Electric fans will not be a benefit regarding additional power output of the motor. The benefits derived from electric fans is increased accessibility in front of the motor and cooling insurance.
By insurance I mean that if you have 2 dual fans setup, (one pushing, one pulling), but you only use 2 normally and 3 when the a/c fan signal kicks in, you'll always have at least one to limp home on if 1-3 fail.
If your fan clutch fails, it can possibly seize, seizure of fan clutch sometimes leads to shearing off at the water pump, leaving you with nothing to circulate your coolant but wishful thinking.
If you're worried about alternator output, get a bigger alternator.
Mmmm, IMPUL Goodness
