 license plate light bulb change
dhl03
Infiniti EX35
Los Angeles CA
5-20-2008
does anyone know how to replace the license plate bulb? thanks
dividedhighw
EX35 Expert
2008 EX35 AWD (Technology Pkg)
Ottawa ON
4-22-2008
 « Re: license plate light bulb change (dhl03)
Don't know the "in service" date or what mileage is on your vehicle, but I would try to get this covered under the "adjustment period" as a warranty item. Assuming that bulb is only lit while your headlights are on, estimate how long (or how many miles) it would have been activated and you should be able to make a good case for having it covered.
Just a thought,
David
dhl03
Infiniti EX35
Los Angeles CA
5-20-2008
i wanted to replace it with a LED bulb in which it will last longer. usually there are screws to access the cover but in this case there are no screws. does anyone know how to access the bulbs? thanks
nghivdo
2008 Infiniti EX35 AWD Journey, Premium, Luxe Style, NAV, Black Obsidian, Graphite Leather
San Francisco CA
5-24-2008
Yeah, I 'd like to replace the license bulbs with Lexus-style white LED Bulbs too! But how the heck does one get to the bulbs? Remove the entire interior panel perhaps? Is the outside snapped on after un-doing the 2 pop-in plastic rivets? I can't figure it out! The manual states to "See Dealer" for replacement of certain bulbs, including the license plate bulbs! No amount of Googling has helped either...yet.... Someone must know! Guys & Gals?
dividedhighw
EX35 Expert
Ottawa ON
4-22-2008
 « Re: license plate light bulb change (nghivdo)
Hey Nghi ... check your email.
Cheers,
David
rontek
Had -2008 Infiniti EX35 Now - 2009 Infiniti FX50S
Burlington MA
5-16-2008
 « Re: license plate light bulb change (dividedhighw)
After checking the service manual YES, you do have to take the entire panel of the inside lift gate door! Bummer, huh ?
nghivdo
San Francisco CA
5-24-2008
Thanks a million David!!!! Entire interior lighting is now white LED's....verrrry soothing... now to find time for the biggest task... the license plate LED replacement! I'm discovering how very, shall I say, "interestingly" put-together the EX is, particularly how difficult it is to replace simple wear & tear items... like the LICENSE PLATE BULBS!
Modified by nghivdo at 11:10 PM 7/13/2008
dhl03
Infiniti EX35
Los Angeles CA
5-20-2008
so how did you do it? i understand you have to remove the entire panel...is there another easier way? also, how in the world did you replace all interior lights to LED? i can't even remove the stupid interior dome lights bulbs replaced cuz i cannot remove the cover and i do not want to damage anything...help!!!
rontek
Burlington MA
5-16-2008
 « Interior AND license plate LED light bulb change
I have not been brave enough to attempt to remove the inside cover of the hatch for the license plate bulb, but I have replaced all the interior and the front parking lights with LED bulbs. These are "Easy" replacements and make a huge difference in appearence. For the interior you need 10 Bulbs total. For the parking lights 2 more. If you want to attempt the plate its the same bulb as 6 of the interior and the 2 parking light bulbs. Here are the parts I used, and the place I got them.
Part #85645 - Festoon Hi-Power 1Watt LED - 31mm Super White
You need 2 for the cargo bay lights
Part #75841 - T5 3-LED Super White
You need 2 for the footwells of Front Seats
Part #45687 - T10 - 1Watt Hi-Power LED Super White
You Need 6 for the rest of the interior lights
2 for Map 2 for Front Door Bottom and 2 for Rear Seat Top
If you want to swap the parking and or Plate bulbs, it's the same bulb (T10)
I purchased mine at http://www.ledlight.com. It was not cheap, but IMO well worth it. Maybe I will post some pics if I get a chance.
Modified by rontek at 11:33 PM 7/26/2008
rontek
Burlington MA
5-16-2008
 « Re: Interior AND license plate LED light bulb change (rontek)
Well, I decided to go all the way and try replacing the License Plate bulbs with LED's also. Surprisingly it was VERY easy ! I got a small flat tip screwdriver and gently pulled back the inner hatch cover at its thin top corner spot. Once I was able to grab hold of it, all the plastic clips seperated very easily all around, and the whole cover came off! No broken snaps or parts at all. There are four what I call "Pop In" pins in what would be on the bottom part of the cover, that popped right out and you have to be careful not to lose them, but they went back in easily as well. The only thing I was surprised by, is the plate is lit by TWO bulbs. That makes TEN total T10 LED bulbs needed for everything, (Interior, Front Parking, and Rear Plate). The other bulbs are the same quantitys as my previous post.
Happy2Drive
'08 Infiniti EX Journey AWD Dark Currant w/Chestnut Interior, Lux Elite, Premium, Nav & Tech Pkgs
Cleveland OH
7-29-2008
Any chance you would mind providing a primer on how to easily access and change-out the front footwell lights?
I have the LEDs now, but I'm not confident how to tackle getting at those bulb/socket locations.
Thanks!
Happy2Drive in Cleveland Hts, OH
mcube3
2008 EX35 AWD DC/Chestnut
Markham ON
9-17-2008
Thank you thank you thank you!!
I've been googling around for the bulb change until I've found this. I've went to the dealer and asked if there is an easy way of changing those license plate bulbs before seeing this. The service manager said they have to get a mechanic to do it and needs that charge me 1/2 hour labour. I almost budge and crazy enough and pay them to do it.
orijin
Nissan Rogue Silver SL AWD
Brooklyn NY
7-27-2008
In my opinion if you guys want leds order from v-leds.com instead ive ordered from other places but to me and many others opinions they rate v-leds as the best site to buy leds from.
rontek
Burlington MA
5-16-2008
 « Re: Interior AND license plate LED light bulb change (orijin)
I dont have any affiliation with any site, I just did a little research and found the LEDlight.com site to be cheaper on most of the bulbs, and give volume discounts as your quantity of a particular bulb increases. So for the bulbs that you need multiple units, the price per bulb goes down. As for the Plate light bulb replacement, here is how "I" did it. You can decide yourself if you want to give it a shot. Below that I will post how I replaced the footwell bulbs too.
Plate Bulbs - I got under the back inner hatch cover with a small flat head screwdriver where the thinnest parts are at what would be the top near the window in each corner, and started pulling the cover back, the panel clips "popped" off quite easily. No broken clips at all. The only "gotcha" I found is there are 4 round black "pin type" clips along what would be the bottom part of the cover where the closing grip handle indent is, that popped out and I almost lost one. If you use common sense and don’t force anything, it was not very hard at all. Everything went back together easily as well. Remember there are TWO plate bulbs.
Footwell Bulbs - You have to reach up under the dash. The way I did it was to unclip the whole module the bulbs plug into, And feed it around under into the footwell with the wiring still connected. I then swapped out the bulbs, (if you ordered the 3 led version I did, you may have to "squeeze" the led's together a little to fit them into the bulb housing). After swapping the bulbs, test them before reinstalling as I found they are polarity sensative and you may need to turn them around to get them to light. This is the case for all the LED replacements. I dont know why, but thats the way it worked for me. Once you are sure they work, just feed the whole housing back up under the dash and clip it back in place. Try to note the orientation of the clips on the housing as it sits in the underside of the dash when you first remove it, as it makes it easier when you are putting it back. It may take a little bit if manipulating to get it to snap back in, depending on how big your hands are, but its really not that hard.
RioD007
EX35 Platinum Graphite
Paradise Valley AZ
2-26-2009
i did it the other day with led's and it was cake
2008 EX35 (Loaded Except Nav) Platinum Graphite : Tint (5% Front Double 5% Rear 20% Windshield) : All Interior and Puddle Lights Blue LED : 10,000K HID D2C MOD :HID Fogs & Hi-Beams : Blue Rear Turning Signal Bulbs : Blue LED Parking Lights: Blue LED License Plate Lights : Blue LED Trunk Lights : Red LED Side Marker Lights:Hardwired Cobra Radar/Laser Detector : Resonator Delete : Stock 18's Wrapped With Wider and Super sticky 235 series tires
:Finally Got My +2 Mod (Ask Me For Details):
WISH LIST: Stillen Intake : Black Grill : Graphite Rims : Smoked/Tinted Taillights and Signals :Hawk HPS Pads: Bully Dog Tune :
C456D
EX35
Miami FL
3-14-2009
Quote, originally posted by rontek »
Followed your instructions rontek and it worked like a charm.
Just would like to add e few things:
- I ordered 10 T-10's, however just found use for 8 of them (2 for Map, 2 for Front Door Bottom, 2 for Rear Seat Top, 2 for license plate)
- For installing the map lights and most importantly the rear seat top, remove only the white lid cover with a flat tiny screwdriver, do not try to remove the gray frames, it will be tough to put them back on.
- for installing the passenger footwell, just pull the cover underneath the glove compatiment which easily comes off.
- All bulbs are polarity sensitive and you may need to turn them around to get them to light
dividedhighw
EX35 Expert
Ottawa ON
4-22-2008
 « Re: Interior AND license plate LED light bulb change (C456D)
Hmm ... if I understood rontek correctly, the two extra T-10 bulbs are for the parking lights.
Thanks for your great input, C456D, and welcome to NICO!!
Cheers,
David
C456D
EX35
Miami FL
3-14-2009
 « Re: Interior AND license plate LED light bulb change (dividedhighw)
Quote, originally posted by dividedhighw »
Cheers,
David
Thanks David,
You are correct. The last pair of T10's were for the parking lights.
Does anyone knows if are there any led bulbs to replace the low beam halogen headlight?
Punjab
EX35
Cleveland Ohio
9-3-2008
Yes their are... check out http://www.v-leds.com
I was pondering to get the fogs..
ex35kmrsx
White '08 Infiniti EX35 - AWD-JOURNEY-TECH
Edmonton Ab
4-15-2009
I was wondering if anybody ordered from V-LEDS using sylvania.com's fitment guide? I'm asking because.... from the v-leds site they redirect you to the sylvania site (after pressing the fitment guide/start here link) to find the bulb part numbers for the EX, and it shows some discrepancies from rontek's. For example....Rontek used the same bulb for both MAP/PARKING/Plate, but v-leds/sylvania states different bulbs for map and plate, and the cargo bay lights uses the same as MAP. So im assuming different bulbs can be used? Hopefully somebody can verify that those different bulbs from vleds can also be used... I would prefer not to order from ledlight.com lol
http://www.v-leds.com/page/fitmentGuide.html
http://www.sylvania.com/Consum...t.htm
dividedhighw
EX35 Expert
Ottawa ON
4-22-2008
 « Re: Interior AND license plate LED light bulb change (ex35kmrsx)
A big Canadian welcome to NICO, ex35kmrsx!!
(I'll tickle Ron to see if he can answer you.)
Cheers,
David
cjre1
Infiniti EX35 Journey
Canyon Country CA
5-17-2009
I changed all my lights out three weeks ago with super bright white lights from super bright LED lights. Awesome look.
The license plate light took me 10 mins to do. No issues there.
lybrian1
2008 EX35
Toronto
5-9-2009
 « Re: (cjre1)
i used 9-LED super bright white but it does't look very bright. i think its the angle of the bulb placement. there is a dark spot int he middle of the license plate as large as my hand. im worried i might get pulled over for this
ex35kmrsx
Edmonton Ab
4-15-2009
Can anybody post pics? please and thank-you
jonkarn
EX35 Balc/Black
Brooklyn NY
12-21-2008
Hey guys I just swapped out some of my bulbs for LEDS as well. The cargo lights and interior lights looked so good so I went overboard and tried to install the license plate bulbs as well.
This was a bit more involved than I thought and I was going to just forget it. But I continued, and in the process broke off one of the white push pins(not a big deal), but also 2 of the 4 pieces that protruded out of the plastic handle piece that you grab to pull the hatch down. These pieces grab onto the metal hole that the handle sits in. I didnt realize that this handle was a separate component, and comes loose when you pull of the cargo door cover. The main problem was gravity. The push pins popped so easily at the very top that the cover slipped off downward unexpectedly while I wasnt fully supporting it. This is very awkward to do when the hatch is open, because you have to reach up. you really need 2 people, one guy to hold the hatch down lower so you have a better angle to pull everything off, and then put it back on. I couldnt get the cover back on either as I had a very hard time trying to align all the pins, especially fitting the 2 ends that are closest to the window. To fit these in first, while holding the rest of the cover with your arms fully extended was more than I could do. They dont seem to grab very well, not giving you enough of a hold before you can pop all the pins in. Too much gravity. Each pin doesnt hold enough of the covers weight to help you go one by one snapping them in place. Maybe I am a retard, but this seems much easier for 2 people. Now i have to bring it in to service to replace one of those pins and the plastic cover handle as well. This is going to cost me. Guys if you aren't familiar with how this cargo cover fits on and off, don't attempt it. I though I was being very careful, but I didnt realize the process involved. Plus you guys didnt tell us how to put the cover back on, lol. Damn you mechanics! You made it sound so simple!
mcube3
Markham ON
9-17-2008
 « Re: Interior AND license plate LED light bulb change (jonkarn)
When I did mine I snapped off 2 clips on both sides close to the rear window. But everything was holding up and didn't look funny so I just left it the way it is.
» Return to EX35 Forum
Car Finance Advice Nissan Infiniti News Archive
240sx technical information Nissan technical information
Infiniti technical information Nissan Infiniti Car Owners Homepage
Advertisers Marketplace
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
