, Had to get some longer bolts for the clamps, But works great.
man im so tempted to buy that but im afraid its not gonna work because of everything else i have read.
rb25drag
If you have the Rb25 trans I know it will work b/c Mine did. But you will have to buy some Longer hex bolts, The ones they supply are too short for the 25 trans.
slowrb20
Car: 1992 Nissan 240sx coupe
i have the same short shifter on my rb20 too. it works fine. not sure on the bolts because it was already in the car when i got it.
Bluefire
RB20 and RB25 shifters and bushings are different sizes. The RB25 uses a bigger bushing versus the RB20/S13/KA.
-Bluefire
matafied
Car: 1989 240 rb25det 1992 240 rb25det
yea idk about that the shifter it self will work i have used it, but the bushings are different sizes. but as far as bolting up a short throw idk. the rb25 has a slant (45 degree angle ) to it, ka and rb20 sits flat. their was a wright up way back when
cb_240
well the bushing was indeed the problem, got that all sorted out now
used the s13 ka shifter bushing, nissan part number 32861-h7301 and with a few light taps of the rubber mallet it went on great
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
cb_240 wrote:... and with a few light taps of the rubber mallet it went on great
Thats the way to do it! If it does not fit.. bigger hammer! </sarcasm>
But seriously, I know what you meant.
cb_240
figured id post that it actually fit so any idiot like myself in the future knows the ka bushing works
redtop240
Car: 92 240 RB20 Coupe
So question for you all, my RB20 has that problem and it has a lot of ****er play. How bad is that to have, and is it something I need to fix ASAP?
cb_240
its a $3 part at most
redtop240
Why did i get edited for the word shifter play? Anyways what is the part name i would need to order? And how hard is it to install?
