ca18detgabby
92 s13 ca18det
lake mary fl
2-10-2007
| « Re: I have the weirdest CA's ever! (eds13) | 11:34 AM 7/7/2008 |
I would guess(just a guess as I dont know anything about your situation) that you have an issue with ignition relay or maybe the switch under the clutch(god I can never remember its name) that is the safety switch under the clutch.if you have fuel, spark and air......... you should be running regardless of the timing atleast you should run. can you push start it? though I hate starter fluid what does that do? how is the fuel in the tank?(old or new) is your ECU good? is the maf wired properly? could you start at what you have gone over, so that we can take it from there? I mean there is a million and one possibilities....... is it stock trim? tunes? I suppose you could have a massive vac leak if it is trying to start and never does? or the maf isnt hooked up correctly maybe?
 | Quote, originally posted by r34 gtr » | | Who gets rid of their CA's? People who suck, thats who. |
Bwana
Super Moderator
'89 240 coupe RB25DET '77 MGB CA18DET
Fort Collins CO
9-16-2004
ZOMG! Eddie posting on NICO again?!!?!??!!
 My cars are for sale! Do the right thing and Buy them!!! MGB Roadster! 240sx Coupe!
eds13
Special Ed
We are the all singing all dancing crap of the World
11-1-2004
I'm disparate man, lol. maf is wired correctly. tried several different ecus that i know are good. fuel tank is fine, with clean 93 in it. havent tried starter fluid. it has a front mount, and 3" downpipe, 2.5" exhuast, stock turbo, and injectors, and everything else. ninja edit: it also cranks fine.
Modified by eds13 at 4:22 PM 7/7/2008
eds13
Special Ed
11-1-2004
oh crap! just noticed you finally have more posts than me! bwahahaha
Bwana
Super Moderator
Fort Collins CO
9-16-2004
| « Re: (eds13) | 1:06 PM 7/7/2008 |
No fire whatsoever? How do the plugs look?
eds13
Special Ed
11-1-2004
wet, almost overly wet, almost
ca18detgabby
92 s13 ca18det
lake mary fl
2-10-2007
| « Re: (eds13) | 1:50 PM 7/7/2008 |
what happens when you crank it? video and or images would be great.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
maybe recheck timing
1990 240sx CA18DET 32k miles Greddy FMIC R32 VLSD NiSmO tranny and engine mounts NiSmO CA strut bar SoOn tO cOmE : honestly, i just dont know anymore
articzap
Online
1990 Nissan 240SX - CA Swap
Depew NY
3-18-2008
| « Re: (ca18detgabby) | 2:25 PM 7/7/2008 |
I had a very similar problem.3/4 injectors were stuck.
 240 Hotness
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Although it cranks fine, does it have partial combustion, or nothing at all?
Project "Baller" http://forums.nicoclub.com/zer...r-lol Supported by: Wes Engines - Lismore Australia
eds13
Special Ed
11-1-2004
cranks just like it should, with the occasional pop,( every 30 seconds?)injectors aren't stuck...
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
Ok cool, have you performed the ECU diag 3?
eds13
Special Ed
11-1-2004
ecu's givin me no codes
trevr
1991 Nissan 240sx LE
Endicott NY
1-12-2007
| « Re: (meminto) | 5:53 PM 7/7/2008 |
How about this guy? Is it working hard or hardly working....
Modified by trevr at 9:07 PM 7/7/2008
articzap
Online
Depew NY
3-18-2008
| « Re: (eds13) | 6:23 PM 7/7/2008 |
How do you know the injectors aren't stuck open. You don't.
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
| « Re: (eds13) | 6:28 PM 7/7/2008 |
No codes at all or code 55 (ie normal no errors)
eds13
Special Ed
11-1-2004
55.i hear them pulsing... but i should be able to get it to fire, just not, not do anything.
zmannz
1988 rx7 w/ dry sump ca18det coming soon....
Rock Hill SC
12-12-2004
| « Re: (eds13) | 7:29 PM 7/7/2008 |
I know its basic, but check your grounds and all connectors to be sure they are clean, tight, and appropriately connected. I once picked a 90 supra turbo for 500 bucks with "electrical" problems. Turned out the MAF wires were slightly smashed and there was a ground loose, no other problems whatsoever.
1988 Mazda RX-7 with dry sumped ca18det in the works! Full picture gallery: http://s169.photobucket.com/albums/u226/zmannz/
articzap
Online
Depew NY
3-18-2008
| « Re: (zmannz) | 7:36 PM 7/7/2008 |
I bet $500 that you're flooding the motor with fuel or you're not getting enough fuel.
eds13
Special Ed
11-1-2004
check all the grounds a billion times lol. i'll double the mafs wiring....ok...so throw another set of injectors in it?
articzap
Online
Depew NY
3-18-2008
| « Re: (eds13) | 8:21 PM 7/7/2008 |
If you have a spare set, I'd give it a shot. Check the resistor pack also.A word of advice, you can change injectors without removing the intake manifold. Takes about 2 hours doing it that way.
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
Timing belt jumped...
After a long break, Project CA S14 is revived! Check it out NOW!
greensx
93 240sx hatchback
san antonio tx
5-5-2006
| « Re: I have the weirdest CA's ever! (eds13) | 9:31 AM 7/8/2008 |
Any chance did you do a 5speed conversion? If so check you clutch neutral safety switch(if thats what you call it, basically the wires that connect to the auto shifter) in the cabin. Mine was giving me hell but once i plugged those up my car started turning on like normal.
eds13
Special Ed
11-1-2004
| « Re: I have the weirdest CA's ever! (greensx) | 12:53 PM 7/8/2008 |
| Quote, originally posted by articzap » | | If you have a spare set, I'd give it a shot. Check the resistor pack also. A word of advice, you can change injectors without removing the intake manifold. Takes about 2 hours doing it that way. |
yeah i know, i've done it, it sucks. | Quote, originally posted by float_6969 » | | Timing belt jumped... |
checked it, its fine. | Quote, originally posted by greensx » | | Any chance did you do a 5speed conversion? If so check you clutch neutral safety switch(if thats what you call it, basically the wires that connect to the auto shifter) in the cabin. Mine was giving me hell but once i plugged those up my car started turning on like normal. |
nope, stock 5 speed.
Ca_Silvia
Calgary
11-18-2005
| « Re: (articzap) | 2:07 PM 7/8/2008 |
2hrs?!? 40 mins tops for R and R /threadjack
Aaron
Acecool
1989 240SX Hatch Pig KA24E 126k
Charleston SC
9-8-2006
| « Re: (Ca_Silvia) | 2:34 PM 7/8/2008 |
Ill go with either timing.. or reversed fuel lines......give me a picture, and a sound clip :-)
1989 Nissan 240SX With KA24E :: 0-45 in 5.7, 0-60 in 7.8 With RB20DET :: WIPMY S13 PARTS FOR SALE http://www.carolinanissans.com...12360
articzap
Online
Depew NY
3-18-2008
| « Re: (Ca_Silvia) | 2:40 PM 7/8/2008 |
Always takes longer the first time. We all know this.
eds13
Special Ed
11-1-2004
i'll see what i can do for a sound clip. i had to rob its ingnitor for a buddys car to get it running lol
splintercell
1989 nissan 240sx hatchback
BG VA
3-19-2005
| « Re: (eds13) | 11:20 AM 7/9/2008 |
are all you relays still in fuse box? didnt remove them for anything? also check fuses under dash...for some reason my car was doing something similiar and it was some off the wall fuse that was blown. doenst hurt to check.
BUILD THREAD http://forums.nicoclub.com/zerothread?id=339213
r34 gtr
ugly black 89 240sx hatchback
Huntsvegas AL
12-29-2002
Check your fuel pressure. Kthx.
I'm like the Gangstalicious of NICO.| Quote, originally posted by Jesda » | | Side note: People in the mortgage industry do a lot of cocaine. |
| Quote, originally posted by float6969 » | | It's not that I think he's retarded. It's that I was the one that gave him his gold medal at the special olympics. I KNOW tim is retarded. I hope I never meet him in real life actually. I'm like 6'2" 185lbs. Tim is prob like 6'7" 300lbs and eats live baby sheep for snacks during the day. |
boost_boy
1990 sentra w/ CA18DET
Miami Fl
11-14-2002
| « Re: I have the weirdest CA's ever! (eds13) | 1:48 PM 7/9/2008 |
Just because it exhibits spark and fuel doesn't mean it's supposed to run if other issues are hampering it. Spray starting fluid into a vaccum line leading into the intake or any hole that will get the fluid into the runners and then try and start it. If it cranks and runs for a second, you're either having fueling issues such as your fuel lines being crossed, etc, etc. If your ignition is weak (ie weak battery), the CA will not crank. And lastly, if the orange near the glove compartment is not connected or it's powered source is dead, it will not crank. Try those things and see how it goes. Dee
Who's selling their CA18 next ? Forged pistons are no insurance for ignorance . Spending money foolishly doesn't equate to a high hp car . Being cheap all the time equates to a waste of time And lastly, I'm not done; for I've only just begun, so stay tuned Dee
eds13
Special Ed
11-1-2004
fuel pressure is at 37 what orange? you mean the dash plug?
meminto
S13 Silvia CA18DET
Brisbane QLD
4-28-2008
| « Re: (eds13) | 4:10 PM 7/9/2008 |
Hrrrmm... you need pages ef-ec 39-42 of the workshop manual...However if you already have it, it may be the euro version.. ignore base timing in this (if you have jdm ca18) as the jdm base timing is 10 +- 2
mbmbmb23
Charlotte NC
8-19-2004
Ecu not plugged in all the way? Do you have an SAFC wired in? Have you tested your coil packs? My guess is timing.
eds13
Special Ed
11-1-2004
yes ecu is plugged in all the way. no i dont and yes. i'm getting spark to all 4 cylinders.
articzap
Online
Depew NY
3-18-2008
| « Re: (eds13) | 8:04 PM 7/9/2008 |
Have you tried swapping the injectors yet?
lostmenoggin
1989 Nissan 240sx ca18det swapped
Bluemont VA
3-16-2006
| « Re: (articzap) | 8:46 PM 7/9/2008 |
If you have another CAS laying around try swapping it out.
eds13
Special Ed
11-1-2004
| « Re: (lostmenoggin) | 11:54 AM 7/10/2008 |
not yet lol. i have no good ignitor right now.and yeah, i tried that.
Acecool
Charleston SC
9-8-2006
| « Re: (eds13) | 7:57 PM 7/10/2008 |
Did you try the fuel lines yet?
| First 1 2 > Last |
