T45 wrote:With their adapter the only issues with the Z32 are ps pump clearance to the sway bar, oil pan or xmember, and motor mounts. The trans will stay in the stock location. The ps pump can be moved higher in the stock bracket using the stock Z fittings but the sway bar still has to be lowered.
The stock Q manifolds will fit as long as you de-glove the heat shields from them and hack off the cats. After that you can do what I did and cut the stock Z mani's and graph them together. This allows bolting up to the rest of the stock Z exhaust system. MFG some similar log style headers that bolt up to the Z system would be really easy.
The wiring harness has been figured out for the Z, there is a big post on this somewhere around here.
The bonuses are the stock cruise control system works, a/c hasn't been done to my knowledge but I believe it will fit and work with custom hoses, consult works, stock guages work, etc. It's the perfect engine to swap in any nissan due to nissan's "lego" designs.
Tyler,
Fully agree with your points. Also, when I get my custom sway bar back, Addco will have the design on file if someone wants to go the same route. My bar will mount on the rear "rails" and come forward versus front to back like the stock one and is fashioned in such a way that the geometry isn't affected. It'll be 3-way adjustable (first hole being stock swaybar rate, second 15% stiffer, and third stiffest or about 30% stiffer than stock).
Also the 1990 (or that generation) P/S pump from a Maxima works very well and has a smaller pulley. Using it frees up a lot of space on the LH side and provides pretty good placement for the plumbing. I've posted some pics in my thread regarding this.
So there are some things that will become more available going forward making it easier for others to do themselves or to bundle into a turn-key solution.....
Thanks,Nick.
