mounting for show? i hope for your own sake, you don't use it for anything where you can get hurt.Even if you mounted it correctly - 4 point harness + stock seat = no... actually, 4 point harness in general is no good (submarining possibility).
You should search - here, google, etc - it's been discussed.
If you REALLY must, instead of the lower mounting bolts, there is the upper hole on the coupe & fastbacks that you can use if you buy a Sparco eye-bolt & your harness has the clip in feature - otherwise, just a long bolt and bolt through both holes.
It will turn your 4 point into basically a 3 point, but the position is relatively better than where the lap belt bolts are.
bew bews
