mxr662 wrote:Maybe a switch could be wired in the shut off 2 or four injectors to save gas cruising on the highway.
Wouldn't you be able to do with with a CONSULT or the Nissan Datascan program?
Wait. That might be a little more cumbersome than a simple switch. I think that it would be the easiest way to go because (this could be due to my lack of electrical engineering experience) it seems to me that although the purpose and activation of the switch would be simple, the installation and wiring would be the "hard" part?
I'm thinking that the switch would have to run to the ECU and be connected to the part of the ECU that would control injector flow/cylinder management?
Or, an idea that just struck me is to have a modified ECU with a "fuel-saver" program that would run the Q on 4-6 cylinders (is that possible to do the 4?) and be activated much like the Stage II program by a simple 3 position rotary switch?
I hope some of these ideas are valid and not just implausible nonsense. I feel a bit smarter with these ideas, but I'd feel like quite the buffoon if it was all just retarded babble.
