SEARCHED but no results, S13 calipers on S14 5 Lug rotors???
Ls1pwr
im doing a 5 lug swap and dont have the money to get the 300zx calipers and m/c. could i use the s14 Se 5 lug rotors with stock calipers?
i searched but did not find a definitive answer, some ppl said yes and some ppl said no they wont fit. thank you in advance.
Ls1pwr
TTT
anyone know?
GTS-T 240
Car: 1990 RB25DET 240sx
yeah i could never find that out so i just redrilled my s13 rotors for 5lugs till i get my new brake set up
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
s13 and s14 rotors are the interchange able, they just use different lug patherns.
Same goes with the calipers.
So in other words, s14 rotors will work with s13 calipers
onosqv
Car: '92 240sx Vert
Coolwhip wrote:s13 and s14 rotors are the interchange able, they just use different lug patherns.
There is a SLIGHT addendum to that.
If you are regular s13 (non-abs) will you want 95-96 5-lug s14 rotors. If you are abs s13 (or vert s13), you will want 97-98 5-lug s14 rotors; although you should be okay w/ 95-96 rotors as well in this case.
Quite a few forum members (on this & other forums) found out the hard way.
Ls1pwr
i ordered the raybestos oem 5 lug rotors for a 1996 se. thanks again for the advice.
doubleohkevin
Car: 1995 coupe
How about brake pads? since rotors are the same (s13 is .2mm smaller/bigger or so, i forgot which one) brake pads *should* work too right?
onosqv
Car: '92 240sx Vert
brake pads stay same. Just use the same caliper you have had...
I wana 240sx
Car: nissan 240sx 95
Im trying to get some rotors 4 my 95 base 240sx. Most of them say w/o abs. I got abs, can I use the w/o abs rotors ? How can u tell if u have abs? sorry newbie here. I have a yellow abs light in the dash, so Im assuming I have abs. Just need rotors asap. thanks
