It ran 1120 give or take some change, shipped to my door. They threw in a 3"-4" silicone coupler since I have 3" intake piping and that beast is a monster.. lolTJG wrote:how much did this cost you?
does this t2 get your approval? lolWDRacing wrote:Good times ahead...
You need to unhook the wastegate on this fvcker to...or you don't have a hair
You should get a picture of your set-up.sunnys14 wrote:Im running a 4" pipe with a 90 degree bend right off the compressor housing so it clears the power steering quite a bit.
I'm running a 3" intake pipe. I got a 3-4" reducer so I could hook up my piping, but it's not clearing very well. I bought a 45*degree, 4" to 3" silicone coupler. I've not put it on yet, due to lazyness... lolsunnys14 wrote:What size intake pipe are you running? 3" or 4"?Im running a 4" pipe with a 90 degree bend right off the compressor housing so it clears the power steering quite a bit.
It's pretty thick. It's actually, like 3/16" mild stock. It's welded to the compressor housing bracket-holder thingy. Like a big washer that spans two bolts I guess...?I found out why I wasn't boosting any higher with the line bled off all the way. The line wasn't big enough to bleed out enough of the air. I put a Manual Boost Controller on it, and she does about 22psi before she breaks up. Either the tune(from the 2860RS) needs re-done, or I'm blowing out spark. No way I'm maxing out my 740's.. And AFR's are great up until she breaks up. Low 11's actually.And yes, the arm on the wastegate was a little too tight. I fixed that to where the arm was neutral with the flapper, then gave it one turn tighter on the screw.BACARDI_DWB wrote:how thick is your wga mounting bracket.....
Um, if you are breaking it in with a T25 and a bottom mount mani like mine, I would say go with the 2871R. I should have done that in the first place, and I wouldn't have been so eager to get rid of my 2860RS. I think I went overboard with my turbo....It's a T2/T4, and it's just mind boggling. The turbine housing was machined out quite a bit for the larger exhaust wheel. Not a lot to seal to the elbow.240sxvaj wrote:How's the car running? get it dyno or something i want some numbers, so that i can start deciding on my turbo choice. still not sure if i want a t2871r or gt3076r since they cost about the same. my motor is almost done and after i use my t25 to breakin my motor i want something bigger.
Seriously dude...can you just post in Gen Chat or something? You have less then no idea what you're talking about. Until you can post something that actually makes sense, DON'T POST IN KAT...DON'T EVEN REPLY TO THIS...JUST STOP POSTING.racersonly2004 wrote:hmm if closing the gap i litlle dosnt help you might have a fuel concern we had a car come in at work not to long ago that had the same prob we recomended ading an fmu that increces the fuel pressure acording to boost pressure on a 12:1 racio. since it is a larger turbo its pumping alot more volume of air so u could need more fuel. i wasnt reading to much into your setup but if you run that much boost, and depending on the compression ratio it might be octane to low. if the turbo is watercooled it should help with pinging. but it can be hard to diagnose the problem without the vehicle in ones pressence.
WD
You're an idiot...you don't use an FMU with larger injectors...racersonly2004 wrote:obviously the ka is the only motor uve ever turbod so let me brake it down for u s l o w l y... an fmu is a fuel management unit, an adjustable fuel pressure regulator that also raises fuel pressure according to boost on a ratio. example: on a 12:1 ratio fuel pressure is increaced by 12psi for every 1 psi of boost. since it is a larger turbo it pumps a larger volume of air (air flow rate is different then psi pressure) depending on the ingectors, the tune, and fuel pressure hes running it could be runing lean and cause a missfire. how do you just assume that its spark blow out when you cant see it.
