 Piston poll, what slugs you runnin?
themadscientist
RB/Skyline Moderator
Online
staring down at you with disdain from the
spooky mountaintop castle
11-12-2002
Time to buy pistons, help me pick. What do you have and what is your feeling about your purchase?
Piston oiler notch correct?
Were they weighted?
What was the ring quality?
Were they a consistent barrel size or did they vary a great deal?
Any special coatings?
what clearance did they require?
noisy when cold and if so do they warm up quick and get quiet?
I am probably going to get a set nobody has just to broaden our collective experience of the available brands.
Online Poll » Results
CP (36%, 4 votes)
wiseco (27%, 3 votes)
arias (18%, 2 votes)
JE (9%, 1 votes)
Veniola (9%, 1 votes)
Ross (0%, 0 votes)
other (0%, 0 votes)
(11 total votes)
sicj
1987 Nissan 200sx
San Jose CA
4-25-2008
 « Re: Piston poll, what slugs you runnin? (themadscientist)
I'm running Wiseco 84mm overbore pistons.
No. There is a notch on the skirt but squirter hit webbing around piston pin. Squirter modification required.
Were they weighted?
Yes. They were within 3-4 grams of eacother. The weights were written on the pistons to show they were "matched". I had them rebalanced within 1/2 gram. A higher priced piston would probably be matched better.
Pretty much standard rings with a high quality oil control ring.
Dimension wise they were all identical in every measurement... The piston pins slid in with no resistance either. Spiral lock pin retainers are a ***** to install but very secure.
Yes. Piston skirts are coated with black anti-friction coating
they wanted .003". Piston rings were spot on with the bore size too. No need to file any of the rings!
N/A
Bwana
Super Moderator
'89 240 coupe RB25DET '77 MGB CA18DET
Fort Collins CO
9-16-2004
Stockers in the CA but used CP's in the last rb25 I did. No complaints whatsoever.
Quote, originally posted by r34 gtr »
Yeah man, I hear ya. I went out to my car yesterday to go job hunting and when I opened the door my balls melted off. True story.
boost_boy
1990 sentra w/ CA18DET
Miami Fl
11-14-2002
I use CPs in the street engine and wiseco in the built engine. I've used wisecos back in 1999-2000 and they weren't bad, but my engine management was and it cost me those $500+ pistons in less than 1000 miles. Detonation was the villain, so check my sig................On the other hand, the CPs have been pretty good as well, but then again, there's a much better source of engine management fueling them too.
Since the first wiseco set, I had some adjustments done to the piston ringland heights to get them away from detonation (if there's to be any). I also got modified valve reliefs to compensate for the big bumpsticks. The ring quality on both are pretty competent as well.
Dee
Who's selling their CA18 next ?
Forged pistons are no insurance for ignorance .
Spending money foolishly doesn't equate to a high hp car .
Dee
meminto
S13 Silvia CA18DET
Lismore NSW
4-28-2008
Arias pistons in mine, no problems with squirters, no special coatings and have huge valve recesses for increased lift...
Unfortunatley I think they don't make them with the bigger recesses any more, I havent noticed them to noisy at start but others I have talked to mentioned some noise...
What on earth possessed him to build such a creation?
float_6969
1990 Nissan 240sx Coupe
Topeka Kansas
8-26-2002
Custom CP piston. 83.5mm, approx 10:1 compression with thicker ring lands than standard, full floating wrist pin.
YES
Were they weighted?
YES
GOOD
VERY GOOD
NO (but available)
I don't remember. It came with the spec sheet.
YES, and YES
themadscientist
Online
11-12-2002
 « Re: Piston poll, what slugs you runnin? (float_6969)
Well, they ain't cheap but here are the pistons I am going with.
http://todaracingusa.com/product?cid=25&id=648
Toda ain't screwin around, these things are dead sexy.
http://todaracingusa.com/category?id=25
TODA will also be doing my machine work on the block. Visa card is hot as a mofo, I might have to go back to stripping.
DALAZ_68
240sx
Los Angeles CA
4-9-2007
Quote, originally posted by themadscientist »
nice
how much does work for the block usually cost...wen i get down to the gritty i wanna have a good idea how much itll cost me
1990 240sx
recently swapped CA18DET 32k miles
Greddy FMIC and Hot pipe
R32 VLSD
SoOn tO cOmE : 5 lug brake upgrade, R32 MAF,KA TB,444cc injectors, aluminum one piece driveshaft, bucket with 4 point harness, Greddy BOV, Standalone,turbo timer...
themadscientist
Online
11-12-2002
 « Re: Piston poll, what slugs you runnin? (DALAZ_68)
I'm in Japan so the price is big yennies. They will be boring and honing the block with a torque plate and flycutting the deck to true it up. It's going to set me back about $800. I have to ship the block to them in mainland, I'm down on a small island.
float_6969
Topeka Kansas
8-26-2002
That's a RETARDED amount of money for block work!!! At the shop I use, boring is $25/cylinder, $50 for the decking, and another $25 to hot tank the block.
themadscientist
Online
11-12-2002
 « Re: (float_6969)
Everything is expensive here. The old man here who doesn't know what a torque plate is and can't even replace valve guides charges over $55 per cylinder and has tools that look 40 years old.
Toda builds professional racing engines for GT300, F3 and F4.
r34 gtr
ugly black 89 240sx hatchback
Huntsvegas AL
12-29-2002
Anyone using Mahle pistons? I know lots of race teams use them, and they have been in the piston business for over a century.
I'm like the Gangstalicious of NICO.
ryan: It's not that I think he's retarded. It's that I was the one that gave him his gold medal at the special olympics. I KNOW tim is retarded. I hope I never meet him in real life actually. I'm like 6'2" 185lbs. Tim is prob like 6'7" 300lbs and eats live baby sheep for snacks during the day.
themadscientist
Online
11-12-2002
 « Re: (r34 gtr)
I looked them up, no CA pistons on the shelf.
sicj
1987 Nissan 200sx
San Jose CA
4-25-2008
 « Re: (themadscientist)
wow impressive!
that's the only thing I wish I had when I was machining my block was a torque plate. It was crazy to see a block distort as much as .003" when the plate was removed after machining.
So with $800 block work and $800+ pistons and I'm sure your getting other crazy parts to go with those as well...what are your goals for this engine? 500+hp? I mean that 400+hp CA wasn't nearly as built up as yours sounds like it's going to be...
themadscientist
Online
11-12-2002
 « Re: (sicj)
Goal is it doesn't blow up. This will be my first build and my first time messing with the Haltech. It will be a long slow process to turn the power up. 300 would make me happy but I am building it to take 400.
Nothing crazy just a daily driver.
Giallo spyder met
Nissan 200sx -92 Euromodel
Jonkoping
2-15-2007
I run CP piston great piston and they have prove 330Hp/L
r34 gtr
Huntsvegas AL
12-29-2002
^ Yeah, if they work for you, they should be good for pretty much everyone else.
» Return to CA18DE / CA18DET Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
