Tayluh_240
Baton Rouge Louisiana
9-23-2007
| « Re: pop-up light (shift_240_s13) | 6:16 PM 5/14/2008 |
idk ill come over and help you
- Taylor
redsx13
93 240sx 03 Z
LA CA
8-3-2007
| « Re: pop-up light (shift_240_s13) | 6:49 PM 5/14/2008 |
ya, they brake all the time. i have a good right motor assem. laying around if your interested.
 ***Update*** just got my sr20det in and it runs like ****. if you have any advice what so ever, please follow this link.http://forums.nicoclub.com/zerothread?id=360014
redsx13
93 240sx 03 Z
LA CA
8-3-2007
| « Re: pop-up light (shift_240_s13) | 6:50 PM 5/14/2008 |
i too have a red 93 240 hatch
Tayluh_240
9-23-2007
| « Re: pop-up light (redsx13) | 7:21 PM 5/14/2008 |
| Quote, originally posted by redsx13 » | | i too have a red 93 240 hatch |
how much could i take it off of ya for?
shift_240_s13
93' 240sx, 72' 240z
brusly La
4-22-2008
| « Re: pop-up light (Tayluh_240) | 7:23 PM 5/14/2008 |
| Quote, originally posted by Tayluh_240 » | how much could i take it off of ya for? |
sorry my friend was on and i thought i was on my acount. but im intrested in the motor.
redsx13
93 240sx 03 Z
LA CA
8-3-2007
| « Re: pop-up light (shift_240_s13) | 7:41 PM 5/14/2008 |
i dont know not too much, how much where u looking to pay?
shift_240_s13
93' 240sx, 72' 240z
brusly La
4-22-2008
| « Re: pop-up light (redsx13) | 8:22 PM 5/14/2008 |
well do i need the whole assembly or just the motor for that problem?
redsx13
93 240sx 03 Z
LA CA
8-3-2007
| « Re: pop-up light (shift_240_s13) | 5:38 PM 5/15/2008 |
no, just the motor. As a first step i would check the relay for that side. the relays are located under the hood in the black box near the right front of the car. swap the left relay with the right one. if thats not the problem, you have a bad motor. im not exactly shure what you are refering to when you say the "assembly", but if you mean the housing that holds the headlight, that does not need to be replaced. there is a small ball joint on a rod that is connected from the headlight housing to the motor. pop the ball joint off, disconnect the plug from the harness, and simply unbult the motor. (P.S. it is VERY unlikely but there may be a wireing problem so if your up to it just glance over the wire harness to make shure there are no spots that are crimped or damaged.let me know what you come up with.
shift_240_s13
93' 240sx, 72' 240z
brusly La
4-22-2008
| « Re: pop-up light (redsx13) | 8:37 PM 5/15/2008 |
alright, i checked the relays and still the same thing happens.......so i guess ill be needing that motor. would $20 shipped be good?
tercel drifter
sr20det s13
edmonton alberta
9-24-2007
before you play with the wiring it may just be something as easy as the motor being jammed. Happened to mine. Left light was stuck but right light went up and down. Pop your hood and play with the manuel controller for the light(the big nob that spins) and it may be all good hopefully!!!
shift_240_s13
93' 240sx, 72' 240z
brusly La
4-22-2008
| « Re: (tercel drifter) | 7:22 PM 5/16/2008 |
ive done that and it doesnt work, i even took it apart.thanks.
Trax07
1989 SOHC 240SX
San Antonio TX
7-16-2007
| « Re: (shift_240_s13) | 7:07 PM 5/17/2008 |
swap out your Combination switch .... or clean it i just replaced it and viola...
shift_240_s13
93' 240sx, 72' 240z
brusly La
4-22-2008
| « Re: (Trax07) | 10:51 PM 5/17/2008 |
ive done it.REDSX13, do you still have that headlight motor?
shift_240_s13
93' 240sx, 72' 240z
brusly La
4-22-2008
| « Re: (shift_240_s13) | 10:44 AM 5/23/2008 |
do you?
