Here you go, BTW you are gonna have to remove the battery in its entirerty to get the bolts at the bottom, so you will have enough room to pull the airbox out.DarkAquarius wrote:Thanks for the input. Do you know if where I can find the instruction on how to remove the OEM air filter?
Your SRI should come with instructions, but the info posted above will definitely do the trick.DarkAquarius wrote:Thanks for the input. Do you know if where I can find the instruction on how to remove the OEM air filter?
Never mind. Found it... NameTakeNow sign.DarkAquarius wrote:Thanks, I'll take it apart and put it back together just to have a feel for it. Thanks for your feed back... Those instruction looks like you got the from a manual. right. Where can I get this information?
Nope, the pics are from the 2.0L . Im the Tech for the Car club im in, We have (2) MR20DE, and then my Lonely QR25DE. So i have pics for both.gotak wrote:You guys posted the 2.5 engine's air intake stuff. The 2.0 is different.
Probably lost MPG cause you're enjoying the noise . Could also have been variances in traffic levels. The want to make noise goes down a little bit with time.DarkAquarius wrote:All in all, with just the intake, I gained about 10hp, but my MPG(25/34) reduced to (22/31).
I'm so tempted to get the Weapon R and an exhaust but it's my everyday car, I don't want it to annoy me and others all the time.DarkAquarius wrote:If you have an exhaust, or Catback system, you notice the symphony between intake/exhaust.
Return to “Sentra Forum / Infiniti G20 Forum / Pulsar / NX Forum”
