 Flywheel Starter Issues
Unreal
Bennington VT
1-13-2008
Hey guys,
I just had a bunch of work done to my 300Z. New clutch, flywheel, tranny, and one piece driveshaft. However, the car no longer starts and my mechanic and I believe that it's because of the fidanza flywheel. Does anyone have any clue how to remedy this problem? You can hear the starter spin, however it just won't start
MinisterofDOOM
Maxima Moderator
Layton UT
5-19-2004
 « Re: Flywheel Starter Issues (Unreal)
Is the fidanza flywheel the same size as stock? I'd contact Fidanza and see if it's supposed to work with the stock starter location.
-The MinisterofDOOM
|The Q of DOOM| - |The Maxima| - | Hear my Q!|
4.08 VLSD, NICO 8-way ECU, full exhaust with custom headers,
Tokico Blues with Eibach springs, Stillen FSTB, 20mm RSB, 255 rear rubber.
Of course I forgive you. That is your God's function. Your crime is forgiven.
However, your stupidity requires a response." -Leto Atreides II
mtcookson
Maxima - VG/VE Moderator
Howard KS
11-21-2002
Do you have a twin turbo Z or NA? If NA its not likely an incorrect flywheel as the NA flywheel is the smaller of the two. It could just be the starter itself, may be that the solenoid or bendix is acting up, which is what engages the starter with the flywheel. When either goes bad it will cause the exact problem you're having where its not engaging but is spinning.
If you need any large items shipped like engines or even front clips, I can help you out. Just go to AssociatedShippers.com and get a quote.
Unreal
Bennington VT
1-13-2008
 « Re: (mtcookson)
Well it turns out it's the inncorrect flywheel. It blew the starter to bits and the teeth on the flywheel are obliterated.
Thanks Specialty Z for awesome shipping!
mtcookson
Howard KS
11-21-2002
That's interesting... do you know which one they sent you?
Unreal
Bennington VT
1-13-2008
 « Re: (mtcookson)
I wanted an RPS non-turbo but what I suspect I got is a Fidanza Turbo
Unreal
Bennington VT
1-13-2008
 « Re: (Unreal)
Alright, so the flywheel isn't the problem, it's something else. I had the flywheel replaced with a Fidanza, and had problems. I put a OEM flywheel in, and replaced the starter and I still have the problem...
The transmission came with the car so I'm wondering if it might be a turbo tranny which is making the starter and flywheel not match up?
If it could be, how can I tell? Is there a serial # on the tranny that I can look up? I have a service manual.
Unreal
Bennington VT
1-13-2008
 « Re: (Unreal)
Bump?
mtcookson
Howard KS
11-21-2002
Sorry for the delay, I somehow missed the post.
I'm not sure what the easiest way to check would be maybe besides measuring the thickness of the starter mounting point, the TT's should be a tiny bit thicker I believe to make up for the slightly larger TT flywheel.
I suppose if you had the TT tranny with the NA flywheel it could potentially not mesh with the starter properly causing the teeth to break. If you can, measure the thickness of the starter "flange" and I'll compare that to the TT trannies I have. I do have an NA tranny but its in a car at the moment so won't be able to measure it. Maybe we can figure something out based on that. That's all I can think of at the moment.
Unreal
Bennington VT
1-13-2008
 « Re: (mtcookson)
Well I decided to throw the old tranny back into the car. I am hoping the grinding that was in the tranny was because the clutch was so bad. Lets see how it goes.
I am assuming it didn't mesh because the turbo flywheel is larger making the starters position slightly farther out. I just hope I can get this car back. I've been driving a tundra, which I really shouldn't complain about
mtcookson
Howard KS
11-21-2002
Yeah, I bet the starter gear slammed into the flywheel causing the destruction.
Unreal
Bennington VT
1-13-2008
 « Re: (mtcookson)
Yea my mechanic called and thought there was no difference at first. Then he took some time and saw that they are slightly different. Thanks Nissan, for the matching bell housing and no difference to the untrained and even trained eye
» Return to VG30 / VE30 Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
