 Synthetic Oil or not......
tooloon
whitby
10-23-2007
Hello,
My 2007 M35 Sport is going in for it's 30 K service on Monday and I have been trying to decide if I should switch to synthetic oil or not....
I have used it in thepast on other vehicles and been happy....
Also, I do not have an Infiniti dealership close to me so I was going to get the service done at Nissan. They said they can do any service, just not warranty issues...
Anyone care to comeent one way or the other???
Thanks,
Alex
THT
98 Rav4, 04 M45
Joliet IL
8-3-2005
Use synthetic when you can; it provides better protection
antzrus
'06 M35xxx/Obsidian/Bourbon Rosewood/Premium/XM/Tint ClearBra/SteelSkidPlate ContiExtremeContacts
Wenatchee WA
2-19-2008
 « Re: Synthetic Oil or not...... (tooloon)
Use it in my machine w/no problem. As an aside; I have been driving for over 40 years now. I have used the cheapest stuff available when I was young and ignorant-even let oil changes go by until the stuff was like black pudding. I have not been oil "compulsive" (for a better word).
I have yet to have an oil related problem w/any machine in all these 40 plus years. I think synthetic, expensive oils were created just to make us, street drivers feel better...
Jim
Pashdut
06' M35
12-7-2005
 « Re: Synthetic Oil or not...... (antzrus)
Pretty much boils it down to this:
if you live in a place where there is snow, ice, and freezing temperatures, then Synthetic is recommended because it cannot freeze.
if you live in So. Cal like I do, good old Mobil 1 regular oil is just fine.
ps: this topic has been debated from here to Istanbul on this forum. Do a quick search and you will see some other opinions.
Modified by ttsupra26 at 12:42 PM 5/12/2008
06' M35
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
The main reason for using synthetic (www.bobistheoilguy.com will get you started) is their extended envelope of performance, not necessarily extended changes.
The best oil is always fresh oil.
Brian
1995 Q45 & Q45t & 2000 Q45
GJEMD
Macon Ga
1-9-2007
Also buy good gas like Chevron or Amoco. Keeps oil contamination to a minimum
Pashdut
06' M35
12-7-2005
 « Re: Synthetic Oil or not...... (GJEMD)
Quote, originally posted by GJEMD »
I don't think your gas company makes a major difference. It's all about Octane. 91 all the way and you'll be fine (except for Arco...they are really cheap on quality).
Here is my gas station I fill up at in So. Cal: http://www.bp.com/sectiongener...28375
wingFeather
Arm Chair w/ cigar
7-21-2005
 « Re: Synthetic Oil or not...... (ttsupra26)
I switched my M35 to synthetic after about 15k miles.
Synthetic is better
Double E
'04 M45 Brill. Silver, NAV
Ral NC
1-18-2008
 « Re: Synthetic Oil or not...... (wingFeather)
I changed my M to synthetic at 49K miles. I have a small puddle on the garage floor now but It may have been from me not cleaning off the access door well enough. The puddle was fresh oil though and any mess I would have made on the door would have been in the draining process.
I'm a bit concerned so far.
I took some cleaner to the door, drain and filter area and wiped up the puddle. I'll take another look Tuesday and report back.
I've not had issues switching other cars over before but we'll see.
NightRiderQ45
1998 Infiniti Q45
Birmingham AL
4-11-2007
Quote, originally posted by ttsupra26 »
Mobil 1 isn't regular.....it's synthetic.
Mobil Clean 5000 is regular dino.
1998 Infiniti Q45. 212k and counting on original motor and transmission...
Pashdut
06' M35
12-7-2005
 « Re: Synthetic Oil or not...... (NightRiderQ45)
Quote, originally posted by NightRiderQ45 »
that's right mate^ that's what I meant
tooloon
whitby
10-23-2007
I went with synthetic (Mobil 1). I've always liked it better in my past vehicles... As for octane, I run on 94.... I love the car but I wish the gas milage was a bit better on my M35 though....
Thanks everyone,
Alex
Pashdut
06' M35
12-7-2005
Quote, originally posted by tooloon »
Thanks everyone,
Alex
Where do you get 94 octane from? (not that I would need anything higher than 91, I'm just curious because I have never seen anything higher than 91 at any gas stations)
szhosain
Super Moderator
2003 M45. Brilliant Silver.
San Jose CA
7-23-2002
That is not in California for sure ... other states have 93 available as Premium. I have not seen 94 though ...
Z
szhosain
Super Moderator
San Jose CA
7-23-2002
Ummm, no, it can help. Chevron puts in "Techron" additive into their gas. Which is basically a diluted version of the stuff in BG-44K and it does keep fuel injectors cleaner tha other gas. No mileage improvements per se, but the engine runs better.
Z
NightRiderQ45
1998 Infiniti Q45
Birmingham AL
4-11-2007
 « Re: Synthetic Oil or not...... (szhosain)
Quote, originally posted by szhosain »
Z
BG-44k have changed their formula.....for the worse. Doesn't contain the strong cleaning agents like the old forumula does which sucks.
Double E
Ral NC
1-18-2008
So if it changed for the worse, is the bottle of Techron I'm adding every so often about as good as I can do myself?
szhosain
Super Moderator
San Jose CA
7-23-2002
Ah! I did not know that ...
Z
szhosain
Super Moderator
San Jose CA
7-23-2002
 « Re: Synthetic Oil or not...... (Double E)
Quote, originally posted by Double E »
I don't know for sure. You should at least use the stronger version of the Chevron Techron that is sold - there are two different bottles (I forget the exact info on the bottle).
Just don't add in more than one bottle (of the BG44K or the conc Chevron Techron) more often than every 3000 miles - only use one extra one if you have a specific problem (like engine raggedness) that you are trying to cure.
Ideally, do this additive about two tankfuls (approx 600 miles) before an oil change, so whatever may have blown into the oil is removed from the engine.
Z
tooloon
whitby
10-23-2007
They sell it at Sunoco gas stations in Canada. I've always put it in my cars that require higher octane gasoline in the past....
Alex
saeedakobiakov
04 M45
GLOSTA MA
2-8-2008
we had 94 in Mass. until 3,4 years ago, now 93 is the highest.
shell or sunoco in my car only. that is why my car is the fastest on this forum.
i just bored reading this silly topic.
Sorry dont take it personally any one.
just change your oil every 3 k with Mobil one like me,if you care about the car.
later.
take it easy on me now.
14.1 @ 100.2
NightRiderQ45
1998 Infiniti Q45
Birmingham AL
4-11-2007
I would use Redline S-1 or Gumout Regane. Redline contains 30-50% of cleaning ether while Regane contains 30-40% of cleaning ether which a OTC product.
http://www.redlineoil.com/msds/43.pdf - Redline S1
http://msds.walmartstores.com/cache/25030_1.pdf - Gumout Regane
Double E
Ral NC
1-18-2008
 « Re: Synthetic Oil or not...... leak update
No drips on the floor 6 days later...
» Return to M-Series Forum / Fuga Forum
