mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Thu May 15, 2008 5:36 am
The screws supercharger kit offered for the 350Z might be able to work on a Maxima but the major downside is they're tall, as they are bolted on top of the engine, meaning the hood probably won't clear. You would likely have to do some major hood modifications to be able to close it.
Now, I believe Stillen used to make a centrifugal supercharger kit for the 4th gen Maxima's but they're no longer in production to my knowledge so you'll have to search for a used one.
Internal wise, you don't really have to change them out as long as you keep the boost relatively low and tune it well.
Personally, I'd probably go with a turbo setup instead. It takes more fabrication to pull off but they just tend to perform a lot better than superchargers. The screws s/c is pretty much the best one out there as far as power and efficiency goes but they've been pretty unimpressive on the Z's from what I've seen. They do offer quick boost but a good turbo setup can still easily outperform one.
The centrifugal superchargers, like in the Stillen kit for the Maxima, are pretty efficient but still suffer from "boost lag" in that you don't have instant boost like the roots and screws superchargers and boost is linear... meaning, you won't have peak boost till redline since boost continually builds. This is the centrifugal s/c's weakest point in my opinion. If it were able to hit peak boost early and keep it there till redline it would probably be the best option out there but as its unable to do that, the turbo still shines.
In the end, it really just depends on what your goals are. How much power do you want? If you just want a slightly faster car but aren't looking for a ton of power the centrifugal s/c and turbo would be a good choice. If you're wanting to make a lot of power down the road the turbo would be best choice.
