elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 7:12 AM 5/9/2008 |
NICE! what kind of boost are we looking at?Those pictures make me happy in the pants.
SHIFT_it yourself
 1994 Q45t- 5 Speed The Infiniti Q45 Resource, Q45.org | Nissan VH series website NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 7:50 AM 5/9/2008 |
Me stupid! Where are O rings in block?Rods forged? Did you sleeve it also? Dropped static CR ought to help life and power. Does VK have squirters for bottom of pistons? Changing oil pump, radiator, transmission build? Good luck!
Brian 1995 Q45 & Q45t & 2000 Q45
jonseyq45
1990 Q45, Rare 70 402(BB) Monte Carlo, Rare 73 Buick 455 Centerion Convert,1981 KZ1300 6cyl DOHC M/C
Vancouver Wa
2-18-2008
| « Re: 2002 Q45 F50 Project Teaser pics (maxnix) | 11:57 AM 5/9/2008 |
O rings are a way of providing additional sealing. Grooves are cut in both the head and the block. A ring is made, usually copper, to fit in the groove. As it is both in the head and the block it provides a stronger seal. Used in both turbo and supercharger applications where cylinder pressure is raised.Jonsey....
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: 2002 Q45 F50 Project Teaser pics (maxnix) | 1:26 PM 5/9/2008 |
Wow.
marksport
11-24-2003
| « Re: 2002 Q45 F50 Project Teaser pics (maxnix) | 2:03 PM 5/9/2008 |
| Quote, originally posted by maxnix » | | Me stupid! Where are O rings in block? Rods forged? Did you sleeve it also? Dropped static CR ought to help life and power. Does VK have squirters for bottom of pistons? Changing oil pump, radiator, transmission build? Good luck! |
jonseyq45 nailed the o-ring answer. Rods are billet steel, factory sleeves bored out 0.5mm/0.020", low compression pistons for higher boost level. I don't think the VK have squirters built in. Oil pump is stock, radiator will be custom made and thicker. Transmission will be rebuilt for the increase in power. Two new B&M oil coolers, one for the transmission and one for the engine oil will be installed behind the fog/driving lamps, each with their own temperature activated electric fan.
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: 2002 Q45 F50 Project Teaser pics (jonseyq45) | 2:17 PM 5/9/2008 |
| Quote, originally posted by jonseyq45 » | | O rings are a way of providing additional sealing. Grooves are cut in both the head and the block. A ring is made, usually copper, to fit in the groove. As it is both in the head and the block it provides a stronger seal. Used in both turbo and supercharger applications where cylinder pressure is raised. Jonsey.... |
So basically 4 crush rings in a matrix to keep them located? I was thinking rubber or viton and wondering how that would work.
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 2:19 PM 5/9/2008 |
I like your approach. So no direct oil cooling of the pistons? It's reputed that the VH45DE has this feature, but never documented that I know.
Modified by maxnix at 12:03 PM 5/12/2008
jonseyq45
Vancouver Wa
2-18-2008
| « Re: 2002 Q45 F50 Project Teaser pics (maxnix) | 3:09 PM 5/9/2008 |
Ceramic coating??????
qsiguy
1994 Infiniti Q45 Turbo
Phoenix AZ
3-20-2005
| Quote, originally posted by elwesso » | | ....Those pictures make me happy in the pants. |
Very impressive! Can't wait to see how this project goes. I'm curious how much boost you are planning as well. Any specs/goals?
jimbyjimb
1992 Q45
Seattle Wa
4-3-2008
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 7:34 PM 5/9/2008 |
Beautiful engine. O-rings a nice touch.
marksport
11-24-2003
| « Re: 2002 Q45 F50 Project Teaser pics (maxnix) | 3:01 AM 5/10/2008 |
| Quote, originally posted by maxnix » | | I like your approach. So now cooling of the pistons? |
Well I haven't really thought about the piston cooling as I am running an external oil cooler. I was told that I wouldn't need squirters if I have a good cooling system. I will look at the motor again and talk to my machine shop about it. | Quote, originally posted by qsiguy » | Very impressive! Can't wait to see how this project goes. I'm curious how much boost you are planning as well. Any specs/goals? |
I am planning to run 15psi as my fuel management maxes out at 16psi. Lack of options on fuel management is the limiting factor or I would consider higher boost and twin turbo. No real goals other than making it reliable and quick enough to take on the AMG S65.
S13Flame
Y33
Nashville TN
1-3-2005
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 5:00 PM 5/10/2008 |
Hmmmm an S65 will leave you for lunch my friend even with your supercharger. You would need at least 20psi of boost to keep up with that German Monster. Believe me I know....
Buy my wheels
sijoko
Black 1994 Infiniti Q45 Turbo, Silver 1995 Infiniti Q45t
USA
7-26-2002
| « Re: 2002 Q45 F50 Project Teaser pics (S13Flame) | 7:15 PM 5/10/2008 |
| Quote, originally posted by S13Flame » | | Hmmmm an S65 will leave you for lunch my friend even with your supercharger. You would need at least 20psi of boost to keep up with that German Monster. Believe me I know.... |
What are you basing your statement on? A VK45DE with 15 psi supercharged is going to put out approx. 600 hp. How much power is the S65 pushing and also how much does it weigh? Anyway, this is an awesome project. Who wants to guess the quarter-mile times? I'm going to say below 12 secs with the full 15 psi and a proper tranny setup.
 TURBO Q45 ----------0-100 MPH VID: http://www.youtube.com/watch?v=3_Kz9fgQyzw
konatown
94 Q45t, 2010 Genesis Coupe
Evansville IN
8-22-2006
| « Re: 2002 Q45 F50 Project Teaser pics (sijoko) | 8:10 PM 5/10/2008 |
He'll be sacrificing some torque to the S65 AMG but will also have about 800lbs less to lug around.I bet at 15PSI this car will be just as fast as the MB. Awesome project, keep us updated!
marksport
11-24-2003
| « Re: 2002 Q45 F50 Project Teaser pics (S13Flame) | 1:18 PM 5/11/2008 |
I'm counting on the weight difference AMG S65 est curb weight: 5035 lb Infiniti Q45 est curb weight: 3801 lb At 8lbs on the smaller supercharger, this car was able to keep up with an 2008 BMW M6.
SynisterQ
1994 Black on Black Q45
Jax NC
2-10-2008
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 4:15 PM 5/11/2008 |
Totally awesome!! Please keep us posted with more pictures and details as the project progresses. Are those Kenne Bell superchargers? Beautiful!!
 1994 Infiniti Q45 black on black, Tokico blues, Eibachs (I think they're Eibachs, its definitely lowered), Stillen upper control arm and FSTB, Sylvania Ultras, 18x9.5 Enkei Racing rims with Falken Ziexs 245/40/18(shoulda gotten 255s), upgraded 2 gauge ground cables, 136k miles http://www.myspace.com/vuallinnguyen
gammer_ghn
I Slay Chef Gordon
1999 INFINITI Q45, Nissan 240 Vert, Chevy Astro
Tujunga CA
4-2-2007
| « Re: 2002 Q45 F50 Project Teaser pics (SynisterQ) | 4:28 PM 5/11/2008 |
napkins please!!! very nice! you are one of the first to do this!
auditech10
03 M45
Algonquin IL
3-28-2006
I have a video of a stock 2002-04 S600(v12 biturbo, but not the amg) do 11.8 in the quarter. I will bet my next years worth of salary that the AMG s65 will trounce over that, especially the newer one. None the less, for approx 1/3rd of the price of one, it will give it a run for the money! Awesome job, any info on the supercharger kit you are using? Is it the Kueliyan(sp?) setup that you are just making better??? Cheers
sijoko
USA
7-26-2002
| « Re: (auditech10) | 10:38 AM 5/12/2008 |
| Quote, originally posted by auditech10 » | I have a video of a stock 2002-04 S600(v12 biturbo, but not the amg) do 11.8 in the quarter. I will bet my next years worth of salary that the AMG s65 will trounce over that, especially the newer one. None the less, for approx 1/3rd of the price of one, it will give it a run for the money! Awesome job, any info on the supercharger kit you are using? Is it the Kueliyan(sp?) setup that you are just making better??? Cheers |
The S65 does the quarter mile in the low 12 second range. Yes it's a powerful car but it weighs over 5000 lbs whereas the F50 weighs in at ~ 4000 lbs. I don't think a supercharged Q45 with approx. 600 hp will have any problems with it.
qsiguy
Phoenix AZ
3-20-2005
Lofty goal to beat a 6.0 liter V12 twin turbo 604 hp/738 lb torque supercar. But...if we don't make goals that push the limits we wouldn't make much progress would we?It's probably safe to say you won't encounter too many of those cars and fewer still that will be willing to race you. Might have to go by the numbers, hp / 0-60 (have to beat 4.2 sec) / quarter mile (12.4 @118 mph according to C&D), etc. Good luck!
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: 2002 Q45 F50 Project Teaser pics (marksport) | 12:06 PM 5/12/2008 |
Well, if he doesn't get him on the straightaway, there is always the next corner.
sijoko
USA
7-26-2002
| « Re: (qsiguy) | 1:55 PM 5/12/2008 |
The S65 does 0-100 mph in 9.2 seconds. My car hits 100 mph in a tad bit over 10 seconds. So I can definitely see a supercharged F50 with 15 psi being faster than the S65.Here's the performance stats for the S65: VEHICLE TYPE: front-engine, rear-wheel-drive, 5-passenger, 4-door sedan PRICE AS TESTED: $191,215 (base price: $184,875) ENGINE TYPE: twin-turbocharged and intercooled SOHC 36-valve V-12, aluminum block and heads, port fuel injection Displacement: 365 cu in, 5980cc Power (SAE net): 604 bhp @ 4800 rpm Torque (SAE net): 738 lb-ft @ 2000 rpm TRANSMISSION: 5-speed automatic with manumatic shifting DIMENSIONS: Wheelbase: 124.6 in Length: 205.0 in Width: 73.7 in Height: 58.0 in Curb weight: 5081 lb C/D TEST RESULTS: Zero to 60 mph: 4.2 sec Zero to 100 mph: 9.2 sec Zero to 150 mph: 21.4 sec Street start, 5-60 mph: 4.4 sec Standing ¼-mile: 12.4 sec @ 118 mph Top speed (governor limited): 158 mph Braking, 70-0 mph: 154 ft Roadholding, 300-ft-dia skidpad*: 0.90 g FUEL ECONOMY: EPA city driving: 13 mpg C/D-observed: 12 mpg http://www.caranddriver.com/re...html
gammer_ghn
I Slay Chef Gordon
Tujunga CA
4-2-2007
| « Re: (sijoko) | 2:45 PM 5/12/2008 |
am i the only one here that knows the Q will demolish that piece of crap MBZ come on now where is the Q love?? A F50 with 475hp will get 8.0021 pounds per HP where the S65 will only get 8.322. Yes i know torque is high on the S65amg but if he can achieve 500 hp he will get 7.602 and i think that is more than enough to wipe his *** with the S class! Dont forget a 4.5L V8 VS 6.0L I12 TT. Makes me chuckle when i look at these numbers and your paying the fraction of the price of the MBZ. Look at the link i provided and you will see that in 2005 if you were to buy a flagship car in around the same price as the F50 you would have won in every aspect. Just look at the weight difference and power since we do have the good toys that are easier to use than the Idrive.EDIT: The links might look the same but they are not check all of them out. http://autos.msn.com/research/...99706 http://autos.msn.com/research/...99706 http://autos.msn.com/research/...99706
konatown
Evansville IN
8-22-2006
| « Re: (gammer_ghn) | 5:08 PM 5/12/2008 |
At 15 PSI he should be making about 620-650 HP. He'll be wiping the road off with that Teutonic yacht.
gammer_ghn
I Slay Chef Gordon
Tujunga CA
4-2-2007
| « Re: (konatown) | 6:03 PM 5/13/2008 |
that is true. Well i demand more pix!!! dont leave us hanging here!!!
impreziv
1990 Skyline GTR
Winnipeg MB
2-26-2006
| « Re: (gammer_ghn) | 9:24 PM 5/14/2008 |
where are you guys getting these "15psi = 650hp" figures from?psi doesnt mean jack, unless you know how much air mass is moved by the compressor at that pressure. if the compressor he is using is only capable of pushing 30% more air than the engine normally consumes, its only going to make 30% more power. to make 600hp, its going to need to flow more than twice the air. most of the 600hp capable superchargers i'm familiar with are a fair bit larger than this one, judging by those pics of the blower. i dont mean to rain on anyones parade, but seriously, 650hp from a blower that small?
konatown
Evansville IN
8-22-2006
| « Re: (impreziv) | 9:29 PM 5/14/2008 |
I was hypothetically speaking, of course.
impreziv
1990 Skyline GTR
Winnipeg MB
2-26-2006
| « Re: (konatown) | 9:55 PM 5/14/2008 |
yeh i understand this is hypothetical numbers. but hp is impossible to determine unless you know the specs of the compressor. i can't say anything for sure based on only looking at pictures, but that blower looks about the same size as something like what comes on a Pontiac GTP or a smaller Benz motor. look at the blower on the 2009 Vette ZR1. that motor makes 630hp at 10.5psi, and that blower is significantly larger than this one, and it is intercooled. edit: if you want an expample of a blower from a smaller benz motor, look at the M111 engine. it has a supercharger, and at 10psi, most people cant get too much more than 200whp from the motor. nevermind the fact that it is a smaller motor compaired to a V8, but at 10psi, the blower pushed enough air to make 200whp. if someone put that supercharger on a 4.5 V8, they would surely loose power, as the blower wouldnt be able to push more air than the engine normally breaths.
Modified by impreziv at 11:19 PM 5/14/2008
sijoko
USA
7-26-2002
| « Re: (impreziv) | 11:14 PM 5/14/2008 |
Since we don't know the flow numbers on the compressor, we can't know for sure but as a rule if you double the atmospheric pressure going into an engine you will approximately double the horsepower. That means if you take a 340 hp engine and run 14.7 psi of boost with a properly sized supercharger you can expect 680 hp minus the power to run the supercharger. So, I think a guesstimate of 600 hp is not too far off the mark unless the supercharger he is going to use is flow limited.
impreziv
1990 Skyline GTR
Winnipeg MB
2-26-2006
| « Re: (sijoko) | 11:38 PM 5/14/2008 |
| Quote, originally posted by sijoko » | | as a rule if you double the atmospheric pressure going into an engine you will approximately double the horsepower. That means if you take a 340 hp engine and run 14.7 psi of boost with a properly sized supercharger you can expect 680 hp minus the power to run the supercharger. |
you are so very wrong. you could take a Garrett GT2860 turbocharger (this turbo flows a maximum amount of air to make 360hp), and set it up on your 4.5L. set up the wastegate to 14.7psi. you will certainly NOT make 600hp. the turbo isn't capable of flowing more than 360hp worth of air. i have no idea how much pressure the turbo make when it flows 360hp, but it is much higher than 14.7psi (maybe 30psi?), it certainly doesnt make 600hp there either. the same logic applies for a supercharger. there is a certain speed you can accellerate a supercharger to where it no longer flows more air than it did at a lower RPM, this is beyond its efficiancy point. this factor allows you to determine the maximum amount of air the compressor will be able to flow. most manufacturers of turbos and superchargers will tell you the max amount of power it can make. the amount of boost pressure is not a factor. the amount of air mass it flows at a given RPM within its efficiancy range is the only thing that will tell you how much power the blower can make. by your logic, any turbo capable of compressing air to 14.7 psi could make an engine produce 600hp, as long as it made 300hp in its normally aspirated state. air-mass = power (potential power) air-pressure = merely the compression needed to compress that air mass to a volume able to be forced into the engine.
sijoko
USA
7-26-2002
| « Re: (impreziv) | 11:42 PM 5/14/2008 |
| Quote, originally posted by impreziv » | you are so very wrong. you could take a Garrett GT2860 turbocharger (this turbo flows a maximum amount of air to make 360hp), and set it up on your 4.5L. set up the wastegate to 14.7psi. you will certainly NOT make 600hp. the turbo isn't capable of flowing more than 360hp worth of air. i have no idea how much pressure the turbo make when it flows 360hp, but it is much higher than 14.7psi (maybe 30psi?), it certainly doesnt make 600hp there either. the same logic applies for a supercharger. there is a certain speed you can accellerate a supercharger to where it no longer flows more air than it did at a lower RPM, this is beyond its efficiancy point. this factor allows you to determine the maximum amount of air the compressor will be able to flow. most manufacturers of turbos and superchargers will tell you the max amount of power it can make. the amount of boost pressure is not a factor. the amount of air mass it flows at a given RPM within its efficiancy range is the only thing that will tell you how much power the blower can make. by your logic, any turbo capable of compressing air to 14.7 psi could make an engine produce 600hp, as long as it made 300hp in its normally aspirated state. air-mass = power (potential power) air-pressure = merely the compression needed to compress that air mass to a volume able to be forced into the engine. |
Maybe you should take the time to read what I wrote first before you answer. I qualified my statement about psi with the fact that the compressor has to be sized properly for the engine. So am I still wrong?
marksport
11-24-2003
| « Re: (impreziv) | 12:28 AM 5/15/2008 |
Tho I haven't stated how much power I will be putting out, this supercharger maxes out at 970cfm or around 67lbs/min
Modified by marksport at 8:40 AM 5/15/2008
impreziv
1990 Skyline GTR
Winnipeg MB
2-26-2006
| « Re: (marksport) | 4:56 AM 5/15/2008 |
| Quote, originally posted by sijoko » | Maybe you should take the time to read what I wrote first before you answer. I qualified my statement about psi with the fact that the compressor has to be sized properly for the engine. So am I still wrong? |
i was responding to your bit about "double the atmospheric pressure going into an engine you will approximately double the horsepower" yes you are still wrong about that. | Quote, originally posted by marksport » | Tho I haven't stated how much power I will be putting out, this supercharger maxes out at 970cfm or around 67lbs/min Modified by marksport at 8:40 AM 5/15/2008 |
i wasnt meaning to rash on you or your project. i was just saying this cause other ppl are spitting out alot of numbers with no information regarding the actual supercharger you are using. if 970cfm is the max, you should be good for 668hp. the normal rule is 1.45cfm = 1hp (potential HP). im not sure if youre planning for an intercooler or not. not having one is going to bring you a bit lower than that 668 'potential hp'. i stand corrected :p i wouldnt have figured a blower of that size to be able to flow that. is that an OEM blower from a production car? or an aftermarket?
marksport
11-24-2003
| « Re: (impreziv) | 6:48 AM 5/15/2008 |
| Quote, originally posted by impreziv » | i was responding to your bit about "double the atmospheric pressure going into an engine you will approximately double the horsepower" yes you are still wrong about that. i wasnt meaning to rash on you or your project. i was just saying this cause other ppl are spitting out alot of numbers with no information regarding the actual supercharger you are using. if 970cfm is the max, you should be good for 668hp. the normal rule is 1.45cfm = 1hp (potential HP). im not sure if youre planning for an intercooler or not. not having one is going to bring you a bit lower than that 668 'potential hp'. i stand corrected :p i wouldnt have figured a blower of that size to be able to flow that. is that an OEM blower from a production car? or an aftermarket? |
That's the main reason I never quoted how much power I was going to get, other than 15psi would be as much most cars can run on pump gas. I am running the Laminova heat exchanger air to water intercooler. The blower is fairly compact and being that it's a twin screw, it is one of the most efficient supercharger around. The unit is a Lysholm Autorotor sold thru Kenne Bell. I think there is only one or two cars that use these as OEM supercharger as they are quite expensive new compared to a roots or magnacharger.
maxnix
NICO Supporter
Austin TX
7-22-2002
| « HP is not blow power (marksport) | 9:08 AM 5/15/2008 |
All this talk about air flow and horsepower is rather irrelevant because HP is just a calculated number based on torque.What really counts is area under the torque curve when graphed. Why the V12 MB truck designed head engine and Audi V12 diesel do so well, the latter in spite of its RPM limitations (hence less horizontal dimension on the X axis).
sijoko
USA
7-26-2002
| « Re: (impreziv) | 10:45 AM 5/15/2008 |
| Quote, originally posted by impreziv » | i was responding to your bit about "double the atmospheric pressure going into an engine you will approximately double the horsepower" yes you are still wrong about that. |
I think you should school yourself before you go around saying people are wrong about a subject. All naturally aspirated engines are operating at 14.7 psi of pressure at sea level. This is the weight of the atmosphere pushing the air into the vacuum inside the cylinders. If you go up in elevation, where there is less atmospheric pressure, you will have less weight pushing the air into the cylinders hence less engine power output. This is basic engine theory. Now, what about forced induction? I said that if you added 14.7 of boost to an engine with the correct sized compressor you would approx. double its power output. Why? Because we now have double the amount of air going into the engine. The only thing is that the compressor has to be able to support double the naturally aspirated airflow at 14.7 psi of boost. Yes, you have to take into account other variables such as heating of the air flow but the basic premise is still correct. Here's an excerpt from an article by Popular Hotrodding: Normally aspirated motors actually have atmospheric pressure pushing the air into the cylinders. This pressure (at sea level and at a given temperature) is 14.7 psi or one bar. Doubling the power output of the motor can be as simple as doubling the pressure to the motor. Upping the pressure to two bar (14.7 psi above atmospheric) can double the power output of your motor. Here is where things start to get tricky. Suppose you have a 300hp normally aspirated motor and want to double the power output. If you install a turbo kit and set the waste gate to 14.7 psi, chances are you will nearly double the power output. Of course, this equation assumes a number of things, the first of which is you have a turbo capable of supplying 600 hp worth of airflow. This pressure-to-power conversion works at elevated power levels as well, which is why we chose to increase the power output of the normally aspirated motor in the first place. If we run 14.7 psi, we essentially double any power gains applied to the normally aspirated motor. An example works well here. Suppose our test motor produced 400 hp normally aspirated. If we applied 14.7 psi to the 400hp motor, we would expect something near 800 hp. If we upped the power output of our normally aspirated motor to 450 (a gain of 50 hp), the same 14.7 psi would give us something closer to 900 hp. If we take this scenario one step further, we can see that a 500hp normally aspirated motor will produce near our magical 1,000 hp at just 14.7 psi. http://www.popularhotrodding.c...html And here's what ProCharger states on their website:
How much horsepower will a supercharger add to my engine? Although some manufacturers claim a specific horsepower increase, superchargers actually add horsepower as a percentage gain (percentage of an atmosphere). Assuming an engine with a compression ratio of around 9:1 running pump gas,if a supercharger gives your engine 14.7 psi of boost (another atmosphere) that will essentially double the output of your engine, everything else being equal. http://www.procharger.com/faq.shtml
marksport
11-24-2003
| « Re: (sijoko) | 2:34 AM 5/20/2008 |
My build is based on the 2003 Cobra Mustang as they have similar displacement at 4.6L, quad cam 32valve motor and 320hp stock.
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: (marksport) | 8:15 AM 5/20/2008 |
I have seen this in a special Maruader, a one off special build. Want a picture, MS?He also has a SVT Mustang that puts out 600+HP on racing gas. Still have to go for a ride in it.
Modified by maxnix at 4:21 PM 5/20/2008
marksport
11-24-2003
| « Re: (maxnix) | 11:22 AM 5/20/2008 |
| Quote, originally posted by maxnix » | | I have seen this in a specail Maruader, a one off special build. Want a picture, MS? He also has a SVT Mustang that puts out 600+HP on racing gas. Still have to go for a ride in it. |
lets see them. I've always loved the marauder for their sleeper musclecar looks.
| First 1 2 > Last |
