themadscientist
RB/Skyline Moderator
staring down at you with disdain from the
spooky mountaintop castle
11-12-2002
| « Re: Most power in the world? (Giallo spyder met) | 1:06 AM 7/4/2008 |
most big power CAs in the past did not use the stroker kit. That big swing limits RPM and the lil guy has to scream to eat enough air to make big numbers. On the street light to light it's a benefit but if you want maximum power and top end it's a step backwards IMO. I was even thinking about destroking the CA.
ks13
89 Silvia K's
Southern NH
9-3-2006
| « Re: Most power in the world? (Giallo spyder met) | 2:12 AM 7/4/2008 |
cars coming along well I take it
Giallo spyder met
Nissan 200sx -92 Euromodel
Jonkoping
2-15-2007
| « Re: Most power in the world? (ks13) | 2:08 PM 7/4/2008 |
No hp numbers? Or dynopaper?
themadscientist
11-12-2002
| « Re: Most power in the world? (Giallo spyder met) | 3:33 PM 7/4/2008 |
at this point info vids and pics of CA18s is like bigfoot sightings unfortunately. The 600s is the most anybody was claiming, Munson and Norris. I saw a passing reference to a 700hp 1.9 Silvia with a T88 but only once. That leads me to believe it was a typo or it blew up; a 700hp CA18 would have been very article worthy.
boost_boy
1990 sentra w/ CA18DET
Miami Fl
11-14-2002
| « Re: Most power in the world? (Giallo spyder met) | 4:13 PM 7/4/2008 |
| Quote, originally posted by Giallo spyder met » | No hp numbers? Or dynopaper? | Dude, just handle your own business and stop chasing ghosts. Push your own CA to the outer limits and then see where you stand against those that have come before you and those (like myself) that are presently trying to push this engine to its limits. Be your own target and set your sights accordingly. Dee
Who's selling their CA18 next ? Forged pistons are no insurance for ignorance . Spending money foolishly doesn't equate to a high hp car . Being cheap all the time equates to a waste of time Dee
DALAZ_68
240sx
Los Angeles CA
4-9-2007
| « Re: Most power in the world? (boost_boy) | 2:30 PM 7/6/2008 |
| Quote, originally posted by boost_boy » | | Dude, just handle your own business and stop chasing ghosts. Push your own CA to the outer limits and then see where you stand against those that have come before you and those (like myself) that are presently trying to push this engine to its limits. Be your own target and set your sights accordingly. Dee | well put Dee...
1990 240sx recently swapped CA18DET 32k miles Greddy FMIC and Hot pipe R32 VLSDSoOn tO cOmE : 5 lug brake upgrade, R32 MAF,KA TB,444cc injectors, aluminum one piece driveshaft, bucket with 4 point harness, Greddy BOV, Standalone,turbo timer...
jt15833
7-9-2005
| « Re: Most power in the world? (DALAZ_68) | 4:51 PM 7/6/2008 |
boost boy and chosen one why you guys knocking this man so much. first he asks about max block pressure/power and chosen thinks he doesn't know that different turbos @ different psi flow different amounts of air.this stuff happens to much you guys are making assumptions off his question and responding to that, not the actual question at hand. As inspirational as your posts are I'd stick with the ole "if you don't have anything informative to say don't say it at all"
ks13
89 Silvia K's
Southern NH
9-3-2006
| « Re: Most power in the world? (jt15833) | 4:57 PM 7/6/2008 |
^agreed^
Nicksemianiw
JDM 89 Silvia K's
Ottawa ONT
1-21-2005
| « Re: Most power in the world? (ks13) | 9:32 PM 7/6/2008 |
I have a video of a yellow Silvia S13 with a CA18DET laying down like 700+ WHP I'd host it if I knew how lol.
Shift-Z32 *squak* What no Bov? (SOLD)Shift-S13 *pssssssssshhhhhh waaaa baaaa *backfire* baaaa baaa* Hitting boost and going sideways :D
meminto
S13 Silvia CA18DET
Lismore NSW
4-28-2008
| « Re: Most power in the world? (Nicksemianiw) | 9:50 PM 7/6/2008 |
Upload it to youtube!! I would love to see that!!!
Project "Baller" http://forums.nicoclub.com/zer...r-lol
dash
s13 ca18
dirty south
5-5-2006
I would think any response to such a broad/vague question would be appreciated. I feel his curiosity, but can understand exactly where boost_boy is coming from. "Build it yourself and find out" is the only true answer to be honest. So much goes on behind the scenes in the real world vs the internet. Dyno 'numbers' and quick ETs may look impressive at face value, while telling you nothing.... like, did it blow up 2 minutes later... or was the car a tin-can... was water/alky inj used... nitros.... etc...Mobne runs oe nissan crank and bearings. Simlar? turbo ~2bar, with 260/8.8 tomei cams. 497hp on hi-grade pump gas ? I'd start there for a hi-strung target and try to improve on it.
boost_boy
Miami Fl
11-14-2002
| « Re: Most power in the world? (jt15833) | 9:39 PM 7/7/2008 |
| Quote, originally posted by jt15833 » | boost boy and chosen one why you guys knocking this man so much. first he asks about max block pressure/power and chosen thinks he doesn't know that different turbos @ different psi flow different amounts of air.this stuff happens to much you guys are making assumptions off his question and responding to that, not the actual question at hand. As inspirational as your posts are I'd stick with the ole "if you don't have anything informative to say don't say it at all" | Some of you knuckle heads don't read well. Obviously the information on the internet is minimal, so again, it's time to stop chasing ghosts and/or hearsay or rare internet sightings and go pave your own way. Oh yeah jt15833 and ks13, I think I've earned the right to be able to pass on such a comment to someone that has great aspirations from the CA18DET. I've built better than 30 CA18s and have done some damage to a few of them, but never have I seen one trash it's block with my naked eyes. I've pumped over 30psi of efficient boost from a 60-1 through an engine I'd built on pump gas with 3 people in a fully loaded S13; only to tear down the engine out of curiosity and see little to no wear on bearings, rings and pistons. Now, something could go wrong and send a rod outside of a freshly built CA18 with saaaay: solid lifters, expensive rods and pistons, etc, etc, etc. Bottom line is anything can happen at anytime or he could very well achieve his objective, but we just don't know. After 11 years of dealing with the CA, I happily stand behind my post. Not knocking the man, his ability nor his engine, but to be chasing pipe dreams is an understatement. One should do themselves a favor and make their own history with this motor and not worry about who has the biggest crank if you understand what I'm saying. And by no means am I one to distract anyone, but in order to run with the best or to try and get into the league with the best, one most focus on himself, his personal contributions and dedications to his cause (first and foremost). Dee
the_grey_john
1990 Nissan 240SX HB - Manual
Houston TX
7-8-2008
^spoken like a true sage...^
"Is it just me or as 240SX become synonymous with SR20? Maybe some people like RB's huh?"
