There isn't a single person on this forum I'd trust more on this question than RED_DET.If you recall from your first of 3 threads in this forum alone on this subject he said:
| Quote, originally posted by RED_DET » |
| THe swap is relatively easy. Just be sure to remember what is plugged into where, I suggest labeling everything so you don't forget. You can pull the motor/tranny together. Out the top or bottom is your choice. You will have to jack the front end up @ least 3 feet off the ground from the bottom of the bumper to get it out the bottom, which requires some big jack stands and using blocks of wood on the jack to reach this point. If you go out the top, remove the hood and angle it out to allow the transmission to come out. Exhaust will have to be removed, cross member, drain anti freeze and remove hoses. Unplug things from the harness, drain transmission fluid, remove axles, remove intake, battery, drain power steering fluid and remove hose from pump. |
And, as per the second thread, your best bet is to take the axles out, because you can't go out the top that way:
| Leaving the axles in will make it just that much harder. If you do, you can only go out the bottom. |
As long as you properly disconnect everything you're really not going to have any problems. It's tight, but it will come out. Heck, it's not even really that tight of a fit. You can look into the engine bay from up top and see every one of the mounts, so there HAS to be room just based on that simple of a visual inspection.
I'm not trying to be a jerk. My point is that the feasibility of doing this has been confirmed by a reputable source. Relax and go for it.
The DD - '01 Sentra SE (RR SR20DE) w/pp (VLSD, FSTB), a few mods
Get your Nissan/Infiniti's FSM FREE here.
Need parts? Look here!
