| Quote, originally posted by arcadia » |
| is there an online list of safety requirements for events? dont want to overlook anything. |
heres our short list, and what our tech inspector actually looks at
ech Inspection - All cars must pass some sort of tech inspection to get on a track.
- Must have SA2000 or higher helmet. Some sanctioning bodies allow M2000 and up. Please check with the organizers on which one you can use. TBF and NASA allow M2000 helmets.
- Tires must show good tread and cannot be corded.
- All front seatbelts must be in working order. Harnesses are ok as long as they are mounted correctly.
- Headlights(if night event) and brake lights must be in working order.
- Battery must have a tie down. If the battery is rear mount it must be tied down and covered in a battery box.
- All wheel bearings must be free of side play.
- Brakes should have at least half their life left. I recommend newer pads if you are track racing.
- Steering system must be in good working order and should not be loose.
- Windshield cannot have any cracks over 1'.
- No leaking fluids.
- All lug nuts must be present.
- All body panels must be present.
inspectors notes:
Pretty basic stuff really. I check the drift cars as closely as i do for SCCA events. Some stuff is okay for drifting but not for SCCA... but the person running the event makes the final call as they paid the insurance for the event and are overall responsible.
Under the hood:
- I look at the engine and radiator for what could be moderate/major fluid leaks
- I look at the master cylinder for leaks or weaping
- I check the throttle cable linkage at the TB/Carb
- I check to ensure the battery is tied down and that there is a non-conductive cover over the positive terminal. I dont gig them on the terminal, but i ask that they do cover it.
Outside the car:
- I check that all of the lugs and lug nuts are present. The person running the event may or may not allow a vehicle to run if it's missing one.
- I push on both front wheels at the top to ensure wheel bearings are serivceable and not too loose.
- I check condition of tires. Clearly at a drift event, several people will be using used tires. I look to see if theyre dry rotted or cracked and if they're fronts, I look for usable tread if it's a street tire.
- I check the windshield if it's cracked more than 12" and cracks across the drivers side of the screen.
Inside the car
- I remind them to remove all loose items,
- I check seat belts and anchor points for harnesses
- I shake the wheels for looseness and play
- I shake the seat to ensure it's fastened securely
Your Helmet
- I check to ensure it's at least SA2000 or MA2000.
- I check it for cracks or impacts
It should go without saying, but buy, beg, borrow or steal a torque wrench and torque your wheel's lug nuts to spec. Weird and odd things happen well enough without inviting the misfortune of a wheel coming off mid drift/mid corner... or anywhere.
