mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Mon May 19, 2008 11:45 am
I have a 94 300ZX FSM and it says pin 18 is black with a pink line, I believe. (B/P)
The green with yellow line wire looks to be on pin 42 and 52 and goes to the cam position sensor. I see orange on pin 9, 16, and pin 31.
Pin 9 goes to the a/c low pressure switch, pin 16 goes to the ignition coil relay and ECCS relay, and 31 goes to the engine and main harness and ends as the data link connector for Consult. There is another orange that is on the fuel pump relay and it comes from the fuel pump computer.
I'd say the one you're looking for right off the ECU for the fuel pump relay will be the black/pink one.
This is all for the 300ZX though... I'm pretty sure the DET would be similar but I'm not positive. Hopefully this helps a bit.
