elwesso
Super Moderator
94 Q45t NICO Track Slut
Anderson and Angola IN
2-23-2003
| « Re: what can I use to clean the plenum (ppastos) | 8:41 AM 5/8/2008 |
are you talking about the outside?Autoparts stores sell engine degreaser that works pretty well...
The Infiniti Q45 Resource, Q45.org | Nissan VH series website NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328, ask for Joe, say Wes sent you.Need a Nissan/Infiniti Mechanic around Indy OR Northern Indiana?? EMAIL ME!!! NICO ECU's for sale
ppastos
1993 Infiniti Q45 114,000 Miles
Ipswich Ma
12-22-2007
| « Re: what can I use to clean the plenum (elwesso) | 8:47 AM 5/8/2008 |
Yea I tried that I basically tired everthing short of painting it and I don't want to do that just for the shine.
Q45tech
Q45 Guru
1990 Q45 319,000 miles
Marietta , Georgia
4-30-2002
| « Re: what can I use to clean the plenum (ppastos) | 8:56 AM 5/8/2008 |
Be sure to remove plenum from enine bay for serious cleaning as chemicals will fall into valley and eat contacts and hoses.....................don't do damage in quest for a shine!
http://www.t3auto.com/
goody94q45
Q45 Undertaker
94Q45 Gray/Gray
Orangevale CA
8-17-2005
| « Re: what can I use to clean the plenum (ppastos) | 8:58 AM 5/8/2008 |
I use a can of brake parts cleaner and a wire toothbrush. Spray a few square inches at a time, give it a scrub, and wipe of the dissolved residue with a rag. Don't scrub the emblem.
Mike "Goody" Goodwin 94 Q45 157,000 miles ____________________ 90 Q45 115,000 miles (The Beauty) ___________________________ (The Beast)
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
| « Re: what can I use to clean the plenum (elwesso) | 9:01 AM 5/8/2008 |
| Quote, originally posted by elwesso » | are you talking about the outside?
I bet not as inside is what affects performance.I took mine to a machine shop which had a nasty bath for it. Worked wonders on it and the lower runners. You must have new gaskets for the latter.
Brian 1995 Q45 & Q45t & 2000 Q45
Q451990
Old School Q Guru
1990 Q45 - 91K, 2005 G35 Sedan - 32K, 1997 Nissan Truck - 133K
Columbia, SC
7-23-2002
Brian, Did it damage the outside finish, or the emblem? Heath
1990 Infiniti Q45 - AKA "Q2" 2005 Infiniti G35 - Sedan A/T FOR SALE 1997 Nissan Truck - XE - 5 Speed M/T
goody94q45
Q45 Undertaker
94Q45 Gray/Gray
Orangevale CA
8-17-2005
| « Re: what can I use to clean the plenum (maxnix) | 9:29 AM 5/8/2008 |
| Quote, originally posted by maxnix » | | I took mine to a machine shop which had a nasty bath for it. Worked wonders on it and the lower runners. |
I cleaned my spare plenum's interior with carb cleaner, brake parts cleaner, and a combination of wire brushes and bottle brushes. It came out spotless but it also took a few hours and a lot of scrubbing. The machine shop was probably able to clean your parts while you had a cup of coffee in the lobby (j/k). The emblem will easily pry off a hot engine or sun-heated plenum with a screwdriver and reattached with trim tape after cleaning.
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: (Q451990) | 9:32 AM 5/8/2008 |
Oh yeah, emblem was toast. Slightly discolored the aluminum, but it was clean. All accessory tubes etc. were removed.Maybe I'll find a way to post an after picture. Only before I have is of VH41DE.
qship96
1996 Q45
Timonium,Md
11-24-2002
| « Re: (maxnix) | 12:33 PM 5/8/2008 |
On one of those days where the wife really pisses you off..... her electric toothbrush and some metal polish should do the trick!
maxnix
NICO Supporter
Austin TX
7-22-2002
| « Re: (qship96) | 1:02 PM 5/8/2008 |
| Quote, originally posted by qship96 » | | On one of those days where the wife really pisses you off..... her electric toothbrush and some metal polish should do the trick! |
Damn, I usually use hers on the toilet. I'm dead.
Haitian_King
1992 Infiniti Q45
Willingboro NJ
1-13-2007
| « Re: what can I use to clean the plenum (goody94q45) | 10:20 PM 5/10/2008 |
| Quote, originally posted by goody94q45 » | I cleaned my spare plenum's interior with carb cleaner, brake parts cleaner, and a combination of wire brushes and bottle brushes. It came out spotless but it also took a few hours and a lot of scrubbing. The machine shop was probably able to clean your parts while you had a cup of coffee in the lobby (j/k). The emblem will easily pry off a hot engine or sun-heated plenum with a screwdriver and reattached with trim tape after cleaning.
Mike, How did you know for sure it was clean? I have my spare plenum and about a buttload of freetime coming up. I'd like to do something productive.
"Don’t buy a poorly maintained Q… It’ll be like falling in love with a high priced hooker! The sex will be great but you’ll be broke and up all night crying." - DrewQ45"I highly appreciate the wide range of knowledge Dennis contributes to the forum but you seem to be verging on the edge of Q45Tech worship. If he said air was bad you’d probably die from asphyxiation… Get a grip man!" - DrewQ45 "Those pics make my butt leak." - AZHitman "I pulled along side of one and stared at it. Then I saw the Hyundai badge and proceeded to vomit a little in my mouth." - Yours Truly
goody94q45
Q45 Undertaker
94Q45 Gray/Gray
Orangevale CA
8-17-2005
| « Re: what can I use to clean the plenum (Haitian_King) | 10:36 PM 5/10/2008 |
When all the gunk is gone and you're done cleaning the inside of the plenum it will look as clean as the outside of the plenum- shiny aluminum. My spare plenum cleaned up in a couple of hours and looked like new. Brake parts cleaner, carb cleaner, simple green, bottle brushes, a scrubbing pad, a toilet bowl cleaner, and elbow grease will get the inside sprkling clean. All of the above and a small wire toothbrush worked nicely on the outside surfaces. You'll use a couple of cans of cleaner so work in a well ventilated area so you don't asphyxiate yourself or ignite the vapors and burn the house down when the telephone rings.
elwesso
Super Moderator
2-23-2003
| « Re: what can I use to clean the plenum (goody94q45) | 7:25 AM 5/11/2008 |
if you have all kinds of crud in the inside, anything that doestn require you to use gloves isnt strong enough. Paint stripper works well.
Victor
1994 Infiniti J30T
Fullerton CA
4-6-2008
| « Re: what can I use to clean the plenum (elwesso) | 7:53 AM 5/11/2008 |
If thats baked on grease your trying to get off wouldn't oven cleaner work? Might pit the aluminum though.
Victor
1994 Infiniti J30T
Fullerton CA
4-6-2008
| « Re: what can I use to clean the plenum (Victor) | 8:18 AM 5/11/2008 |
If oven cleaner doesn't work then methylene chloride (active ingredient in paint brush cleaner and paint remover) would.
Haitian_King
1992 Infiniti Q45
Willingboro NJ
1-13-2007
| « Re: what can I use to clean the plenum (goody94q45) | 11:15 AM 5/11/2008 |
| Quote, originally posted by goody94q45 » | | When all the gunk is gone and you're done cleaning the inside of the plenum it will look as clean as the outside of the plenum- shiny aluminum. My spare plenum cleaned up in a couple of hours and looked like new. Brake parts cleaner, carb cleaner, simple green, bottle brushes, a scrubbing pad, a toilet bowl cleaner, and elbow grease will get the inside sprkling clean. All of the above and a small wire toothbrush worked nicely on the outside surfaces. You'll use a couple of cans of cleaner so work in a well ventilated area so you don't asphyxiate yourself or ignite the vapors and burn the house down when the telephone rings. |
Did you use a small mirror to get a glimpse of the interior? Like a dental mirror?
goody94q45
Q45 Undertaker
94Q45 Gray/Gray
Orangevale CA
8-17-2005
| « Re: what can I use to clean the plenum (Haitian_King) | 11:44 AM 5/11/2008 |
I use a 1" dia. inspection mirror with extendable arm available at any auto parts store. Brake parts cleaner, carb cleaner and elbow grease should be all you need. Some chemicals aren't kind to aluminum.
Q451990
Old School Q Guru
Columbia, SC
7-23-2002
BG makes a throttle body cleaner that's basically like brake parts cleaner on crack. Small cans but it appeared to be one of those "a little dab will do ya" type of products when I saw it being used at T3.Heath
