pouncer11 »
https://forums.nicoclub.com/pouncer11-u94289.html
Tue May 13, 2008 3:47 am
Youre going to get distortion going from speaker level to pre-amp. I would suggest not even bothering with an output converter and purchasing a pioneer or alpine head unit. It will run you between 150-200 dollars when you are done but the end result is only low sounds in the sub and highs/mids in the car. (make sure it has a high pass filter for pre-amp out or low pass filter for the in-car speakers. ) In other words dont crap out on the sub quality when you have bose quality mids and highs. woofersetc.com is a good place to shop for affordable high quality stereo equipment. If thats not in your budget then tap the lines near the head unit. i suggest soldering the wires, tape melts in the summer and twisted wires cause distortion.
