Absolutely not. The alignment is mainly a factor of the location of the dowel pins, it has less to do with the bolts, and nothing to do with the thickness or material.elwesso wrote:Do you think that with some of the thinner plates that maybe it would sort of self-correct when you tighten everything down? Probably more so with steel than aluminum.
Right, but when you torque down the bellhousing it will preload the input shaft to whatever direction the engine and trans are misaligned to. Once that happens, you will see seriously increaded wear to the input shaft bearings and possibly the main bearings in the motor.T45 wrote:Even with the runout, the pilot will make sure it's centered in the crank, and as long as the plate is flat I don't see a big issue. I could be wrong though...
Even if they wear to a point of "agreement", with every degree of rotation they will disagree again. The clutch disk is connected to the input shaft and the pressure plate/flywheel are connected to the crankshaft.T45 wrote:I can see that theory, but with a bronze pilot bushing in there it will wear down in a matter of seconds if there is any dis-agreement between the crank and shaft. That's it's purpose.
I'm not saying that is a good thing because it will still be off-center, but if it's off by that much then you would probably know because getting the bolts started and pilot lined up would be a *****.
I can at least measure accurately on a 45 as I still have the dummy shaft and my block in bits. I'll be realigning my spare z32 box next time I have it out as the workmanship of the original job looks a bit crappy.Here's some pics of what I used to measure it. The dolly bush in the input bearing space is what I used to locate the box to sort the dowels out.Mettler wrote:How are you measuring this accurately?
