240_newb93
'93 240
Los Angeles ca
6-22-2008
| « Re: 89 Nissan 240SX Power Window...help!!! (lightsource) | 9:29 PM 7/27/2008 |
did you get your problem solved yet? looks like u made some progress messing with the wires or w/e... could be the fuse
before God aim: loahatethme
rexify
1990 Gray 240sx sr20det 2005 Black WRX ej20
Boston MA
12-19-2007
| « Re: 89 Nissan 240SX Power Window...help!!! (lightsource) | 5:04 PM 8/3/2008 |
I had the same problem. I heard a click when I tried to roll down the drivers side but it wouldnt go down. PAssager went down with no problem. I switched the amp and it fixed it.
holycrapitsJR
1989 240sx
Sarasota FL
2-13-2007
| « Re: 89 Nissan 240SX Power Window...help!!! (rexify) | 3:56 PM 8/7/2008 |
ugh, same thing happen in my car, hot in FL too. I bought a "working" amp off ebay and it still clicks. drivers side no worky. pass. side okie dokie. if I wiggle the amp it works sometimes, sounds like a short inside the amp mebbe? anyone ever try to take one apart?
N053B133D
1990 240sx Hatchback
Eugene Oregon
9-7-2004
| « Re: 89 Nissan 240SX Power Window...help!!! (holycrapitsJR) | 3:35 PM 9/29/2008 |
| Quote, originally posted by holycrapitsJR » | | ugh, same thing happen in my car, hot in FL too. I bought a "working" amp off ebay and it still clicks. drivers side no worky. pass. side okie dokie. if I wiggle the amp it works sometimes, sounds like a short inside the amp mebbe? anyone ever try to take one apart? |
Mine did the same thing, tore it apart (there's no way to get into it without destroying the casing) and sure enough, one of the contacts on the board was all scorched. I bought a new (used) one and popped it in, worked for a week and now it's the same story as the old one. Now i'm wondering if these things just break a lot or if the motor is shorting out and causing too much power to go through the relay.....
kuroneko
'92 240sx hatch
New Orleans LA
8-4-2007
and yet another situation. same thingpassenger works, other doesn't. has the clicking. I tried switching the motor with one that i knew worked. NOTHING I tried using the amp off of my buddy's car (both windows work on his) and NOTHING. So i'm not really sure what the problem is. maybe there is a short somewhere in my wiring.
N053B133D
Eugene Oregon
9-7-2004
| « Re: (kuroneko) | 3:24 PM 11/6/2008 |
| Quote, originally posted by kuroneko » | and yet another situation. same thingpassenger works, other doesn't. has the clicking. I tried switching the motor with one that i knew worked. NOTHING I tried using the amp off of my buddy's car (both windows work on his) and NOTHING. So i'm not really sure what the problem is. maybe there is a short somewhere in my wiring. |
Just tore my 2nd dead relay apart and found that the same contact on this one is burnt out as on the last one. I looked at the wiring diagram to see how much resistance the power window motor is supposed to have but I couldn't find it. Anybody happen to know? Otherwise I'm gong to test the passenger side with my ohm meter and compare that to the driver side...I couldn't imagine that it would be anything else though. As far as your problem goes, you should check to see if you're getting power from the harness to the relay.
Verndogg77
1990 240sx hatch
newport news va
10-25-2008
this must be another common occurrence in these cars. my driver's side window does the exact same thing. i used to be able to pound on the door panel a couple of times and it would work but not anymore.
holycrapitsJR
1989 240sx
Sarasota FL
2-13-2007
| « Re: (Verndogg77) | 6:53 AM 11/14/2008 |
I bought 3 new amps in the couple months. Then I figured out you could just solder the contacts back together. the new ones kept burning out in different places though. anyways, after I repaired one I have not had any trouble with it. Maybe they all have just one weak spot and if you fix it then you're good...and it IS possible to open the amp without destroying the case, you just gotta know where the clips are(2 on top and one on the bottom) I have pictures if anyone wants
Verndogg77
1990 240sx hatch
newport news va
10-25-2008
| « Re: (holycrapitsJR) | 12:15 AM 11/15/2008 |
yes! please post pics!
holycrapitsJR
1989 240sx
Sarasota FL
2-13-2007
| « Re: (Verndogg77) | 2:01 PM 11/18/2008 |
actually, I found this... http://forums.nicoclub.com/zerothread/244885 easier than posting my own pictures
Ladreik
92 nissan 240sx se
Ames Iowa
11-28-2008
I need help with my power window assy, Passenger side went down but not up I could not find much info on diagrams and such but i am getting voltage to the switch. I did find one forum post of the power window Amp (or encoder) So i decided to search for it to test it... problem is I cant find it. From what I read it is connected with 2 screws but where is it located.
N053B133D
Eugene Oregon
9-7-2004
| « Re: (Ladreik) | 11:12 AM 11/29/2008 |
| Quote, originally posted by Ladreik » | | I need help with my power window assy, Passenger side went down but not up I could not find much info on diagrams and such but i am getting voltage to the switch. I did find one forum post of the power window Amp (or encoder) So i decided to search for it to test it... problem is I cant find it. From what I read it is connected with 2 screws but where is it located. |
It's behind the door panel, just follow the bundle of wires that comes from the switch and it will lead you to a white rectangular box.
