Stripping interior past the dash?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
has anyone stripped a Q down past the dash? Ive got the dash pad off my Q right now and theres that thick metal support bar going down the middle.. Anyone have any idea how to get that little guy out of there? Do you have to take all the duct work out or is it just bolted in the obvious places? The dash was not that much fun to try and remove...
qship96
Car: 1996 Infiniti Q45
why are you removing the dash?
elwesso
2007 BMW M Coupe
suspected mix door as well as checking out a couple other things. I had some wiring issues near the brake pedal (switches) and while im in there itd really make life easier of that bar thing was gone.
Raxephon
Car: '04 RX8...for the moment...
Are you talkong about the 2" diameter steel pipe that runs from left to right, or the thinner strips of metal behind/under the center console?
I just got done gutting the '91 for parts for the '94 about 20 minutes ago. (goodbye LAN system )
The framework for the dash is shaped similiarly to the symbol for pi.
On a side-note, the footrest below the parking lever is actually a bracket held on by 3-4 screws.
Which means plenty of pedal travel for a clutch pedal once the bracket is removed.
elwesso
2007 BMW M Coupe
Yeah thats the guy im talking about. I was hoping youd answer to this post.. Is there anything funny about getting that little guy out?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
anlasak wrote: On a side-note, the footrest below the parking lever is actually a bracket held on by 3-4 screws.
Now that is useful information. I have always thought that was likely part of the firewall satmping.
Raxephon
The 2" bar that runs from one side of the car to the other between the "A" pillars?
If thats what you're talking about, then yeah, most of the ductwork will have to be removed, a lot of it is attached to that bar.
Raxephon
Some picks of my recent carnage.
elwesso
2007 BMW M Coupe
how the hell are you supposed to get the brake pedal out? There are 2 nuts easy to get to,and 2 others that are about impossible..
Raxephon
elwesso wrote:how the hell are you supposed to get the brake pedal out? There are 2 nuts easy to get to,and 2 others that are about impossible..
The impossible ones are possible with (2) 12" wobble end extensions.
elwesso
2007 BMW M Coupe
I got it.. I ended up using a regular box end wrench, but i have tiny double jointed arms so it worked.
rhinoone
Wes, you are in for a big job as there are bolts holding the dash pad in that require removing the windshield, and then take out the screens covering the defrost vents. If you need your windshield replaced, now is a good time to consider it.
I'll look for pics.
Raxephon
rhinoone wrote:... there are bolts holding the dash pad in that require removing the windshield....
Sorry, but you're wrong.
Windshield removal is completely unnecessary for dash removal.
Look at the pics I posted above. My windshield is still there and the dash pad is not.
elwesso
2007 BMW M Coupe
defintely.. I did not remove my dash to remove those bolts.. Not easy indeed, but extremely possible...
not to mention, if you yank hard enough the dash WILL come out...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well, I guess a side benefit will be a spotless evaporator closet and coil.
