New Member Introduction
Nissan 350z / Nissan 370z general community discussion forum
JETPILOT
Hi... I'm new here. I made a post and some people requested some more info on it. So I thought I would make an intro post.
My car is a 2004 Chrome Silver Track model. Over the last 4 years I have been modifying it for road racing. My home track is Sebring and I am new to the sport. I belong to CHIN and HPDE my car. That's enough for me. I drive against my own lap times. I have no sponsors and put this car together paying retail for everything. This is my sencond turbo kit and third motor (second built one).
The car is a Greddy TT with a built motor (nicknamed SAA2 Shock And Awe V2.0). I have the following list of mods and adding more all the time. The car makes 565 whp and 520 fl lbs of tourque on a Dynojet.
Arias ED pistons 9:0 to 1Eagle ESP H-Beam rodsARP L19 head studsARP rod boltsARP main studsARP exhaust manifold boltsHKS head gasketsGreddy Twin Turbo TD05H-18G turbo’sForged Performance turbo oil feed linesK&N air filtersTial 48mm BOVTial 38mm WG w/14psi springsGTM turbo camsIntake: 256 deg (stock 238)Exhaust: 264 deg (stock 240)Lift: 0.423” (intake and exhaust)Overlap: 18 deg (at 0.045” lift) – less than stockJWT valve springs and retainersTurbo XS UTEC w/map sensor Redline raised to 7500RPM Tuned @ 16psi Turbosmart e-Boost solenoid controlled by UTEC closed loopGreddy TT dual 2.75” exhaustNissan Rev up oil pumpSGP 3” downpipesSGP wastegate relocationGTM fan shroud w/high output cooling fansKoyo radiatorNISMO thermostatGreddy oil panCJ Motorsports stage 2 return fuel systemWalbro 255 fuel pumpDeatschWerks 600 injectorsRev Up lower plenumK&N Cone filters RC-9350SVRT solid engine mountsSVRT head support modAttack coilovers 16/14 kgf/mm 896/784 lbs/inchBattle Version rear lower control arms/camber arms 350 EVO front camber arms Innovate DB7 widebandATS triple clutch/standard flywheel/standard compound/1350 kg pressure plateHotchkis adjustable sway barsPowerGrid adjustable sway bar end linksStopTech 355mm front ST-40 4 piston caliperStopTech Aerorotors (2 piece)StopTech ss braided linesAxxis ULT pads for streetHawk DT-70/DT-60 race padsADVAN RS wheels F 18x9 +22 F 19x10 +35 TOYO R888 tires 275/35/18 F 305/35/18 RRays Duralumin lug nutsNISMO V2 front bumperNISMO USDM side skirtsEVO-R Type-E wingGTSpec dry carbon strut tower braceEVO-R CF engine coverTechnosquare flash for speed limiter removal
A few Pics.... Enjoy!
Watermelonwarrior
Car: 2006 Cayman S 6SPD
Sweet ride man. Welcome to nico
What an introduction. Usually we have to beg the new guy to post pics or tell us what color hes got...
On a side noteIs it just me or is there a new person here like everyday? This is pretty recent to
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Watermelonwarrior wrote:On a side noteIs it just me or is there a new person here like everyday? This is pretty recent to
Thats how its supposed to be...
Nice Ride JetPilot, and incredible power. Really good build, what happened to the first two motors?
JETPILOT
Hi Gentlemen...
The first motor, the stock one, blew with the Turbonetics kit on it. The tuner had raised the rev limit to 7200 RPM without asking me or telling me. One day I over reved and snapped a connecting rod.
The second motor, a fully built motor a copy of the one I have now, was tuned improperly and fried the rings. So I got a new one replaced under warranty.
rmezz13
nice. i plan to go with the turbonetics kit if i ever have any money to do so, is there anything you recommend? any downfall to the kit? i'm looking to maybe max the car out at 400 whp on stock internals. if i build the motor i want to aim for 650+ for a highway monster. Highway is where the money is in my town...
JETPILOT
I wouldn't recomend the Turbonetics kit. The build quality is not good, You wil have A/C issues, cracked pipe brackets, failing turbo seals and a whole list of issues. The kit isn't very complete. The ECU reflash isn't the best, and if you get the tuner kit you will need to get an ECU solution such as a UTEC. They do have good customer service and support to a point. Everyone I know that had a Turbonetics ended up blowing the stock motor and selling the kit and goign with something else.
The only kit I recomend is the Greddy TT kit. If you blow your motor you can up the power to 600Whp if you desire. The Turbonetics max's out at approx 450whp. I recomend it because I have experience with it not that anything else is inferior.
I love the Greddy. It is well well engineered and has been trouble free. You don't hear of problems with the Greddy other than the E-Manage Blue ECU it comes with. It's garbage.
R350Zz33
Car: 2008 350z enthusiast
jetpilot how much did all the mods cost u not including thing u twice purched
R350Zz33
the greddy tt setup
JETPILOT
With labor and parts I'm close to 40-45K I'd say.
R350Zz33
including the car ?
JETPILOT
I'm not sure what your asking. Are yo uasking how much money I put into the car for all the mods minus what I did twice? That's 40-45K plus 35K for the car. Total cost 75-80K.
Total cost for the Greddt TT and built motor plus ECU and tunung, install labor? That's about 25K.
R350Zz33
i better start selling crack or somthin lol
JETPILOT
R350Zz33 wrote:i better start selling crack or somthin lol
To anyone wanting to mod a car like this? Don't! You have no idea what your getting yourself into. I never intended on going this far!
The car was in the shop for an entire year!
Return to “350z / 370z Discussion”
