MAXIMA VQ35DE Differences (2007 vs all)
Author
fre$h_turk
pine brook nj
12-11-2006
MAXIMA VQ35DE Differences (2007 vs all) 9:41 AM 6/26/2008
I'm ready to drop an another VQ35 in the car....I was wondering if anyone knows that a 2007 VQ35 will work...
What are the differences from the 04-06 ?... are the mounts the same?
It's kind of urgent, Thanks in advance.
PLEASE HELP !
fre$h_turk
pine brook nj
12-11-2006
anyone?
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
Mounts don't change. The ECU and engine did. Might also be the same on transmission.
1991 - S13 Coupe KYB AGX + Eibach ProLine $475, Strut Mount $160, ClutchKit $150, ExhaustSet $300, WaterPump $50, Radiator $99, FanCluth $45, Clutch Master $30, Brake Kit $310, Chassis $150, Anti-Theft $XXX, Audio $250, Celica Seats $200, Alternator $115, Starter $130, NISMO Wheels, Stillen Strut Bar, RedCoupe Shell $1,500 NEXT>>Bushing, LSDStatus - Running Strong. 2003 SE-R Spec-V Brakes =$150. Running Strong.1992 S13 SE Coupe Being taken apart for VQ Swap VQ30DE $320, ECU $50, Harness $100, MAFS $50, Intake Manifold $99, Z33 6-Spd $380, Poly Mounts $125, Z33 Oil Pan $121For Sale : FL, S13 Radiator, KA24DE, Automatic, ECU, Starter, EGR, FAN, Alternator, etc NEW LOW PRICES
fre$h_turk
pine brook nj
12-11-2006
« Re: (Soravia) 9:26 AM 6/27/2008
i'll be using the ECU therefore the timing from the 95 maxima.. and the 5 spd tranny...all i need to know is if the engine is the same
Soravia
Jacksonville FL
11-18-2005
The engines are all the same. Unless the engine you're looking at is VQ35HR, the VQ35DE are all very similar.I recommend against your hybrid. Stock ECU will have issues accounting for larger engine.
Jacko3
Fort Lauderdale FL
1-9-2008
« Re: (Soravia) 1:29 PM 7/10/2008
That's right! the 2007 G- 35 Coupe has the VQ35DE engine. It is the 2007 G-35 Sedan that has the VQ35HR engine. The 2007 coupe is largely the same as the 2005 and 2006 coupes. If there is any difference, it is cosmetic or a small change in the ECU. My car is moded out with modifications for 2005 and 2006 VQ engines, and it all works fine.Whatever small changes occurred int he 2007 G-35 Coupe, may have come from the many years of learning form the 2003 - 2006 model tears. Beyond this, they are all largely the same.
fre$h_turk
pine brook nj
12-11-2006
I had a 2002 engine in my 1995 max...timing and everything else is 1995.. I blew it up going over 140 mph over about 1 minute...It consumed a lot of oil and there wasnt enough so the rod bearings just gave up...
it sounded terrible..
well about 3 weeks ago .. i found a 2007 engine ... thats why I was wondering..
and now that engine is in my 1995 Maxima on 3500 miles and runs like a charm ..
Thanks for the info guys
< Contact Us - NICO
Copyright © 2000-2008 by NICO
