brand suggestion
dormicum
Car: 2002 Q45
which brand of subpension will you suggest if i want to install a coil over for my 2002 Q
Modified by dormicum at 12:28 AM 5/10/2008
Q45tech
What is the purpose of modification? What do you hope to achieve?
Suspensions have little to do with peak handling as tires represent 90% of what possible. Soft fast wearing expensive tires will out handle hard highway tires by close to 10%. Body lowering can improve things MAYBE 1-1.5% if done correctly at the expense of ride and impact harshness over bumps.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Theres not much available for the F50 so id say whatever you can get your hands on easiest is probably going to be your best bet.
dormicum
Car: 2002 Q45
Q45tech wrote:What is the purpose of modification? What do you hope to achieve?
just want to be more stifferas the espelir coil with the standard subspension body is to soft for this 2 tons car
dormicum
Car: 2002 Q45
elwesso wrote:Theres not much available for the F50 so id say whatever you can get your hands on easiest is probably going to be your best bet.
so far as i know is JIC
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There is insurance also.
Try the Espelir springs and report back with full before and after alignment spcifications..
dormicum
Car: 2002 Q45
maxnix wrote:There is insurance also.
INSURANCE is far from affordble for me
i am now using espelir springcheck out the fotos hehehehe
