Rear sump for the 450.tmorgan4 wrote:What kind of sump does a 450Z require?
Rear pan but how deap and how wide, you have to consider deep because if its too deep you will struggle getting the engine in, (when the engine goes in on an angle the sump if too deep will hit the cross member and the top of the motor, the intake manifold will hit the firewall) so you wont go in any further, this is the problem i had.Chrispy300 wrote:
I'm in depending on how you price them. The rear sump would be great, I'm just concerned with the clearance requirement between the pan and the crossmember. I have my engine in pretty low so the pickup tube would need to be pretty "snug" to maintain my engine height. I can give you dimensions for mine if you need them. PM me and let me know if you want to do one for me and what you think you'll want to make it happen - also let me know if you'd be going aluminum or steel. I'm kinda pressed for time as with the situation I'm in now I can't move on (and I really-really want to) without the pan.tmorgan4 wrote:After seeing the fiasco Nick is going through with his oil pan, and the fact that both Ben (T45) and my own modified factory VH oil pans leak slightly, I'm toying with the idea of designing some completely fabricated oil pans.
Not sure why they were steel .vs. aluminum could be tooling or 1000 other things. I believe the VH41s had an aluminum pan though. When I get the car back in the air I'll take some measurements and post them up here. BTW - I don't care either way on the steel .vs. aluminum, I just need to get a pan made that will clear everything, not leak and allow me to continue with the build.tmorgan4 wrote:For some reason I hadn't even considered aluminum since the factory one is steel. Why is the factory pan steel and not aluminum?
The only issue is that I have never in my life welded aluminum. I'm picking up this TIG pretty quickly though...just need some seat time to practice. Even if we got these designed and cut then someone with a little experience could weld them.
If you have some dimensions on hand I'd love to get my hands on them and try and get a model laid out.
What sort of TIG did you get, im hunting for one at the moment and want to get a good one, preferably 3 phasetmorgan4 wrote:I just picked up a very very nice TIG. Just need to learn how to use it.
Just waiting for the last 3 gigs of Autodesk Inventor to finish downloading and I will start playing with designs.
I've got some dimensions written down, but I'm not sure if they will help you or not. I've got to go with a front-sump arrangement on mine as I don't believe I have enough clearance (<3/4") between my rack and the windage tray to run the pickup tube, without sitting the motor higher. I picked up a non-VH oilpan to steal it's side kickout but still clear the Q p/s pump (this replaces the existing small kickout). Doing this I can keep all the baffling of the Q pan and with a near vertical (90*) drop from the rear of the pan (to clear the crossmember) to the front sump, it will make it very difficult for the oil to move back off the oil pickup during acceleration.tmorgan4 wrote:Nick if you happen to come up with any dimensions I would like to see how they compare to mine.
