Yeah, really! Those things look about 2" shorter in free length.elwesso wrote:what are you doing for camber correction.
my mechanic said i need the left side "heim joint" where the uca bolts to chassis (subframe) infiniti says its part of the subframe and not available seperate?mechanic said it is slightly adjustable , u know what he is saying ? from ur pic it seems not to be adjustable and part of subframealso no part # on exploded view if i am looking at correct thingqsiguy wrote:Since I snapped the rear wheel stud and had to put the car back on the jacks I decided to take the opportunity to complete the install of more parts that have been waiting patiently in my garage.
Started on the suspension. New Tokico Blues and Cali Customs springs going on. The rears are done, pics below. I ordered several new rear wheel studs and a couple for the front just for spares from Joe. Also ordered new rear diff bushings so I can get my 4.08 installed, and a new speed sensor gear as well for speedo correction.
So on the to do list:
Tokico Blues/Cali Customs springs (fronts still to do)Unitrax 4.08 rear diffRe-gear speed sensorFront steering bootsAdjustable front tension rodsActive model rear sway bar (if it will fit around the turbo plumbing/exhaust)transmission coolerand possibly a new front mount intercooler if I can sneak it into the budget
Here's how the OEM rear springs compare to the Cali Customs
Passenger side rear
Drivers side rear
SPL is meant to have an improved upper link out thei summer. There is a world of difference between genuine SPL and the copies. Someone had their copy tension rod break not too long ago.elwesso wrote:Im not sure if they ebay brands are good? I use all SPL so I dont worry.. Pricey but worth it IMO, I'll never have to replace a tension rod or upper link ever again!
$125 for pair - guy at nissan said they are manufactured for him, and they have had no problems in the 5 years they have been selling them, and they have dust boots over the heim joint.Jamesjamesmost wrote:ok so what went bad was the heim joint on the stillen uca thats the rotating knuckle.stillen wanted $120 shipped for the heim joint, and that was after a series of no no no not sold seperatethe guys at 300zxClub.com recommended this for $125 for pair:> or each not surehttp://www.courtesyparts.com/M...1101R
not sure why either, maybe Joe had them in stockhad the suspension tech bushing installed last week and car is solid as a rock nowwill install the UCA'si mentioned earlier next week ,bty they look beautiful.the heim joint is completely rubber booted.qsiguy wrote:Joe's got my parts in, not sure why you couldn't get the diff bushings, he got them in a couple days...on my way to pick them up in a minute.
Anyone have a spare bolt for the front of the tension rod? The one that goes through the bushing? Mine was rusted in and I destroyed it getting it out.
Yes, if you are reffering to the nut holding the axle into the hub, then it is 36mm.qsiguy wrote:The rear wheel hub is kicking my butt. What size is that giant retaining nut? 35-36mm? According to my cheesy plastic calipers it looks like about 36mm. Can someone verify? I couldn't find the size listed in the FSM, just the torque specs.
