Easy to test with the method provided.................all solenoids have the same distinct signature ~. When the center core moves no matter what the core is attached to a pintle or a disk.
You must measure voltage at the injector since the voltage varies and so does the dead time from crank to idle ac.on-off, other alternator loads. ECU self adjust it's timing based on injector voltage:12v - 1030 uSec13v - 870 uSec14v - 760 uSecOnly critical at idle as cruise is O2 corrected and WOT like 2.5% at max from 12-14volts.
The 12+ wire is bigger until just before the injector harness, then splits into 2 smaller wires to HALVE the voltage drop in injector harness [4 injectors are feed 12+ in parallel].
At high rpms and WOT the 1 amp peak injectors are at 55% duty cycle so they appear to draw 0.55 x8 x 1 ampere peak or 4.4 amperes.
For scientists the above is not 100% accurate as some tiny amount of gasoline will flow BEFORE the pintle [or disk] is 100% open depending on the viscosity and psi of fuel..............again only important at idle*
http://www.yawpower.com/inject....html
* the Power Balance Test shows how the tiny variances can affect rpm. When you use BG44k and see differences some of it is from tiny air flow changes [cleaner intake valves] and tiny gasoline flow changes [cleaner injectors].
Brand newindividual injectors are only 3-5% accurate vs published flow and this nonlinearity varies with voltage, duty cycle and fuel viscosity.
Why professional racers trim [adjust open time] each injector individually in their search for every HP.
