C-Kwik
2004 Nissan Titan LE Crew Cab, 2005 Honda CBR600 F4i
SoCal CA
8-2-2002
What TV model#? What was the HD movie source (any copy protections, etc?)? What progrtam are you trying to use to run the movie?
"Bad Driver's Famous Last Words: Watch This!
Dattebayo
1987 S12 V6
DC Suburbs
8-25-2002
| « Re: (C-Kwik) | 11:57 AM 6/27/2008 |
Its a SHARP 19" Model # LC19??25?? something or other, the free Verizon deal.It happens with ANY moving image, regardless of file type or whatever, running on Windows Media 10 with all necessary codecs installed AFAIK... I didn't try a different program yet tho. Let's assume that the program isn't the issue for a min, what could it be? An interlacing problem?
C-Kwik
SoCal CA
8-2-2002
| « Re: (Dattebayo) | 11:37 AM 6/30/2008 |
It could be just about anything. So I won't assume anything. Like any kind of troubleshooting, you methodically eliminate each possible problem until you find it. Somethings are easier to rule out than others and some are hard to rule out unbless you have plenty of other equitment to try it on. So lets try and work with what you can do. Try another video. That's generally going to be a bit easier. And I'll ask again, what is the HD movie source? Try and find the specific TV model# as well. It might make a difference here. It could be an interlacing issue, but then I would think it would have issues all the time, not just with moving images...
pflicht
Krylon King
1991 Nissan 240sx
Andover KS
3-11-2007
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Dattebayo) | 9:36 PM 7/18/2008 |
Try replacing your GFX card with one made within the past 5 years... lol Other than the "FX" series the "MX" series was the 2nd sh*ttiest chipsets Nvidia had to offer...
Project: Kontrollverlust
| Quote, originally posted by The_Chosen_One » | I hope to god you mean I made your decision hard and not your willy wonka. |
skylndrftr
1990 240sx fastback / hyundai sonata
Cyberspace
9-22-2004
I think pflicht is being a little roug but...You might want to try the s-video out on the card to see what happens. I am not really up on HDMI but I dont think your card will support it. The product information does say HDTV ready but it kinda depends. Might want to try a different media player as well.
MinisterofDOOM
Maxima Moderator
Layton UT
5-19-2004
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (pflicht) | 5:52 AM 7/19/2008 |
| Quote, originally posted by pflicht » | | Try replacing your GFX card with one made within the past 5 years... lol Other than the "FX" series the "MX" series was the 2nd sh*ttiest chipsets Nvidia had to offer... |
Yeah, I considered posting the same thing but restrained myself. The GeForce 4 MX cards were garbage. Honestly, datt, you'll be able to find an upgrade from that POS for dirt cheap. Just do that. You deserve a lot of credit for tolerating a GeForce 4 MX card this long. I was sick of them back in 2002.
-The MinisterofDOOM  |The Q of DOOM| - |The Maxima| - | Hear my Q!| 4.08 VLSD, NICO 8-way ECU, full exhaust with custom headers, Tokico Blues with Eibach springs, Stillen FSTB, 20mm RSB, 255 rear rubber.
Dattebayo
1987 S12 V6
DC Suburbs
8-25-2002
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (MinisterofDOOM) | 9:12 AM 7/19/2008 |
| Quote, originally posted by MinisterofDOOM » | | Honestly, datt, you'll be able to find an upgrade from that POS for dirt cheap. Just do that. You deserve a lot of credit for tolerating a GeForce 4 MX card this long. I was sick of them back in 2002. |
I'd be willing to take a donation of a better card  I really don't have money to throw around at computer stuff anywho.
Looneybomber
89 bronco 2 (Blu/tan) 99 R1 (red/wht/blk) 02 explorer sprt (grn) 03 S2000 (triple blk)
Topeka KS
3-7-2004
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Dattebayo) | 9:13 AM 7/20/2008 |
Is it PCI? Anyway, I have a PCI video card sitting around that I'm not using. ATI x1300 I think? x1600? I'd have to look.Anyway, what HD movie source are you using? Last I knew you needed DirectX 10 to play HDMI from HD-DVD and BR sources. In which case, you'd also need Vista since XP doesn't support DirectX 10...And you'd need a better video card than I have since it doesn't support DirectX10 either. However, if you know of a way to get XP to support directX 10, you may be able to get something to work. What resolution are you trying to run at? Have you tried VLC player?...though it requires a better vid card than what you have or else your picture will just stop periodically while the sound continues to play. *edit* Ok I'm trying to find that Direct-x 10 thing and now I can't find anything on it. You may be ok with XP or XP-MCE and a vid card that doesn't support D-10. I don't know, hopefully someone chimes in that uses their PC as an HTPC.
Modified by Looneybomber at 7:13 PM 7/20/2008
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!" -Adolf Hitler, 1935
MinisterofDOOM
Maxima Moderator
Layton UT
5-19-2004
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Looneybomber) | 8:37 PM 7/20/2008 |
| Quote, originally posted by Looneybomber » | | Is it PCI? Anyway, I have a PCI video card sitting around that I'm not using. ATI x1300 I think? x1600? I'd have to look. |
Nooooo. This card is from LONG before PCIE. | Quote, originally posted by Dattebayo » | | I really don't have money to throw around at computer stuff anywho. |
Yeah, I know how that goes.
pflicht
Krylon King
1991 Nissan 240sx
Andover KS
3-11-2007
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Dattebayo) | 7:53 AM 7/21/2008 |
If you are low on money try this card, assuming your mobo can handle 8x AGPhttp://www.newegg.com/Product/...02756
Dattebayo
1987 S12 V6
DC Suburbs
8-25-2002
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Looneybomber) | 9:51 AM 7/21/2008 |
Nah, its AGP. | Quote, originally posted by Looneybomber » | | what HD movie source are you using? Last I knew you needed DirectX 10 to play HDMI from HD-DVD and BR sources. In which case, you'd also need Vista since XP doesn't support DirectX 10...And you'd need a better video card than I have since it doesn't support DirectX10 either. |
Its a DVI-D output on the video card, I use a HDMI to DVI conversion cable. I actually got it to run OK if I just have the card share the desktop between the monitors and run the LCD HD screen as the main monitor. I don't seem to have any issues running it that way but I would love to be able to have the desktop and icons on one side and the movies on the other side rather than one huge shared desktop. Oh well. I don't have any HD-DVD players, only HD files from DL, so no issue there as well. | Quote, originally posted by Looneybomber » | | What resolution are you trying to run at? |
1216x684 For some reason, there are no normal resolutions for my monitor probably given that the driver that Microsoft has for it (Plug and Play monitor) is the only thing available for it.  | Quote, originally posted by Looneybomber » | | Have you tried VLC player?...though it requires a better vid card than what you have or else your picture will just stop periodically while the sound continues to play. |
Its not a player issue. I have to run work stuff on here, an I deal with codecs you probably haven't even heard of, so I can play anything I want and not have a issue with it. Not trying to be snooty, but I do stuff with PAL and other formats on a daily basis, I have a very capable player that I forget the name of. Thanks! Maybe, just maybe. I probably only have AGP 4X tho. Also, those internet site always have a shipping fee and some other crap set up to charge me, so no thanks. I hate using credit online also. I'm an old fashioned store shopper i guess
pflicht
Krylon King
1991 Nissan 240sx
Andover KS
3-11-2007
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Dattebayo) | 9:41 PM 7/21/2008 |
| Quote, originally posted by Dattebayo » | Its not a player issue. I have to run work stuff on here, an I deal with codecs you probably haven't even heard of, so I can play anything I want and not have a issue with it. Not trying to be snooty, but I do stuff with PAL and other formats on a daily basis, I have a very capable player that I forget the name of. Thanks! Maybe, just maybe. I probably only have AGP 4X tho. Also, those internet site always have a shipping fee and some other crap set up to charge me, so no thanks. I hate using credit online also. I'm an old fashioned store shopper i guess  | Lol... VLC will play sh*t that require codecs YOU haven't heard of... Try it, srsly!Newegg is a GREAT place to buy PC parts from... If it says FREE SHIPPING then it is FREE SHIPPING. Good luck
Dattebayo
1987 S12 V6
DC Suburbs
8-25-2002
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (pflicht) | 6:48 AM 7/22/2008 |
| Quote, originally posted by pflicht » | | Lol... VLC will play sh*t that require codecs YOU haven't heard of... Try it, srsly! |
...um, seriously, I don't need another player. Mine does everything there is. Remember, I work in the video field for international security, so we have everything. I mean EVERYTHING. ...except a great video card, lol.
| Quote, originally posted by pflicht » | Newegg is a GREAT place to buy PC parts from... If it says FREE SHIPPING then it is FREE SHIPPING. Good luck |
Can anyone else back this up? I'm still not gonna use my credit card.
Philipio
96 240sx SE
DFW TX
8-31-2006
| « Re: GeForce 4 MX 440 DVI to HDMI problems! (Dattebayo) | 12:12 AM 7/23/2008 |
| Quote, originally posted by Dattebayo » | | Can anyone else back this up? I'm still not gonna use my credit card. |
Newegg is THE place to buy any PC parts on the internet. Period.
xekushnr
SELL ME YOUR S13!
Detroit MI
6-3-2004
I used Newegg to buy every part for the computer I'm typing this on almost 5 years ago. They have been around for a long time and do a great job, and do a great job on RMA's if it comes to that.
 Selling a S13 in the Great Lakes area? Email me!
Looneybomber
Topeka KS
3-7-2004
| « Re: (xekushnr) | 6:21 PM 7/24/2008 |
Not to put down NewEgg, but I've always used TigerDirect.com
xekushnr
SELL ME YOUR S13!
Detroit MI
6-3-2004
| « Re: (Looneybomber) | 6:27 PM 7/24/2008 |
| Quote, originally posted by Looneybomber » | | Not to put down NewEgg, but I've always used TigerDirect.com |
I was going to mention them as well in my post, they are also a great site. I think I may use TD to upgrade my system. I LOVE their combo packages, that's a great idea. I wish more sites would do that.
