What kind of car is this on???By "loosing throttle response" do you mean the car stops accelerating(holds a steady speed), or does it fall completly on its face and starts to slow, or something else?
So, it only happens in third gear while in a steady'ish state corner? The other gears are fine, and 3rd is fine in a straight line?
Do you have a fuel pressure gauge? If so, what is it reading when this happens?
With out knowing what kind of car it is, it is hard to guess. Some cars have a rev limiter that is unmistakable, others just feel like they fall on their face And I have no idea if removeing the cluster / transmission wiring would cause the problem. I would think that if it would cause a problem it would do it in every gear, maybe, maybe not, depends on the car probably.
Are you running any baffling or foam in the fuel cell?
I can't think of anything off hand that would cause that kind of problem other than fuel starve. but with it just happening in one gear in one state it is kind of wierd. Have you tried testing it at the same speed, in a diffrent gear to see if it is indeed gear dependent or if it is speed dependent?
Shift_ZOOM-ZOOM
