Help me defend my decision
MJH240SX
Car: 1990 240SX Hatch, 2010 Mazdaspeed 3
Ok, I have been getting A LOT of crap from friends/locals for choosing to boost my KA24E...but I'm doing what I want, what I like....just tell me I'm normal, b/c around here, if it's not an SR, people think it's crap...I really don't care what the "honda" guys think...
Anyways, the reason I am choosing to build a SOHC is b/c I have (2) running motors..my 1990 coupe rusted to hell and back.....so I pulled the engine, all other salvageable parts, etc etc. I also have a 1990 hatch with a 60k on a rebuilt stock motor...the car is rust free and runs perfect.
I plan to slowly rebuild the pulled engine....new pistons, etc...I'm not going forged due to I really only want to get 250-275hp, and through the hundreds of posts Ive read, stock internals can handle that power easy...
Let me tell you what I have done to my hatch already, and the future plans:-tein lowering springs, kyb agx struts/shocks, 3" stainless exhaust with stainless header, "apexi" n-1 style muffler (already on there when i bought), energy suspension master poly bushing kit (still need installed), suspension techniques sway bars(still need installed), 18" konig caffeine rims (already on when i bought, plan to change), DC Sports front & rear tower strut bars....
Future: rebuild and turbo the sohc, (i wont bore you with the details, since I will be following the posts on this site)....new clutch, lsd, paint, rims
Just want to share my 240 plans with others that love the 240......i'm stuck in honda-ville with no one to appreciate anything with....
480sx
Car: 1996 Pearl White 240sx
ka-t good, make car go fast
Dont listen to the hype kids, just show them up with a properly built ka-t and they will shut their mouths.
240sxvaj
1994 MKIV TT-Daily/Track
I personally like the DOHC better, maybe its because most of those fast ka-t are DOHC. This is totally up to you though, just knowing that you are going ka-t you are pretty much good. Good luck with your build and make those non-believers into Believers. you'll love the power.
WDRacing
240sxvaj wrote:I personally like the DOHC better, maybe its because most of those fast ka-t are DOHC. This is totally up to you though, just knowing that you are going ka-t you are pretty much good. Good luck with your build and make those non-believers into Believers. you'll love the power.
The DOHC motor is better by design...but the main reason you see more high hp DOHC motors is simply because they were installed in everything from 91-98, where as the SOHC was 89-90. So not a fair comparison.
The SOHC has low compression from the factory. SO it will love 8-12 lbs of boost.
Anyone that says you're stupid for turbocharging the motor already in the car is an idiot.
Happy Boosting
WD
nissanfanatic
Car: 1992 Nissan 240sx SE
The one advantage to the SOHC is camshaft selection. You have a lot of room for a lot of camshaft.
If you stay on these forums long enough and get involved enough with your car, they probably won't be your friends anymore. I would only consider myself friends with maybe nine or ten of the guys in my car club. There aren't a lot of people that take cars seriously enough to make a hypothesis based on data that matters.
neverlift
keep in mind, all those honda fans are into "higher revving" motors...
tell them to try to punch themselves in the face real fast, while trying to headbutt their fist even faster
seriously anyone who tells you to not do something is because they are ghey, and know the future for them, getting pwnt. A half *** kat will smoke alot of cars. especially hondas
I put together a t25 setup and 11 psi for under 300 dollars. And it was killing people.
the new setup I have like 30 bux cash and a few things traded in, is way sicker at 5.5psi already, with a bad seal and leaky h/g so def go t3
1991h9
Car: 1991 240sx
you put together a t25 set up for 300? the hole set up cause thats insanely cheap. or are you just talking about the turbo itself?
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
I'd guess he had some stuff laying around or knows someone who had stuff laying around.
lrb_2000
Car: '91 Nissan KA-T hatch
I ran against a friend of mine with a sohc. his motor was built with 8:1 comp pistons and such, he was running 15psi, where i was running 10psi on my dohc with the same turbo, t3 super 60. I beat him buy about 5 cars.. anyways, I think it was the fact that I was running stock 9.5:1 comp and he had only 8:1 comp... but yeah, basically I was running 280hp on 10psi.... as long at your car has good compression and is running fine, then you'll own up most cars you see around on the streets. Don't worry about it, they're just either retarded, or jealous. Either way, you'll smoke em, and they'll be crying, and maxing out they're credit cards to try and beat you.. but it's no use, ka-t is the pwnage.
oh, btw.. i'm drunk , but I think I know what i'm talking about?
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
over the years i have simply accepted it... and chalked it up to guys just being posers and non mechanical.
I don't know how many Sr and Rb guys call me when their perfect swap is ****ed up.
neverlift
I think I have a thread on here, but yeah manifold, turbo(sr t25x2)w/compressor inletx2/outlet,turbine outlet,megan or ssac down pipe 3",sr hot pipe,zmaf,restrictor,drain,cheap *** homemade feedline,3bovs,ebay auction starion IC mod'd for front mount. BUT I already had :walbro,afpr,ability to rom tune(sohc ecu hacked onto a dohc)300zx filter,random pipes,coupler/hose clamps.
lol its for sale, now I have the t3 setup. Needs injectors, oil feed and a staggered gap piston seal for turbine side. shoot an offer lol, end thread jack.
NismoJ30
Car: 1994 Acura Integra
1992 Nissan 300ZX TT
Alot of people are just mainstream tuners and do what everybody else is doing. They want to do things for everybody else's opinion and not their own. That how alot of honda people are. The KA is a great motor don listen to these ppl who tell you other wise. the torque will make you smile from ear to ear when its all said and done
MJH240SX
Thanks for all the replies. Now I'm getting too excited.
abc123omg
Car: '93 240sx KA-T
if you have the money adn will, you can make anything fast. all engines have potential.. unless proven otherwise.
those honda guys and sr /rb ppl are porbally only putting you down cause youre not blowing 6k getting a "JDM TYtE" swap/hype. why toss an engine thats perfectly fine?
remember to go laugh at them when you only spent your 300$(or whatever you spent, but probally nothing past 800$ unless ur hardcore, i personally spent 650$ for my setup) on ur KA-t to get the same amount of power(and more torque) as their stock sr. lol. your ka will also have more power readily useable in the low-mid rpms whereas hondas porbally have to be redlining the whole time
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
I say go with what you start with. If i started with a dohc i would of boosted it but, since i have the sohc i boosted it instead. I decided it would be better to boost the ka24e for the same price it would cost me to swap in the de. I put together my old t25 setup for 600$. Its the same reason most people boost the KA.....they dont want to put a few grand into a swap to only have 200-220whp. Of course you can pull out the "IT'S JDM TYTE YO" card if ya do choose a swap.
The main thing is to do what you want and not what ever one else wants you to do.
The fact i have a boosted nissan and not a honda makes me a out-sider in my town. ....but, i like doing something different.
DevilMB3017
nelson8708 wrote:The main thing is to do what you want and not what ever one else wants you to do.
I really like your sig btw.
